Back with a free bike. GK75a
Fazer Tom
PostPosted: 22:32 - 15 Nov 2015    Post subject: Back with a free bike. GK75a Reply with quote
After not having a bike for 2 years, My father in law has just given me this, he planned to turn it into a track bike but he can't be arsed.
I'm gonna be just getting it going as cheaply as possible. Tart it up and stuff.. Anyway, pics.
https://s11.postimg.org/mtj0dv8xf/20151115_141047.jpg
Its complete and was told it was running when it was stored (in a leaking shed 10 years ago). Carbs are seized, no idea if the engine is.
https://s29.postimg.org/eqgnq6013/20151115_141210.jpg
Very Happy
(CBT 01/07/11. Theory, 21/05/12. MOD 1, 01/06/12. MOD 2, 3/08/12)
Past: (1981 CG125) (1992 ZZR250 x2) (1976 KZ400) (1993 400 Superfour) (2002 Triumph TT600) (1998 Fazer) (2001 CCM 636) (2000 CCM 604) (2007 Kawasaki Z750) (2005 Husqvarna SM450R) Current: (1989 Bandit 400)
Rob Fzs
PostPosted: 23:23 - 15 Nov 2015    Post subject: Reply with quote
gk75a the fancy way of saying bandit 400 heh
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
orac
PostPosted: 23:32 - 15 Nov 2015    Post subject: Reply with quote
mines been around the clocks and gets ridden pretty much every day.
if you ride it hard, keep an eye on oil levels, it seems they do use oil due to a design flaw in the piston/piston rings.
front brake bobins tend to go slack as well.
good luck with the carbs, spars for those are tricky to come by.
plenty of other engine casing fit if you drop it though.
digital ignitor do have a thing of going up in smoke at times too.
fuse box sit in a bad place and the contact tend to corrode and cause issues.
bandit 600 speedo cable works fine, same as early rear shocks
Fazer Tom
PostPosted: 00:14 - 16 Nov 2015    Post subject: Reply with quote
Sounds better Razz
Not touched it yet, gonna bring my tools after work tomorrow and see if I can get it running.
Fazer Tom
PostPosted: 00:21 - 18 Nov 2015    Post subject: Reply with quote
Has anyone got a wiring diagram for this? I've found a few but they are all slightly different, this is a 1989 but can't find a diagram for that model year. Thanks
redeem ouzzer
PostPosted: 01:15 - 19 Nov 2015    Post subject: Reply with quote
Carbs will need rebuilding, use Litetek seal kit and make sure they are surgically clean. Also will probably need plugs as well to even have a chance of starting.
GK73A carb tops liberate more power.
orac
PostPosted: 15:25 - 21 Nov 2015    Post subject: Reply with quote
I only have 92-99.
is it helps my bike doesn't match any of the wiring diagrams either and so far as I can tell is a 94.
but the manual has some wiring diagrams titled as "other models". it would be helpful if you new the country of origin. twin disk models were never imported to the UK by Suzuki as its definitely a grey import.
What is it that you are having issues with?
Fazer Tom
PostPosted: 21:13 - 21 Nov 2015    Post subject: Reply with quote
Is a Japanese model, the cdi has the green wire for the 112mph restriction.
The wiring is sorted, had to strip back the loom and sort it then retape it all. It was mainly previous owner bodges.. The usual spade connectors and twisted wires, wrong colours etc.
Just waiting for a rebuild kit for the carb, but might need some new carb tops as they are cracked.
P.
PostPosted: 21:46 - 21 Nov 2015    Post subject: Reply with quote
Possibly one of the worst bikes I've owned and ridden. I'd not be able to score it less than a GS500 but it comes close. I'd rather ride a mobility scooter.
Hope the build goes well.
Fazer Tom
PostPosted: 22:24 - 21 Nov 2015    Post subject: Reply with quote
Yup, read that it's not amazing but for free, I aint gonna complain.
redeem ouzzer
PostPosted: 11:29 - 22 Nov 2015    Post subject: Reply with quote
Good brakes and chassis, crap build quality, slow compared to it's GK73a brother. Mine was unreliable and tried to burn me alive in a filling station which was the last straw.
hmmmnz
PostPosted: 21:20 - 22 Nov 2015    Post subject: Reply with quote
its funny, the gs500 and bandt 400 are 2 of the most fun bikes ive ever owned,
loved the revvy-ness of the bandit, and the bomb proof engine of the 500 was good for winter reliability.
horses for courses.
the humans are dead
I kick arse for the lord
P.
PostPosted: 21:31 - 22 Nov 2015    Post subject: Reply with quote
Bomb proof engine Laughing
I've seen 4 break. Out of 5. The last one came broken.
orac
PostPosted: 12:19 - 23 Nov 2015    Post subject: Reply with quote
horses for courses.
Yep my gs500 just kept going, think its still about now, sold it due to needing a timing chain. My current 400 is coming up on 110000km and sees the red line almost daily.
The 400 only let me down once, 200 miles from home. The gs500 never let me down. Both bikes use oil, specially when ridden hard, keeping an eye on the oil level is essential. Saw a guy go through 2 engines on a gs due to not keeping the oil topped up - this is purely a user issue and really the bikes fault.
hmmmnz
PostPosted: 20:20 - 24 Nov 2015    Post subject: Reply with quote
i bought mine for £500 with 50000miles on it, was at 85000 miles when i gave it to a work mate when i went back to new zealand, he still has it and its still running fine.
never had a single mechanical issue with it at all, had to repair wiring weekly with all the salt corroision, only left me stranded once when a mis-used chain broke on me.
one of the few bikes i'd own again,
the humans are dead
Fazer Tom
PostPosted: 23:57 - 22 Feb 2016    Post subject: Reply with quote
Not had chance to do anything with the bike at all until the last few days, took the tank and side panels to work.
Upon handing the tank I discovered it had a leak. Only to find this monstrosity. A piece of tin stuck on with liquid metal.
https://i.imgur.com/CrEXKeh.jpg
Thought it could be made into a decent repair after a quick zap with the welder, removed the plate to clean up the steel for welding to find it was made from an old coke can Evil or Very Mad
Underneath
https://i.imgur.com/ffTkDHO.jpg
https://i.imgur.com/IBowPjE.jpg
Hopefully should have time to weld it up and get the tank in primer tomorrow.
Fazer Tom
PostPosted: 20:58 - 23 Feb 2016    Post subject: Reply with quote
Welded the tank today, not the prettiest but the seat hides most, what the seat doesn't hide a tank protector will.
https://i.imgur.com/hcf26XY.jpg
https://i.imgur.com/nhGO5Ia.jpg
https://i.imgur.com/x7VKXcg.jpg
Swaggy.
Fazer Tom
PostPosted: 18:55 - 15 Mar 2016    Post subject: Reply with quote
Can only do bits of the bike as of when there is a few hrs spare at work, so it's been slow. Took a proper look at the back of the tank and realised that it looked a bit shit, so rubbed down the back and ran a skim of filler over and went over the tank again with some high build primer.
https://i.imgur.com/Pnb1L5V.jpg
https://i.imgur.com/DvZvcnZ.jpg
https://i.imgur.com/OdkZXcl.jpg
https://i.imgur.com/wErXtYQ.jpg
There is a gap of 182 days between these two posts...
Fazer Tom
PostPosted: 04:09 - 14 Sep 2016    Post subject: Reply with quote
Does anybody know if gsxr400 heads will fit the bandit head. None vvti model.
Been busy with family life and work so decided to get my brother on stripping the bike down for me so I can work on bits at a time. Big mistake, he's butchered the exhaust ports, mainly the raised bosses where the flange bolts to, ones sheard off. Took the engine to work and stripped the head off, I was pleasantly surprised at the condition of the cams and how clean the engine was inside.
https://i.imgur.com/Fn9C1VC.jpg
https://i.imgur.com/LRi2IFn.jpg
https://i.imgur.com/UY3k64N.jpg
Might be able to salvage the head but cba fucking about drilling and tapping if I could just get a head cheap enough.
nitrosurf
PostPosted: 07:03 - 14 Sep 2016    Post subject: Reply with quote
I thought you would have had difficulty with engine mounts due to the different frame types but apparently:
https://forums.banditalley.net/index.php?topic=9365.0
I guessed the cams would be a different profile, and carb sizes were different between some models but other than that they seem the same...
Join up to some GSF/GSX-R forums, but keep us posted on here as it's interesting.
"Multiple exclamation marks," he went on, shaking his head, "are a sure sign of a diseased mind."
P.
PostPosted: 07:57 - 14 Sep 2016    Post subject: Reply with quote
Like most Bandit 400s it's really not worth the aggro. It'll run fine for 3 days then break.
Fazer Tom
PostPosted: 12:48 - 14 Sep 2016    Post subject: Reply with quote
Gone over the head and it's probably best to get a new one. Everything else looks okay though apart from one rocker.
https://i.imgur.com/mRhOtjJ.jpg
This head is a 1990 gsxr. Look at the rockers compared to mine below, this head is cheap as chips but unsure if the rockers will swap over. Anyone have any ideas?
https://i.imgur.com/MGRKrqC.jpg
redeem ouzzer
PostPosted: 14:47 - 14 Sep 2016    Post subject: Reply with quote
That head isn't from 1990 GSXR if it's got locknut tappets. The GK76 models from 90 to 96 run shims.
Be a REAL MAN!
Fazer Tom
PostPosted: 20:12 - 14 Sep 2016    Post subject: Reply with quote
Yeah the one for sale is shimmed. Are the valve spacings all the same etc? Could just transfer everything from my head over so it would be lockouts.
Fazer Tom
PostPosted: 19:06 - 27 Dec 2016    Post subject: Reply with quote
Ended up just drilling and tapoing new studs into the head, also got a new follower. I dont have any ohots as i forgot as i was fitting it. It seems to be worn in the same place as mine, although nowhere near as bad and the plating it still on.
Really dead at work so had the opportunity to take some bits in. The back wheel was shagged, its not the original wheel as its factory white that someone has just sprayed black over, no primer or anything. Front was ok, still gave it lick of paint though. Yes, the tyres will be getting changed.
https://i.imgur.com/Jirdvwj.jpg
https://i.imgur.com/HgaIFlI.jpg
https://i.imgur.com/yFhhwu1.jpg
Forks wasnt bad at all but gave them a coat too.
https://i.imgur.com/uYlPhnM.jpg
All the disc bolts played nicley apart from one which was seized and rounded. Had to cut a flat into it and hammer a t45 torx into to. Must remember not too use my ratchet as a hammer though.
https://i.imgur.com/88jZhZM.jpg
https://i.imgur.com/CbOKukk.jpg
Tried some electrosis too on the remaining front dosc bolts. Its still bubbing so no pics of the finoshed result yet.
https://i.imgur.com/SVZLfl5.jpg
The last post was made 7 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.09 - MySQL Queries: 16 - Page Size: 140.72 Kb
