WildGoose |
WildGoose White Van Man
Posted: 19:23 - 25 Aug 2004 Post subject: "Put Everything Back" Day |
right, the bike has been sitting idle, waiting for bits for a while now, the shipment arrived late last night, and the chaos continued
graeme france the guy i get my 400 bits off, helped me change the shock, in about 11.5 mins, it was quite inspiring to watch, especially in a dark garage with torches
https://www.giffould.com/gallery/albums/userpics/newshock2.JPG
here is the finished result, after all torqued up, and ready to go, its an early CBR600 shock, with a remote reservoir (so fully adjustable) and a re-machined linkage so it will fit the CBR400 Gull, it raises the ride height by about 10-15mm at the back i believe. supported the weight of the bike by attached a tie down type strap to my garage roof, another thing that was impressive to work, and changing the shock was an easier job than i expected, once the subframe is off, 3 bolts and a bit of fiddling and jobs a goodun
i ordered a new subframe, as mine was very corroded and rusty with bits breaking off, and i also asked for it to be powercoated black, so as to not have the corrosion problem again
https://www.giffould.com/gallery/albums/userpics/oldnewsubframe.JPG
a lovely job i think you will agree, and after a quick scrub of the tatty undertray thingy
https://www.giffould.com/gallery/albums/userpics/cleaningundertray.JPG
its fitted back into the subframe and, mounted onto the bike, back end looking more bike like already
https://www.giffould.com/gallery/albums/userpics/newsubframeon1.JPG
i had an adjustment to make to the rear brake lever position and a new bit to fit to aid me in this, but i couldnt get the system apart, so just removed the whole system from the bike in anger, and left it at that for the rear brake
next the front forks, they are standard CBR400 forks with re-worked valving and race tech springs, sposed to be the dog danglies, dont ask about the price
despite a slight weeping on the left hand seal, i installed them anyway, because i needed to convince myself that i knew where the bolts all over my garage floor went
let us begin https://www.giffould.com/gallery/albums/userpics/puttingforksback1.JPG
a fair bit of cursing, pulling back out, and trying to work out how the hell they will end up straight, true and not twisted, and without bending the top yoke
https://www.giffould.com/gallery/albums/userpics/howthefuck.JPG
got there in the end, dropped through by a further 10mm over honda's standard to quicken the steering up, bars back on too, but no switch gear, or electronic garbage (my least favourite part) yet, but one thing at a time
https://www.giffould.com/gallery/albums/userpics/forksbackin3.JPG
called it a day there, as was getting tired, and a numb arse, plenty of problems to address still, awaiting delivery of the front wheel, which is away getting power coated, the rear will need doing at some point, brakes need addressing, and the whole suspension needs a test ride, and setting up the preload, damping, compression and all that crap, but as far as fitting, my chassis should be pretty much sorted
all manner of dirt, grease, seized bolts, and an oil leak still to sort, but, that'll do it for now, my garage floor looks more like a garage floor now rather than a tasty nut catalogue
was falling asleep anyway
https://www.giffould.com/gallery/albums/userpics/downtools.JPG ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
badlydamaged |
badlydamaged Spanner Monkey
Posted: 19:28 - 25 Aug 2004 Post subject: |
Looks like youve been a busy boy Goose!
Looking good mate ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts"
Add me to MSN if you want! badlydamaged@hotmail.com. |
Claud 14.7 to 1 |
Claud 14.7 to 1 World Chat Champion
Posted: 21:02 - 25 Aug 2004 Post subject: |
Quote: | here is the finished result, after all torqued up, and ready to go, its an early CBR600 shock, with a remote reservoir (so fully adjustable) and a re-machined linkage so it will fit the CBR400 Gull, it raises the ride height by about 10-15mm at the back i believe. supported the weight of the bike by attached a tie down type strap to my garage roof, another thing that was impressive to work, and changing the shock was an easier job than i expected, once the subframe is off, 3 bolts and a bit of fiddling and jobs a goodun |
Wow, thats so cool! Wish i could afford one of those. Your bike will be wicked after all this!!!
Its gonna handle so damn good . It will make a stock one feel wobbly, even though they are quite good...
Ps Pics dont load up. Can you just post a pic of the shock in the bike so i can see it, instead of me having to open up the link. Links dont work with me. |
PsychoHippy |
PsychoHippy Jammy Git
Posted: 21:08 - 25 Aug 2004 Post subject: |
Good to see it all coming together again Goose
Oh, nice beard by the way ____________________ I spend all my money on bikes and beer, the rest I simply waste! |
MarJay |
MarJay But it's British!
kev |
kev I Hump Things
Posted: 22:50 - 25 Aug 2004 Post subject: |
You look like Tom Hanks in castaway. ____________________ 20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes |
bikedudextrm |
bikedudextrm Traffic Copper
fazed |
fazed Korn is my hero!
Posted: 06:15 - 26 Aug 2004 Post subject: |
looks Good goose , I like your tarty black subframe and the cbr 600 shock should make it nicer to ride |
WildGoose |
Posted: 07:23 - 26 Aug 2004 Post subject: |
for claud
thanks peeps ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
Robby |
Robby Dirty Old Man
Bendy |
Bendy Mrs Sensible
Posted: 09:34 - 26 Aug 2004 Post subject: |
Bald is the new hair. All the style mags say so. |
The last post was made 19 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
