BSA B40
Ed Case
PostPosted: 20:05 - 03 May 2015    Post subject: Reply with quote
'Stone-age' biking..........I started on things like that many years ago......best of luck you'll never be stuck for something to do !.
deeds
PostPosted: 17:01 - 04 May 2015    Post subject: Reply with quote
Thanks, I see it as a challenge, if I can get a Suzuki GS500e with 80,000 miles on the clock running like it was new the B40 should be a piece of piss. Wink
deeds
PostPosted: 17:03 - 04 May 2015    Post subject: Reply with quote
Not sure were these pieces go.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1335_zpsl1hbcjux.jpg
Triton Thrasher
PostPosted: 20:35 - 05 May 2015    Post subject: Reply with quote
That's a lot to have left over.
Rrrrrrrrrrrrrrrrrr
Triton Thrasher
PostPosted: 20:36 - 05 May 2015    Post subject: Reply with quote
Except Suzuki parts actually fit together.
Rrrrrrrrrrrrrrrrrr
Bertie basset
PostPosted: 21:16 - 05 May 2015    Post subject: well done Reply with quote
Great work so far. Will look forward to the finished result. When do you think that will be?
deeds
PostPosted: 16:21 - 08 May 2015    Post subject: Re: well done Reply with quote
My Dads going through some bad stuff at the moment so I will have to wait for one or two bits He wanted to do but next couple of months should see it back together.
I have had fun with the swing arm shaft I presume these would have been pressed in at the factory, unfortunately something I don't possess so decided to swap it for 22mm copper tube!
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1339_zpschtwnzma.jpg
The only way the shaft was going in was with a big hammer so turned a drift to save from knackering the end of the shaft.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1336_zpsg4xpdqvy.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1338_zpsevjtefc9.jpg
Job jobbed.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1340_zpsjioap8la.jpg
Bertie basset
PostPosted: 21:04 - 08 May 2015    Post subject: polishing Reply with quote
Can I ask how you got your engine ie barrels and castings so pristine? I want to do something similar with my engine
Ta. Bertie
deeds
PostPosted: 17:45 - 09 May 2015    Post subject: Re: polishing Reply with quote
Ta. Bertie
My philosophy in life is"Why stand up when you can sit down, why sit down when you can lay down." So chemicals.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1266_zpsjuhsipm2.jpg
Doesn't work like it used to, turns paint soft so you can wipe it off rather than lifting it.
So i use wire brush attached to a drill or bench grinder with wire wheel on the barrel , head and rocker which were then painted with high temp paint.
The crankcases were wire wool for ten minutes then spayed with silver paint . I hated it so was wire wooled again.The cases only took half an hour.
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0086_zpscf0jdsvs.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0083_zpsx8geentt.jpg
deeds
PostPosted: 18:12 - 17 May 2015    Post subject: Reply with quote
Forks assembled.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1351_zpsby8pbaac.jpg
Cleaning,priming,gloss and lacquer they do look a lot better irl.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1352_zpsamsjnacm.jpg
Crank cases on.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1353_zpsrsgakcje.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1354_zpscnd8gqbk.jpg
Ed Case
PostPosted: 22:43 - 17 May 2015    Post subject: Reply with quote
Doin' a tidy job there.............respect.
deeds
PostPosted: 15:13 - 18 May 2015    Post subject: Reply with quote
Many thanks.
Bru
PostPosted: 20:42 - 18 May 2015    Post subject: Reply with quote
Very interesting. One question - earlier you wrote that you did not have an original swingarm shaft, so you are using a 22mm section of copper tube instead. Is that right - just a copper tube to join the swingarm to the frame?
Codge
PostPosted: 20:51 - 18 May 2015    Post subject: Reply with quote
fantastic thread Very Happy
Prevarication and procrastination are my worse enemies
Matt B
PostPosted: 09:15 - 19 May 2015    Post subject: Reply with quote
The shaft is in there, driven in with a specially made drift. I would guess the copper was just to hold it in place.
22mm copper tube would last until you sat on it Shocked
deeds
PostPosted: 19:44 - 24 May 2015    Post subject: Reply with quote
Yep MattB's right, I was just using it to hold the swingarm and the shims (you can just make out in the pics) in place.
Shreeve
PostPosted: 21:27 - 24 May 2015    Post subject: Reply with quote
I want my engine that shiny but the amount of time it takes... urgh.
Very nice job so far, looking forward to the finished beast!
Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4
deeds
PostPosted: 18:42 - 25 May 2015    Post subject: Reply with quote
If you have the right tools like bench grinder and polishing mops and don't mind getting filthy it takes/ took me about three hours to do the whole engine.
deeds
PostPosted: 13:54 - 07 Jul 2015    Post subject: Reply with quote
Death stopped play for awhile.
So did things like head bearings taking a month to sort out and buying the wrong rims and getting sent the wrong spokes ect.
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1380_zpseephshlh.jpg
Pulling forks through yoke
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1388_zpsbwcaqscz.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1393_zpscwecsf6i.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/DSCF1371_zpscgvfnrlg.jpg
https://i1077.photobucket.com/albums/w464/deeds18/B40/IMG_20150619_142213891_zpsjqoog0wq.jpg
paddlesat16
PostPosted: 15:13 - 25 Jul 2015    Post subject: Reply with quote
Excellent project Very Happy
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
deeds
PostPosted: 15:08 - 10 Sep 2015    Post subject: Reply with quote
Many thanks, a little update of progress.
I've been putting off the painting of tank and panels because I do so little spraying with compressor I'm never sure of the outcome.
Had to get on with it as autumn is here so cant rely on the weather, here's the outcome.
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0122_zpseuw70cb3.jpg
and a bit more progress with the chassis.
https://i1077.photobucket.com/albums/w464/deeds18/B40/PICT0121_zpsjzcd92sa.jpg
The last post was made 8 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.23 - MySQL Queries: 17 - Page Size: 115.76 Kb
