WD Forte |
WD Forte World Chat Champion
Posted: 23:56 - 08 Sep 2019 Post subject: My old things getting a bit historical |
I've been hacking my current 1979 CX about since 2009
It's built on a 1979 frame but with 1982 Eurosport engine
which has TI ignition not the early CDI type
Apparently the gubment says it can now qualify as a VHI or Vehicle of Historical Interest and
so will be exempt from road tax) and MOT
I shall still get it MOt'd though and it passed last week
This was it about 18 months ago with winter leg shields on
Sod the looks, they keep your legs and feet dry and toasty when its pissing down
https://i.imgur.com/2RCcaz1.jpg
It's a working bike/hack not a garage queen but I decided its 40th birthday would be a good time for a freshen up
and I stripped all the wiring out and removed a lot of parts to check, grease, paint etc
As I built it frame up from various bikes and parts it always been a bit of a test bed for ideas and mods
and I've tried out various options and gadgets over the years.
Any mods that stayed worked reliably, but the wiring got very messy over time so a rewire was on the todo list.
The bars are going to be changed for lower ones, I have a set of GL clocks for a more conventional look and I decided a black & silver colour scheme woudl be kind of retro and easy as well
https://i.imgur.com/Fj7zB57.jpg
Way back on a whim I thought I'd have the switch wiring run inside the bars
this entailed stripping the switch gear and using thinner cables
in place of the stock ones as well drilling holes in the bars and have the wires emerge
under the fuse cover as the fuse holder plate wasn't being used and got removed.
https://i.imgur.com/2NeLz1Z.jpg
I wouldn't do it again
It all worked well for years but it was one of the reasons I put off replacing the bars which were getting rusty
If I'd needed to remove the bars or switch gear for any reason it would have been a lot more work than normal
Eventually after 5 years or so an overlooked bolt head wore through the insulation shorted the horn relay
and burnt out the wire to the horn button.
I only noticed it when taking it for an MOt test as I rarely use the horn.
It was fixed easily enough but on balance, I reckon external wiring is a more practical method.
When collecting/scrounging up bits to build the bike, I was given a set of Suzuki clocks which worked and the speedo lasted well until it was recently removed
The red led at 7 o clock on the tacho was the fan on warning light
LED temp gauge in the wee ducky
LED voltmeter in what was the Suzuki gear indicator
https://i.imgur.com/wl1QlJL.jpg
cant help buggering about with it
During the electric fan mod I chopped off the tapered end of the fan shaft to give some extra clearance for the
fan housing
Must have been in a "Tacho? We don need no stinkin tacho" mood as while i was in there I blanked off the tacho drive with
an old tacho cable end and removed the clock and added a temp gauge and led voltmeter
The HONDA engine badge was drilled so smd leds would shine out behind each letter
H - high beam O - Oil N - neutral D - fan on A - unused (possiby Azzard warning lights mebbe~?)
It worked as an experiment but did not excite.
The box also served as the main front junction box and got a bit, ok very, cramped.
Two amber led flasher repeaters were extended out and strapped to the screen support bracket
they were easily visible in my lower peripheral vision and I didn't have to move my head to check if
flasher were on or off even with full face helmet on
That was a mod I liked, I kept that one
https://i.imgur.com/tb2v4lQ.jpg
Alternative add ons that lasetd well
Suzuki clocks
Kawasaki gpz550 brake master cylinder
MZ screen and fork gaiters
Twin horn off a K100 when I had a BMW K100RS and RT
Later I modded the dash again for this
https://i.imgur.com/jY1BkeN.jpg
https://i.imgur.com/QhG0jhL.jpg
It was machined out of translucent acrylic,sprayed satin black and the led lense cut last of all
I decided to extend the box idea and this mod was used until I stripped the bike recently
It had cleaner tidier look to it and the after market temp gauge worked very well indeed.
I drilled and tapped out a stock CX sender body to accept the new 1/8th NPT sender
7 led at bottom for voltage LH leds Hi Oil Neutral
RH leds fan on an 2 unused/future mods
This year back to some basics
I got these Gl clocks for £30 and while pretty crusty, they tested OK so a de-rust, clean up and paint was in order
SS and brass nuts used here and all led bulbs inside now too.
https://i.imgur.com/AGyOYoM.jpg
Test fit to get an idea of layout
I had to mod a junction box to fit between the fork legs
this is where the PCB for the relays, the 7v regulator for the temp gauge will go as well as the other front end connections.
https://i.imgur.com/z0uoAEd.jpg
Headlamp bucket added to see what will go where and how
https://i.imgur.com/OGX8uti.jpg
Side view:
I knocked up some headlamp brackets from 4mm ally plate to lift the headlamp more then the old ones did
I've had had another idea in mind since but these will do for now
https://i.imgur.com/PY7PtuP.jpg
Starter motor stripped, checked, cleaned and repainted back to a conventional Black/Silver
Brushes & commutator in VGC, not much carbon dust inside.
The M5x110mm cap head bolts were a good practical mod but needed a wee bit of rust treatment
and one of the threads in the end cap was iffy and needed a helicoil.
Tested before re-fitting and all good now.
https://i.imgur.com/8Ndo6gW.jpg
Radiator and fan cleaned up and painted.
New KSD9700 80C thermo switch bonded on with JB weld.
the previous one worked very well, I reckon they're more robust than the
KSD301 can types I had used previously.
The old one worked fine, but for the £1 or so it cost, I fitted a new one.
the switch doesnt drive the fan directly but actuates a relay which handles the heavy current
https://i.imgur.com/IaKevNS.jpg
I dropped the bottom yoke and cleaned, checked and re greased the tapered rollers
Glad i remembered to do that, it's a bit of an arseache to do it when the fronts all built up
I refreshed the fork oil a few weeks ago.
https://i.imgur.com/XhStRu3.jpg
I decide to drop from 8" rise to 4" rise bars and kinda like em.
32" wide compared to the previous 28" ones.
Sprayed switch gear and MC satin black.
Plonked on the clocks briefly to get an idea of layout.
https://i.imgur.com/nfCx9Ug.jpg
Front junction box PCB Version 1.0 fitted.
Track side insulated prior to installation.
7V reg using LM317T with heat sink at top and relays for headlmap hi/lo and horn on board
Most of the lower pins are just for commoning up
after some test fits I'll decide whether to keep it or make a version 2
https://i.imgur.com/AuTa2n1.jpg
Made a 'swing door' for the under a side panel box I made up
to stow electricals in previously unused space and on a whim, some frame bungs as well
https://i.imgur.com/yzokr6m.jpg
This is what I used as a rad guard for years.
Just alloy speaker mesh bent around the rad to protect the
core from stones
https://i.imgur.com/aKPBBRG.jpg
now I has got this
https://i.imgur.com/LjduXgE.jpg
I've 'been using leds on everything but the headlamp for years but usually arrays of stock 5mm leds
which were a bit of a chore to build and while they worked reliably they were not always quite bright enough
for my liking.
This time I'm using COB leds ( chip on board) for flashers and tail lights and shop bought plug in types for the GL clocks.
Much quicker and easier to build than arrays of 5mm LEDs and when I bench tested them with a light meter
the light output from these 5W leds was more than twice as high as a 21w bulb while the temp stayed low and
easily touchable after a 1 hour soak test.
https://i.imgur.com/jyxnpuO.jpg
Here's the current state of it.
basically the same bike but tarted up and rewired and still going strong after 40 odd years.
https://imgur.com/AqIr2N2.jpg
https://imgur.com/wInORu9.jpg ____________________ bikers smell of wee |
Easy-X |
Easy-X Super Spammer
Posted: 03:27 - 09 Sep 2019 Post subject: |
That engine looks... interesting ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Sister Sledge |
Bhud |
Bhud World Chat Champion
Posted: 13:12 - 09 Sep 2019 Post subject: |
I like all the projects and revisions that went into this. Reminds me of when I kept changing everything on my 600 Diversion, made a custom dash, raised the rear, lowered the front, etc. and fitted these upgrades in while riding it nearly all the time.
You're only missing one thing. Matt black... matt black everywhere (except the engine, maybe)! |
kgm |
kgm World Chat Champion
Meatybeaty |
Meatybeaty World Chat Champion
Posted: 13:15 - 09 Sep 2019 Post subject: |
Great commitment, Great looking bike |
Easy-X |
Posted: 13:37 - 09 Sep 2019 Post subject: |
Longitudinal engine, shaft drive, water cooling... a lot happening back in '79!
Lovely work BTW ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
blurredman |
Posted: 08:28 - 13 Sep 2019 Post subject: |
Likewise, I have to wait 2-3 years for mine to be 40 (in the eyes of registration law) 40.
And I very much intend to be doing similar. Though most of mine is frame issue unfortunately.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k. |
yen_powell |
yen_powell World Chat Champion
Easy-X |
blurredman |
Posted: 10:36 - 13 Sep 2019 Post subject: |
As a member of the CX500 forum (as is Forte),
I dispair at the amount of threads people create "got new bike, gonna cafe racer it".
Pretty sure, that there are more cafe racers of CX's than actual factory CX's now.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
A100man |
A100man World Chat Champion
Posted: 13:53 - 13 Sep 2019 Post subject: |
yen_powell wrote: | I was mocked for owning my CX500 back in 84/85, nowadays I would be a cool dude. Same goes for the holes all over my jeans back then.
Fuck, I was so ahead of my time and never knew it. |
If I recall the only think that was considered worse than a Plastic Maggot at the time was to be seen in a Plastic Pig..
..although in fact both had some kind of perverse cachet. ____________________ Now: A100, GT250A, XJ598, FZ750
A100man |
Posted: 13:54 - 13 Sep 2019 Post subject: |
Blurredman wrote: | As a member of the CX500 forum (as is Forte),
Pretty sure, that there are more cafe racers of CX's than actual factory CX's now.. |
I thin it started when some twat started selling a 'cafe kit' for them. I don't think he understood irony. ____________________ Now: A100, GT250A, XJ598, FZ750
WD Forte |
WD Forte |
chickenstrip |
chickenstrip Super Spammer
Posted: 17:34 - 13 Sep 2019 Post subject: |
This. Totally unsuitable bike for it. Whilst I will never be a fan of them, at least the OP is using it for what it was designed - an efficient daily hack. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
Easy-X |
Posted: 20:30 - 13 Sep 2019 Post subject: |
Just looked on eBay: 50/50 between (roughly) stock and either finished or part way through café racers ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
WD Forte |
mentalboy |
mentalboy World Chat Champion
ZedSled |
ZedSled L Plate Warrior
WD Forte |
Easy-X |
WD Forte |
Posted: 18:04 - 06 Oct 2019 Post subject: |
I did consider getting a full fairing as I saw a couple of cheapish ones on Ebay but I dont do the big long rides much anymore and if I can get rid of or lessen the exhaust stink I'll be Ok with that
As mentioned in the aerodynamic thread, I stunk of exaust fumes after a 50 mile ride and my initial thought was to bodgineer a silencer extension and started this but quickly abandoned the idea
https://i.imgur.com/iaGlMnl.jpg
My friendly local car guy often lets me scrounge from his skip
for odds and bits and I got a small piece of non rusty exhaust to make this
https://imgur.com/0YxOZlY.jpg
What that ? odd colour you say?
I know, but light Blue extreme temp paint was all I had to hand and
its better than nothing for now.
(Edit: Sod it,I got no class me, I kinda like it and will probably leave it like that)
I'm hoping with the exhaust directed away from the bike, less will get drawn back
in the turbulent zone caused by the screen, me and my big assed Givi box.
I shall still experiment with the screen and deflectors though
and the leg shields will soon go back on for the winter with added
Vibranium vortex generators 'n shit ____________________ bikers smell of wee |
The last post was made 4 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
