System of a Clown |
System of a Clown Two Stroke Sniffer
dangerousdave |
dangerousdave Traffic Copper
System of a Clown |
dangerousdave |
Posted: 21:33 - 20 Sep 2015 Post subject: |
[quote="System of a Clown"]
maybe it hasnt run for a while , seems odd to have broken like that, cant imagine what would cause that ?? ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
Just_James |
Just_James Could Be A Chat Bot
Posted: 21:52 - 20 Sep 2015 Post subject: |
Some epic wiring you've discovered there! I've done worse myself in the past though
Following this with great interest, really liking what you've done so far and am intrigued with the turbo side of things
My 2p on the plastics, I'd personally be sourcing solid 2nd hand originals in the right colours. Even if they're heavily scuffed and scraped they can be sanded and polished back to a good finish.
I have a pet hate for painted plastics on trail bikes, they are generally a different type of plastic that is 'oily' and are supposed to flex. With all the best prep' in the world you can't expect any paint to stick to them for any length of time other than perhaps for 'show' conditions.
I don't have any personal experience of aftermarket plastics but would expect them to be quite flimsy. Maybe a viable option depending on just what you want to do with the bike and how you want it to look though? ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
dangerousdave |
Posted: 18:46 - 21 Sep 2015 Post subject: |
Just_James wrote: |
I have a pet hate for painted plastics on trail bikes, they are generally a different type of plastic that is 'oily' and are supposed to flex. With all the best prep' in the world you can't expect any paint to stick to them for any length of time other than perhaps for 'show' conditions. |
Thing is, a lot of plastics are sprayed anyway from the factory. The brand new OEM fairing parts on my Thunderace were visibly sprayed and then a gel coat applied. In areas where there are rubs or chips its possible to see the layers of paint and gel coat.
Somebody sprayed my KMX rear panels. I wouldn't have known, the only reason why was because there were some chips in it, and on the exhaust side, the paint began to bubble under the heat of the standard silencer. I changed them for this reason, but apart from that they were great.
Problem is the price of OEM plastic. I got lucky and picked up some rear numberboards off tinternet for about 25 quid. Mind you they were scratched up and looked a state. Some sanding and polishing and they look half decent again. However took me ages to find those panels, as most of them get smashed to bits in off-road use.
Other people have used KX plastics but its not for me, dont think it suits these bikes at all, part of the charm is their original look. KX numberboards go on, as well as KX rear fenders, the seats can be shaved down to take a more slippery KX set cover. However then the tank doesn't look right. Try fitting a KX tank onto a KMX top tube. It wont happen mate. Totally different beasts, the KX's used perimeter frames from early 90's.
There are some new KMX plastic kits from Japan floating around the net, but they want silly money for them IMO.
https://www.ebay.co.uk/itm/KMX-125-200-Complete-Plastic-Set-Fenders-Shrouds-Covers-Fairings-Etc-/271986600147?hash=item3f53aa28d3
A pair of rear numberboards are around £70
https://www.ebay.co.uk/itm/KMX-125-200-Side-Fairing-Plastic-Available-Color-White-Black-and-Green-/271968080546?hash=item3f528f92a2
Depends how much money you want to spend, if you want to come in at under £750 for the bike then i'd say get the sandpaper, heatgun and polish out and get to work on your plastics ... ____________________ 1988 Kawasaki KMX 200
stevo as b4 |
Posted: 22:58 - 21 Sep 2015 Post subject: |
I agree Dave. I also saw those OEM plastics set from Japan for £300, and was in two minds about their value.
Sure it's a lot of cash to lay out on new plastics, probably less though than ordering each piece from a Kawasaki dealer here though.
I guess it depends on how battered or really unusable your old plastics are? if they are smashed/holed or cracked in several places then repair will be time consuming if you can do it yourself, and expensive if you pay someone to do it.
I think having non painted plastics for a pure off road bike is a good bet, but plastics can be painted just as on a road bike I suppose too. All my KMX 125 plastics were re-painted at a car body shop and they came out lovely, but I'm not sure they will be worth it for off road use only?
My 200's black plastics are just all badly scratched and faded, but I will try polishing them and maybe the heat gun trick if required, but then as long as that bike is all the same colour the finish won't matter a bit as I only want to get it really muddy! |
dangerousdave |
Posted: 23:15 - 21 Sep 2015 Post subject: |
stevo as b4 wrote: |
yes i think for off-roaders they only get scratched up so fitting new plastics kind of stops the fun & introduces anxiety of actually dropping the bike ... its going to happen, especially for any competition use.
fix them up as best you can with minimum expense, then ride !! ____________________ 1988 Kawasaki KMX 200
System of a Clown |
dangerousdave |
stevo as b4 |
Posted: 19:56 - 22 Sep 2015 Post subject: |
Nice work!
I've got to say I think that sits much better with the 17"wheels and the Pulse forks than I thought it would. Yeah sure it will be lower, but it does not look drastically so, which is what I think it would if you just fit 17" wheels to a KMX with std forks.
I like KMX's to look like KMX's too!
If the front mudguard is intact and only scuffed or scratched, then it's still good to re-use and re-paint I'd say. The tank and tank shroud along with that front fender could be prepped and sprayed to look very nice indeed IMO. If all you need is a new/good used rear guard and two side panels then you've got off lightly I'd say on a 24year old KMX.
Also if you go with painting the existing plastics you can have the option of easily masking for different colours or stripes to make a 2 or 3 colour paint scheme or just even to add some pin stripes etc?
Your KMX will be a nice tidy Supermoto, and so that's why I think paint is right for your bike, as it's not going to get all muddy and scuffed up (I hope not anyway!)
Oh and a reasonably smart paintjob is almost essential if you want to really show off the boosted frankenstien technical goings on inside the frame rails! |
System of a Clown |
Posted: 20:03 - 22 Sep 2015 Post subject: |
dangerousdave wrote: | looking good!! |
Cheers!!!
stevo as b4 wrote: | Nice work!
Definitely going to powdercoat the frame - dunno what colour now!
I'm bound to fall off at some point (confession time - I don't have a bike license!! I've done a bit of moto x and I've ridden the length of Vietnam on a very crappy Honda!!) so I don't want to spend a fortune on the plastics!
It's not going to be a 100 point resto, but I'm going for high end useable
I think the turbo will be a way off, but one day..... |
dangerousdave |
stevo as b4 |
dangerousdave |
stevo as b4 |
System of a Clown |
System of a Clown |
System of a Clown |
Posted: 20:17 - 29 Sep 2015 Post subject: |
Done bugger all on the bike apart from source a good used suspension linkage - lack of work has been due to to troublesome vintage Volkswagens and their resistance to working
However I have received a reply from the DVLA, not the V5 I was hoping for, but I'm guessing it's legit?
https://i245.photobucket.com/albums/gg63/cpopaul/image.jpg1_1.jpg |
dangerousdave |
System of a Clown |
dangerousdave |
Sean.S |
Sean.S Trackday Trickster
Posted: 09:11 - 02 Oct 2015 Post subject: |
after all the effort your going to, why have you put cheap chinese wheels and chinese forks on?
by the way chinese tyres are lethal, change em mate or be careful out there when it starts to rain |
System of a Clown |
Posted: 22:00 - 06 Oct 2015 Post subject: |
dangerousdave |
The last post was made 8 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
