Sean.S |
Sean.S Trackday Trickster
Posted: 22:17 - 16 Nov 2015 Post subject: |
VFR Vince |
VFR Vince Two Stroke Sniffer
Sean.S |
Sean.S |
Suntan Sid |
Fladdem |
Fladdem World Chat Champion
Posted: 20:35 - 09 Dec 2015 Post subject: |
The nipple snapped off on my rear caliper on my CRM when I was trying to bleed the brakes after I replaced the Master Cylinder when the seal blew and I lost all my fluid. It was cheaper to get a second hand one than a rebuild kit.
I then went to drill the snapped nipple out, and snapped the drill bit off in the the caliper.
I then ended up just turning the caliper upside down and putting some wood between the pads and bleeding out the banjo bolt. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Sean.S |
Posted: 15:56 - 10 Dec 2015 Post subject: |
I got the bleed nipple out this morning and ive taken the calipers down to the powdercoater for paint. Thanks for the tips |
Sean.S |
Sean.S |
Posted: 14:45 - 25 Dec 2015 Post subject: |
Sean.S |
Fizzer Thou |
Sean.S |
Fizzer Thou |
Posted: 00:39 - 06 Jan 2016 Post subject: |
I did think about removing the gaitors from the forks but decided that if I want to change the wheels back to the knobbly tyred ones then I would have to refit the other dirt bike stuff as well.
I bought the wheels from a friend of a friend for £200 and only came with the rear sprocket.The hubs are Talon and the rims are anodised Morad,which is a far better finish than stove enamelling or plastic coating.
The front disc was £95 from Race-Spec and I had a spare rear disc in the shed that was originally meant for the dirt bike.The tyres that came on the wheels were worn out Dunrops but they protected the rims until I was ready to replace those with new Pirelli Diablos.
I have fitted the largest front sprocket that would fit and while Renthal did not sell one then Talon Engineering had the size that I needed on their shelf.Top people ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
Sean.S |
Posted: 01:34 - 06 Jan 2016 Post subject: |
It would look better with the gaitors left on i think... It sounds like youve run out of things to do to your bike, sometimes when that happens i think i look for parts to change on my bike just for the hell of it
The reason i asked about the wheels is because yours look the same as mine (or similar at least) just in a different colour. I dont know what make my wheels are because they were on the bike when i bought it, but the red anodising is starting to fade and wear off the spokes so i would like to buy new wheels at some point
Sean |
Fizzer Thou |
Sean.S |
Posted: 15:09 - 07 Jan 2016 Post subject: |
Fizzer Thou wrote: | New SM wheels are expensive to buy,especially if you buy them as complete wheels from somewhere like Talon,Central Wheels etc.
A friend did their XR250R as a Supermoto conversion by buying some spare wheels,dismantling them and sending off the OEM hubs to be painted and reassembled with new stainless spokes and painted ally rims.This would be a cheaper option.
But if your hubs are anodised they can be redone in a different colour.I have had some red bike parts redone in black,which does not fade like red plating seems to,which turns to pink after a while.If your rims are painted they can be shot blasted and repainted. |
The hubs are black and havent faded, so i could have them rebuilt onto new rims if it worked out cheaper than buying new wheels. However, from what i can tell it probaby wouldnt be once the cost of labour and new spokes are factored in
the rims are anodised too and im not sure how i like the idea of having the rims powder coated, if powdercoating on top of an anodised surface is even possible...? i'll have to keep an eye on ebay and gumtree i think, to see if i can find a cheap set
ive just noticed you have what look like rubber frame protectors on your bike, do you think i could get some to fit my CRM? the alloy ones are what i would ideally like, but they are like hens teeth for this bike
sean |
Fizzer Thou |
Posted: 00:13 - 08 Jan 2016 Post subject: |
They are not rubber frame protecters but plastic.Polisport I think.But I bought them years ago,with the intention of making some ally plate frame protecters at some time in the future.It would not be difficult if you start of with a cardboard template and then cut the plate with a bandsaw.
If you go to 'goggle images' and type in 'CRM 250 SM',there are some good examples ____________________ Just talk bikes.What else is there?
Sean.S |
Sean.S |
Posted: 21:36 - 14 Jan 2016 Post subject: |
Sean.S |
Sean.S |
Sean.S |
Sean.S |
Posted: 21:05 - 03 Feb 2016 Post subject: |
Sean.S |
Posted: 12:57 - 04 Feb 2016 Post subject: |
Sean.S |
The last post was made 8 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
