dolly3900 |
dolly3900 Traffic Copper
Posted: 13:34 - 26 Mar 2015 Post subject: Go-Pro Camera Mount |
OK, quiet in work at the moment, all the kids on GCSE countdown, so bits of free time to play.
Currently the Go-Pro is bar end mounted and whilst it is not impeeding my control of the bike, I am consious of the slight imbalance in the steering, besides, it takes in a view of my knuckle guard at the mo.
Decided to see if I could find some way to mount it behind the screen of the V-Strom for the follwign reasons :-
Extra Protection
Central mount for balance
Central view for better coverage.
Was thinking of a couple of hours in the engineering workshop and seeing what I could bodge together with some scrap aluminium, but then I remembered I have access to a nice LASER cutter in DT, do a simple design on 2D Design and I have come up with this:-
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/cam%20mount_zpst5n2hxez.jpg
Holes to fit behind the screen mount holes and attach that way, dotted lines are where heat to bend to shape, additional holed spacers to even up the screen from bottom mounts.
Will see how it turns out an post results ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
ScaredyCat |
ScaredyCat World Chat Champion
Posted: 13:56 - 26 Mar 2015 Post subject: |
Make sure your screen is clean
Also, you probably wont just get wind noise for audio, which is a bonus. ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
dolly3900 |
Posted: 14:14 - 26 Mar 2015 Post subject: |
ScaredyCat wrote: | Make sure your screen is clean
Damn, I knew that solid black screen was a bad idea
ScaredyCat wrote: |
Also, you probably wont just get wind noise for audio, which is a bonus. |
Hadn't even thought of the wind noise issue, good call ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
Posted: 15:32 - 26 Mar 2015 Post subject: |
One bit of blue, 3mm Acrylic and a friendly Head of DT later, we have this :-
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG1017_zpswtncnrj2.jpg
Need to strip bend it now and will be ready to fit ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
Jocklad |
Jocklad Two Stroke Sniffer
Jocklad |
dolly3900 |
Posted: 15:45 - 26 Mar 2015 Post subject: |
The 3mm is flexible enough to absorb any bumps, but stiff enough to not wobble.
Going to use thin silicon washers between bike & mount, mount & screen to minimise any excessive shake as well. ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
Posted: 15:46 - 26 Mar 2015 Post subject: |
Just realised.
White bike.
Showing blue in the front
Me in High Viz jacket
Could be interestingly deceptive ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
dolly3900 |
Posted: 16:16 - 26 Mar 2015 Post subject: |
TBH, in my mind the lower bend was going to be more acute, so the Go-Pro text would have been more horizontal and as such the right way up to the rider.
As it happens, more vertical, so upside down to the front.
Oh well, no biggy ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
Posted: 16:51 - 26 Mar 2015 Post subject: |
OK, so on first fit, found it needed a slight but important bend on each end to accommodate the curve of the dash, so back to the strip heater and this is the result.
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG1022_zpsmtwarl3a.jpg
Like I said, slight, but important. ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
Posted: 16:53 - 26 Mar 2015 Post subject: |
Finally, fitment.
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG1023_zpsqmdk7hds.jpg
Slightly longer bolts needed to be used as the standard ones are long enough for the screen and that is it, so 5mm longer ones and boom, we are in
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG1024_zpsfpytc0yf.jpg
Jest need to mount the Go-Pro now and will be sorted. ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
dolly3900 |
Posted: 19:55 - 26 Mar 2015 Post subject: |
Footage of nice camera mount
Clear and stable I think
https://www.youtube.com/watch?v=smW4ZTBl5zI&feature=youtu.be ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
ScaredyCat |
dolly3900 |
Posted: 20:35 - 26 Mar 2015 Post subject: |
Got the full door on at the mo as it was exposed totally, but with the protection of the screen, may swap for the sound enhancements of the one with the hole.
Good job really, you'd have heard me singing John Denver otherwise ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
Llama-Farmer |
Llama-Farmer World Chat Champion
dolly3900 |
Posted: 15:53 - 27 Mar 2015 Post subject: |
I did try the lazy option of leaving the door open and see how that worked.
Not a good result.
The video was still stable, but all you hear on the audio is rattle, rattle, rattle from the door flapping and the securing clip bouncing around.
Will see about finding and fitting the proper solution and see how we go from there ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
dolly3900 |
Posted: 09:27 - 13 Apr 2015 Post subject: |
Finally got around to uploading the footage of the camera with the open back to allow better sound.
https://www.youtube.com/watch?v=4SUdztB9OGw&feature=youtu.be
Not much to hear apart from the fact that there is very little wind noise.
Very happy with the effort ____________________ 2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650 |
The last post was made 9 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
