BSA B40
deeds
PostPosted: 16:12 - 22 Apr 2015    Post subject: BSA B40 Reply with quote
Not much good with the internets so if this works You should be looking a picture of a B40.https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0026_zpsfszmj18g.jpg[/img]
This belongs to My Dad who after buying and registering left it for
several years in His garage, I in a moment of masochism offered to
get it on the road.
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0029_zpspflk8onh.jpg
Its definitely better looking the further away You are.
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0030_zpsalvzpy7y.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0041_zpsfeqjqjq3.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0042_zpscif3no85.jpg
Its a unit single 350cc from 1959 one of the first 500.
The idea because of a minute budget is to get the thing running first before spending money on anything else.
At this point (about 2 months ago) we have never heard the engine run.
PostPosted: 17:20 - 22 Apr 2015    Post subject: Reply with quote
Yep get on and ride the bugger
If you go all precious and classic on it and throw money at it
it'll never see the road again.
Amal monobloc, 'mushroom' distributor, ahh that takes me back
Fag paper in points, tickling the carb, jerseys for goal posts
it were all fields round here when I were a lad....... Laughing
Matt B
PostPosted: 18:53 - 22 Apr 2015    Post subject: Reply with quote
Am jealous.
+1 what WD said Thumbs Up
Just clean it up, get it running and ride it. Don't let it become a money pit.
LongJohn22
PostPosted: 19:30 - 22 Apr 2015    Post subject: Reply with quote
Luvvit! Better put some oil in it first, I can tell there's none in else there'd be a pool of it under the bike.
deeds
PostPosted: 19:58 - 24 Apr 2015    Post subject: Reply with quote
I've several boxes of parts but I'm have trouble finding the compression!
So off with Her head.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1226_zpsu2omqybq.jpg
Looks nice and clean so there's definitely something wrong!
High compression piston from the ss90.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1228_zpsmxitzebh.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1309_zpsb0angf9l.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1310_zpshg1anvox.jpg
New ring are .013 these are nearer .040
.Chris.
PostPosted: 22:06 - 24 Apr 2015    Post subject: Reply with quote
That is absolutely lovely. Agreed about not over-restoring it, though it's a difficult one to judge. Wonder what the thing screwed into the side of the tank is?
Chris
1985 Kawasaki Z550F
Lone-Wolf
PostPosted: 22:44 - 24 Apr 2015    Post subject: Reply with quote
Wotcha.
If you mean the thing in the first picture - it's the bracket that holds the rubber knee grips in place.
Cheers.
L.W. - www.moonshiners.org.uk
deeds
PostPosted: 17:56 - 25 Apr 2015    Post subject: Reply with quote
Wolfies correct.
These were a pain to get off needing a piece of metal welding to the screws.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1247_zps0o7vdsdt.jpg
It was decided the top end was too worn so new small end, gudgeon pin, piston and rings also valves, guides and springs.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1269_zpsgg1yhtf7.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1271_zpsvnxacujs.jpg
Home made ring compressor.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1274_zps4c4fxt3z.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1276_zps0pigalmw.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1277_zpsxmlz7n0c.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1280_zpsxbfwleop.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1282_zpsudl0nd7v.jpg
Three of the rocker cover stud holes needed helicoiling so head had to come off again.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1284_zpsp2nishuf.jpg
The spark was intermitent so the old man decided on electic ignition.
This however fitted like a 6 fingered glove.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1286_zpspxhqgjzk.jpg
After slotting the holes it fitted better.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1288_zpssc1qorro.jpg
She fired up after the 5/6th kick and sounded meatier than a 350 should.Now we know the engines good the rest of it could be looked at and some of it aint pretty!
tony_d123
PostPosted: 18:33 - 25 Apr 2015    Post subject: Reply with quote
Good work there, nice to see another one being saved and getting a new lease of life Thumbs Up
Blackpool, Lancashire
Triton Thrasher
PostPosted: 18:39 - 25 Apr 2015    Post subject: Reply with quote
I know the points housing clamp is shit and all that, but I'd almost bet 10 pence that the electronic ignition will leave you stranded somewhere, more than once.
Just realised- you still need the shitty clamp!
Rrrrrrrrrrrrrrrrrr
deeds
PostPosted: 19:13 - 25 Apr 2015    Post subject: Reply with quote
Intresting you think the clamp is the weak link?
It seem pretty tight.
I wish i had taken a close up of the points,they didn'nt even line up.
Besides it'll be My Dad pushing it home Twisted Evil
deeds
PostPosted: 19:15 - 25 Apr 2015    Post subject: Reply with quote
https://i1077.photobucket.com/albums/w464/deeds18/B40/Untitled_zpsvlteulbf.jpg
Do you mean this ?
Triton Thrasher
PostPosted: 20:53 - 25 Apr 2015    Post subject: Reply with quote
I mean the fastener that looks like a side cover screw, that releases the "distributor" so you can turn it to adjust the timing.
All my C15s were a bit old and abused, but that bit was always erratic. When you tightened it up, the timing moved.
Rrrrrrrrrrrrrrrrrr
PostPosted: 22:10 - 26 Apr 2015    Post subject: Reply with quote
you mean the fag paper in the points
could just as easily be a fag packet? Laughing
That electronic ignition 'upgrade' looks a bit crude and 1960s
I'm sure that could be refined.
It was probably ln all the mags in the 60s/70s as a new
high tech improvement over points/condenser
Just looks nasty now.
Triton Thrasher
PostPosted: 22:14 - 26 Apr 2015    Post subject: Reply with quote
Mags? In B40s? In the 1970s?
lol, Einstein.
Rrrrrrrrrrrrrrrrrr
PostPosted: 22:28 - 26 Apr 2015    Post subject: Reply with quote
Don't get snotty wi me young feller me lad
I meant Magazines not magnetos
We didn't have t'internet in them days y'know
and a lot of the stuff learnt about bikes was from 'mags' like
https://www.dino.co.uk/blogbox/motor_mech/450_01_cover.jpg
you lot dont know yer born nowadays with forums web sites and such
it were all fields round here.........
Triton Thrasher
PostPosted: 12:47 - 27 Apr 2015    Post subject: Reply with quote
I can't even see it. Is it one of those mad points-triggered electronic systems?
Rrrrrrrrrrrrrrrrrr
deeds
PostPosted: 16:31 - 01 May 2015    Post subject: Reply with quote
The "distributor" clamp is tighter than the proverbial.
My worry would be the two mounting screws that hold the printed circuit board.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1285_zps8prejosd.jpg
deeds
PostPosted: 16:43 - 01 May 2015    Post subject: Reply with quote
There was a problem of the left fork being seized and the swing arm blowing about in the wind.
The wheels had to come off for new tyres so seeing as most of the bike was going to be stripped it was decided to paint the frame.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1299_zpstpdkntgx.jpg
New swing arm shaft and bearings.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1297_zpsfawcgkkl.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1296_zpsylkswuho.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1300_zpsoimnphjs.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1301_zpszewrrz35.jpg
Only then did My failing eye sight spot this.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1303_zpsutnccagl.jpg
I will point it out to you.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1302_zpsnf54cqz7.jpg
A bend.....bugger.
deeds
PostPosted: 16:54 - 01 May 2015    Post subject: Reply with quote
Can any one confirm the seat loop is meant to be like this IE appearing bent?
I've compared it with a photo on ebay which looks like it may be this shape on purpose but it was hard to tell.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1293_zpslz8ojdio.jpg
deeds
PostPosted: 18:53 - 01 May 2015    Post subject: Reply with quote
Bit of mild polishing while paint dries.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1318_zpsqbs87enc.jpg
Some one beat it to death getting kickstart off!
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1317_zps7pt7h6zw.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1319_zpsj5pwlywi.jpg
Triton Thrasher
PostPosted: 20:48 - 01 May 2015    Post subject: Reply with quote
https://i206.photobucket.com/albums/bb152/beezalex/Clipboard/C15Standard.jpg
Rrrrrrrrrrrrrrrrrr
deeds
PostPosted: 13:09 - 03 May 2015    Post subject: Reply with quote
Thanks that's the first line drawing I've seen showing the seat loop as it really looks.
New non stick slider, one on the right with snapped stud.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1311_zpswa9iyvih.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1313_zpsjgk5s7n6.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1315_zpsshduvprw.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1316_zpseypxwtjy.jpg
Sprayed along with non bent seat loop and new swing arm.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1328_zpsk9hehksb.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1327_zpsydkk9mlr.jpg
Triton Thrasher
PostPosted: 13:14 - 03 May 2015    Post subject: Reply with quote
The drawing shows the swingarm to be a bit lopsided.
Does the spindle sit ok in yours? Did the wheel look straight in the bike?
Rrrrrrrrrrrrrrrrrr
deeds
PostPosted: 17:20 - 03 May 2015    Post subject: Reply with quote
Didn't really check that closely when the wheel was in the bike, if you look at the photo of the slots the left hand one bends upward so the further back the spindle goes the more out of alignment the wheel will be.
Today's progress.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1329_zpsbpijcdor.jpg
Where the magic happens, under my stairs.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1330_zpsyaevepzb.jpg
The last post was made 8 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.16 - MySQL Queries: 17 - Page Size: 137.87 Kb
