Suzuki GSR 750 exhaust can swap
GSR750guy
PostPosted: 10:28 - 22 Oct 2023    Post subject: Suzuki GSR 750 exhaust can swap Reply with quote
Hello all, new forum member here.
I have a 2011 Suzuki GSR750 which I'm looking to swap the original ugly can to a nice aftermarket one. Still deciding on the can Mr. Green
I've been doing the usual online research about the process and I'm looking for advice about whether I'd need to remove the exhaust servo and fit a servo eliminator etc
Basically if anyone could give me advice of what's required to fit an aftermarket can that would be appreciated.
Also, it recently went through an mot and the mechanic said my handlebars are bent. Left side is closer to the tank on full lock than the right side. He said the forks etc are all fine but upon looking at my handle bar across the top yoke it looks as if it's not sitting level across the way. I'll try adding a picture for reference where you can see that the handlebar isnt alligned to the yoke and sitting slightly lower on the the left side as you look top down. Should that just be an adjustment to the handlebar clamps needed?? Haven't taken the handlebar off the bike, but it looks to be the right shape. Hoping it's an easy fix as I'm looking at nearly £200 for a bar Shocked
Thanks in advance
J
2011 GSR750
struan80
PostPosted: 15:28 - 22 Oct 2023    Post subject: Reply with quote
Welcome. Very Happy
PostPosted: 19:28 - 22 Oct 2023    Post subject: Reply with quote
Can't really tell much from that photo. Maybe take a photo showing the bars on full lock on each side?
Anyway, unless it's been dropped I doubt the bars are bent, I'd go more with a slight twist in the forks or something similar.
Triumph Trophy Launch Edition
GSR750guy
PostPosted: 20:08 - 22 Oct 2023    Post subject: Reply with quote
The left handlebar does go closer to the tank than the right but only by about a centimetre if that. The mechanic showed it to me but then said my forks etc were all good so he thought it was a bent handlebar. It hasn't been dropped to my knowledge, but it was delivered by a transport company so I'm thinking maybe the straps could have pulled the bars out of alignment if they were put on too tight?? The pic is to show that the handlebar isnt running straight across the yoke and in asking if the bar was bent at the grip area would it show as sitting out of alignment across the two clamps at the yoke. Just trying to get advice before I start having to remove switches etc to get the bar off and check if it's wonky. Reason I'm asking is I've watched a few videos where a bent handlebar would be the rarest most unlikely cause of the problem I have.
2011 GSR750
jeffyjeff
PostPosted: 21:23 - 22 Oct 2023    Post subject: Reply with quote
If the bars and forks are straight, you might consider that the tank might not be positioned properly on the frame. Might be something as simple as a rubber bushing not seated properly. 5mm offset to one side would affect the handlebar to tank dimension by a centimeter, lock to lock.
blurredman
PostPosted: 11:22 - 23 Oct 2023    Post subject: Reply with quote
If your arms and wrists feel the same then I'd forget about the handlebar. Even a slighly bent bar will make you feel all weird and not symetrical bodywise.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.09 - MySQL Queries: 15 - Page Size: 49.2 Kb
