Author |
Bugsy |
Bugsy Borekit Bruiser
Back to top |
Matt B |
Matt B World Chat Champion
Back to top |
Bugsy |
Posted: 14:41 - 20 Dec 2015 Post subject: |
Back to top |
Bugsy |
Back to top |
stevo as b4 |
Back to top |
Sean.S |
Sean.S Trackday Trickster
Posted: 22:54 - 21 Dec 2015 Post subject: |
Looks like its been well kept, is that wet patch underneath a leak?
Sean |
Back to top |
Bugsy |
Posted: 23:43 - 21 Dec 2015 Post subject: |
Back to top |
Bugsy |
Posted: 00:00 - 22 Dec 2015 Post subject: |
Back to top |
Bugsy |
Back to top |
stevo as b4 |
Back to top |
Bugsy |
Posted: 17:14 - 23 Dec 2015 Post subject: |
Have had caustic soda in exhaust so she should be clean as a whistle,
Will probably grab a spare expansion chamber and play about, trying to get bike back on road asap as im doing a 4 mile commute and its not great for a deisel car.
Definately a lot more 125's about and spares can only think how much cooler they run should imagine they rev up nicely
Bit like your mint white 125, mines too good for any serious trail stuff.
Probably make up a 125 for that, like yourself for titting about on .
Would be interesting putting a different carb on and different bits
Ive got my kmx tagged onto the street triple insurance do you know if they can go on a classic policy? |
Back to top |
stevo as b4 |
Posted: 18:55 - 23 Dec 2015 Post subject: |
Good luck with the re-build, your making fast progress so far anyway. At least a fully re-built sorted bike will make a great fun commuter machine.
If your intention is road use, then I would look at firming up the damping in the front forks, and maybe using thicker oil and or spacers? The front brake wants to be in good order, and a decent disc, sintered pads and a stainless line makes it just about acceptable for high speed use.
I think my little 125, will be more sensible while it's still 124cc, I've got a spare reconditioned 200cc head and cylinder to go on it eventually that's been tuned and ported with head work etc.
Insurance wise it's normally either 15 or 20years old to qualify for a classic policy, so you'd need to check with your insurer. It might be cheaper or more expensive to try and insure both bikes on one policy and sometimes classic policies don't allow other bikes to be added, so ring up and see which is the best way to go.
Often you don't need or get any NCB discount on classic policies, but then you might be mileage limited on some of them though.
My 125 is touching 30years old now, I can't believe I own a 30year old bike and I was 8 when it rolled off the assembly line at Akashi. |
Back to top |
Bugsy |
Back to top |
Bugsy |
Posted: 11:05 - 03 Jan 2016 Post subject: |
Back to top |
oberonspacefr... |
oberonspacefr... Nova Slayer
Back to top |
Bugsy |
Back to top |
Bugsy |
Posted: 22:37 - 09 Jan 2016 Post subject: |
D day tomorrow,carb cleaned and rebuilt, tank flushed,new throttle and clutch cable,oil pump reset.
Starts and runs really well on idle,
Awaiting a dep silencer.
Also a twin air filter on its way.
Any one have any experience with?
Kips spacer plate?
Boysen race reeds?
Re jetting or maybe moving clip down one notch ?with dep and twin air mods etc? |
Back to top |
dangerousdave |
dangerousdave Traffic Copper
Posted: 16:52 - 10 Jan 2016 Post subject: |
Bugsy wrote: | D day tomorrow,carb cleaned and rebuilt, tank flushed,new throttle and clutch cable,oil pump reset.
Kips spacer plate?
Boysen race reeds?
KIPS spacer plate and the Boyesen reeds make marginal differences.
Nothing massive. Twin air filter a better filtration system than stock so some protection for the motor, help the engine breathe a bit better.
None of these mods will make much of a difference to the jetting needed. However, each bike is slightly different.
Best thing I found is experimentation, raise/lower the needle clip. Buy a few main jets, try a couple higher, a couple lower. That way you can work out which combination works best for your setup.
I use a V-Force reed block and reeds, KIPS plate, stock expansion, KX silencer, twiner filter, tuned cylinder, and I went down to stock main jet (112.5), 1 smaller pilot and needle clip varies due to outside temperature. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
Back to top |
Bugsy |
Back to top |
Bugsy |
Back to top |
dangerousdave |
Posted: 00:23 - 21 Jan 2016 Post subject: |
here's a quick guide to jetting
https://all-offroad.com/main/2014/03/overview-jetting-101/
needle clip position doesn't make make any difference on a closed throttle.
also bear in mind its bloody cold at the moment, this affects the air density, compared to a warm day in the summer. this will affect your settings also. ____________________ 1988 Kawasaki KMX 200
Back to top |
Bugsy |
Back to top |
Vincent |
Vincent Banned
Posted: 15:16 - 22 Jan 2016 Post subject: |
It wouldn't cost much to respoke the wheels......if you don't like the covers that is....just snip one at a time and replace ____________________ Space Is Deep |
Back to top |
Bugsy |
Posted: 09:51 - 24 Jan 2016 Post subject: |
Back to top |
The last post was made 8 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
