Bridgehouse |
Bridgehouse Renault 5 Driver
Posted: 20:48 - 04 Mar 2016 Post subject: |
Have been working away for the last few days, so have only managed to get back to this today - had a few hours this afternoon/evening to have a look at it again.
First job was that cylinder head and the cylinder - and the fact that they were stuck fast.
Decided to be logical about it and had a good look around to see what was what.
Well, it's off:
https://i.imgur.com/Zg7L2mT.jpg
How? I hear you all cry in desperation.. (hah).
Well, there's these little tabs - sort of raised bits right in the middle front and back which are strong enough to get a decent flat head screwdriver on, and with a very very light pressure you can just get enough leverage on to break the seal holding the two dowels in:
https://i.imgur.com/6pWwoCV.jpg
https://i.imgur.com/ZEBC7ip.jpg
If anyone is attempting this and the head is stuck fast - have a look for the raised bits and give it some very gentle leverage. Gasket came off as one and the mating surfaces are untouched.. Phew!
Next job was to take the pistons off. There is one split clip missing - I reckon I'm going to find it in the crank case:
https://i.imgur.com/fRnFPPL.jpg
More bits then came off - connecting rod was locked off with a 'stout bar' (as per haynes) and a gear puller used to pop the alternator rotor off:
https://i.imgur.com/Tpytf6J.jpg
Clutch cover was then popped off - needed some liberal rubber mallet to release the gasket on it.. Then out came clutch spider, springs etc..
https://i.imgur.com/OGVnJlw.jpg
All was looking pretty good:
https://i.imgur.com/ZMSL0FQ.jpg
And then I noticed this abortion of a mess:
https://i.imgur.com/x148RL0.jpg
That's the castellated retaining nut for the clutch basket. Yeah, right - castellated. Mutilated more like.
Tomorrow is going to start with a head scratch and trying to work out how to get that bugger off after it was utterly mangled when last put on..
Hope you are all enjoying the ride! ____________________ 2015 Triumph Street Triple - 2015 Honda CB500F - 1976 CB400 Four (Stripped - and undergoing restoration) |
chickenstrip |
chickenstrip Super Spammer
Posted: 21:18 - 04 Mar 2016 Post subject: |
Bridgehouse wrote: |
You always get at least one pingfuckit with every engine strip ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
Pete. |
Pete. Super Spammer
Posted: 21:27 - 04 Mar 2016 Post subject: |
Pistons are showing no sign of blow-by yet there's heavy staining on the head. I wonder if the 50 on the pistons means it's been over-bored 0.5mm? ____________________ a.k.a 'Geri'
Bridgehouse |
Bridgehouse |
Bridgehouse |
Posted: 22:13 - 10 Mar 2016 Post subject: |
Although I doubt anyone has missed me posting, apologies for the gap - I've been rather busy, and I've been waiting for Mr Postman to deliver one of these:
https://i.imgur.com/8En8Vgm.jpg
It's the first tool I've had to buy for the CB400f - a special socket for the clutch basket nut, and spanner to hold the basket whilst trying to remove the nut. If you remember, the nut itself is somewhat shagged - but it was worth getting the tool - came off like a dream and I can use it to get a new one back on!
Here's the offending item:
https://i.imgur.com/LjxBRjQ.jpg
And once off, I could disassemble the clutch, and the gear change linkage with some ease. It's a bit fiddly to get everything off, but nothing that 45 mins and some patience didn't stop:
https://i.imgur.com/q0AR4cX.jpg
And that leaves the side of the casing free for the next stage - at the weekend I'm going to split the casings.
https://i.imgur.com/06DNywL.jpg
Had a bit more time left tonight, so started to strip the front wheel. The tyre was so old that there just wasn't any play left in it. Every time I tried to get an iron onto it, the rubber cracked and split. Had to resort to a hacksaw to get the bugger off.
Anyway, once off, it was a simple case of getting the spacer off and the spindle out, removing the disc, then knocking off the bearing cover:
https://i.imgur.com/6u08vBx.jpg
Leaving me with the bearings to do next:
https://i.imgur.com/eEAGrd3.jpg
On the other side there is a castle nut that holds the bearing in and the rubber seal as well. I could invest in something to get it out, or I could knock it out with a drift. It's very soft aluminium alloy so if I knock it out it will be wrecked. I'll decide tomorrow.
https://i.imgur.com/pYaZIPN.jpg
As an aside - remember I said I found some bits in the sump? Well I drained it out tonight, and here they are. Anyone want to guess what they are?
https://i.imgur.com/o2Sh3ar.jpg ____________________ 2015 Triumph Street Triple - 2015 Honda CB500F - 1976 CB400 Four (Stripped - and undergoing restoration) |
Pete. |
Pete. Super Spammer
Posted: 22:23 - 10 Mar 2016 Post subject: |
Looks like the neutral light switch pin. ____________________ a.k.a 'Geri'
Bridgehouse |
S1417 |
S1417 Nitrous Nuisance
Posted: 00:07 - 11 Mar 2016 Post subject: |
Enjoying this, looks like good work so far |
Ed Case |
Ed Case World Chat Champion
bladeblaster |
bladeblaster Trackday Trickster
Posted: 16:37 - 11 Mar 2016 Post subject: |
great thread, keep it up |
Shaft |
Shaft World Chat Champion
.Chris. |
.Chris. World Chat Champion
Posted: 22:13 - 11 Mar 2016 Post subject: |
A new one is just over £7 from David Silver. Looks like it screws in so you might need the tool to put a new one in anyway.
Keep up the good work ____________________ Chris
1985 Kawasaki Z550F |
Shaft |
Posted: 01:10 - 12 Mar 2016 Post subject: |
So you stick your chunky needlenose pliers in and screw it back the other way.
Not sure why it uses a press in bearing one side and a retainer on the other, is it a preloaded taper bearing?
If it is, the specified torque setting should tell you if you can virtually spin it out by hand, or need a special tool. ____________________ Things get better with age; I'm close to being magnificent........
Fizzer Thou |
Bridgehouse |
Bridgehouse |
Suntan Sid |
Posted: 07:08 - 05 Apr 2016 Post subject: |
There is a similar "nut" on the rear wheel of my XL125.
To get mine out and back in I took a length of flat steel bar, drilled two holes in it, tapped the holes and screwed in two, appropriately sized, bolts and used that.
The "nut" has a very fine thread on it, if it's been in there for a long time you'll need a lot of force to get it moving. I used a meter long bar to get plenty of leverage, it worked for me.
I don't think I'd have got it out with pin pliers mentioned above! ____________________ "Everybody needs money, that's why they call it money!" |
The last post was made 8 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
