B5234FT |
B5234FT Brolly Dolly
jaffa90 |
jaffa90 World Chat Champion
..... Quote Me Happy
recman |
recman World Chat Champion
Ste |
Ste Not Work Safe
ADSrox0r |
ADSrox0r World Chat Champion
hmmmnz |
hmmmnz Super Spammer
B5234FT |
Ste |
Ste Not Work Safe
hmmmnz |
Rogerborg |
Rogerborg nimbA
Posted: 12:31 - 25 Nov 2016 Post subject: |
There's hundreds of miles left in that sprocket, maybe thousands. I wouldn't throw money at a GPZ500S until absolutely necessary - something else could render it uneconomically viable before those teeth give up. ____________________ Biking is 1/20th as dangerous as horse riding.
B5234FT |
pompousporcup... |
Rogerborg |
Rogerborg nimbA
Posted: 14:12 - 25 Nov 2016 Post subject: |
Now you've done it. ____________________ Biking is 1/20th as dangerous as horse riding.
B5234FT |
Azoth |
Azoth Brolly Dolly
Posted: 15:11 - 25 Nov 2016 Post subject: |
You should be looking at the front sprocket, not the rear. If it was installed at the same time as the rear one, it will look much, much worse. Worn front sprocket but new chain and good rear sprocket? Change front sprocket. Worn front sprocket but old chain and mediocre rear sprocket? Change chain and sprockets as a set.
Test the chain like this:
1) Eyeball it from the side to look for missing plates between links. If there are any, replace chain and sprockets as a set, because missing plates will cause the chain to snap.
2) Eyeball it from the rear and turn the back wheel, to check if it's straight. If it's crooked, replace chain and sprockets as a set.
3) Grab it from the 3 o'clock position on the rear sprocket, and pull it backward and push it side to side. Any lateral movement? Can you see daylight through it by pulling the chain clear from the sprocket in that position AND do you have sideways play? If so, change chain and sprockets as a set.
4) Check for the correct specs for tightness for the chain. See if there's a marked difference between the loosest and tightest parts of the chain. If there is, change chain and sprockets as a set, because tight spots will cause the chain to snap.
Chains and sprockets are normal consumables on a bike, along with oil, oil filters, seals, bearings, fuel and tyres. They are all part and parcel of what it costs to run a bike. You have to change them when needed, and not try to cut corners, otherwise you could be in some trouble. A snapped chain, particularly, poses a serious health risk to you and your bike. Chains and sprockets wear out together. Put a new chain on old sprockets, and it will wear out very fast. So, most of the time, you change them as a set.
It makes no difference that the bike is an old GPZ500S. The price of the bike on the used bikes market only reflects what the market is willing to pay for it, not whether it ought to be properly maintained to be kept roadworthy, or even whether it's any good. Even a Chinese scooter needs to be maintained properly. Besides, if you put a new chain and sprockets on it, you will notice it's a lot nicer and smoother to ride. ____________________ Safety in numbers
V2 |
V2 Nearly there...
Posted: 15:14 - 25 Nov 2016 Post subject: |
I'm surprised that no one has said this but....
Looks slack |
recman |
B5234FT |
Posted: 16:02 - 25 Nov 2016 Post subject: |
Tawny wrote: | You should be looking at the front sprocket, not the rear. If it was installed at the same time as the rear one, it will look much, much worse. Worn front sprocket but new chain and good rear sprocket? Change front sprocket. Worn front sprocket but old chain and mediocre rear sprocket? Change chain and sprockets as a set.
It makes no difference that the bike is an old GPZ500S. The price of the bike on the used bikes market only reflects what the market is willing to pay for it, not whether it ought to be properly maintained to be kept roadworthy, or even whether it's any good. Even a Chinese scooter needs to be maintained properly. Besides, if you put a new chain and sprockets on it, you will notice it's a lot nicer and smoother to ride. |
Agree entirely, but my question wasnt "shall I change it if its knackered?" it was "how do I know it's knackered?"
From a quick glance, on a long termer, I'd change it for peace of mind, but I tend to be quite conservative with maintenance so I thought I'd consult the masses.
Thanks for the info, I'll check it out and see what's what |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Rogerborg |
Rogerborg nimbA
Posted: 16:30 - 25 Nov 2016 Post subject: |
B5234FT wrote: | "how do I know it's knackered?" |
If it's jumping off the teeth, or they're snapping.
Can you pull the chain away from the rear of the sprocket? If so, the individual links[*] have stretched, and the chain doesn't fit the sprocket any more and is likely to jump. You should replace it then.
Well, I say that, but I can pretty much squeeze a Victorian chimney sweep in between my Nazi Tractor chain and sprocket, and have already lopped two links out of it, but am still eking out the miles.
[*] Yes, I know, the pins. ____________________ Biking is 1/20th as dangerous as horse riding.
Tdibs |
Tdibs Traffic Copper
pompousporcup... |
Ste |
Ste Not Work Safe
Kawasaki Jimbo |
The last post was made 7 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
