Exsperienced diagnostic help please!
epicurius
PostPosted: 18:10 - 16 May 2015    Post subject: Exsperienced diagnostic help please! Reply with quote
Hi, have stripped the missus Honda melody deluxe 82' (50cc 2 stroke auto choke) its belt was worn down to nothing. cleaned whole scooter, and engine and carb, and exhaust.. . bla bla. (didn't remove oil pump or open gear box) rebuilt, have had running (now goes faster, tho acceleration seemed low) played with the carb before putting new belt on, big mistake, cant get it right now.
It will start ok when warm but doesn't like to start in the first place, I have to fiddle the screws about with little clue which does what, how the hell do I set it up right?
So.. . it runs at 30mph instead of 24mph but I cant get it to reliably start? battery's not great, but I have trickle charger attached while trying to get the carb set so it will, both start from cold and have a sane idle speed (i think setting the idle real high is what gets it started but the acceleration screw did seem to affect the idle speed too so due to the manuals and advise i have found thus far being shaky on specifics as to which is which and what to do with them).
I believe the bottom left one is the air mix and the top one the idle.. . (and the very bottom is the float drain, which flows happily as does the oil to the pump).
Any advise that doesn't cost allot of money before I give in and take it to the garage would be greatly appreciated!
andym
PostPosted: 18:39 - 16 May 2015    Post subject: Reply with quote
Should be posted in the Workshop section, but I'm sure 1 of the mods will come along and shift it.
Anyway a page that might help you out a bit: https://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm
Also, if you don't know what you are doing then it's best to ask someone before attempting the job yourself
epicurius
PostPosted: 19:33 - 16 May 2015    Post subject: Reply with quote
haha now i cant delete it! please do moderators. newb apologies Confused
The last post was made 8 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.97 - MySQL Queries: 17 - Page Size: 37.85 Kb
