*solved* Keeway supershite carb woes - draining too quickly
TheMadRatter
PostPosted: 14:31 - 17 Jan 2024    Post subject: *solved* Keeway supershite carb woes - draining too quickly Reply with quote
Backstory;
Bought a CHEAP keeway superlight, 2019 EFI model with 3500 miles on the clock. Non-runner because the ECU wasn't communicating with the fuel system - ignition side was fine.
Retrofitted a pre-EFI carb, intake and fuel tank and did 10k miles since July/August last year (600 mile round trips almost every other weekend), but it had a crack in the intake and ran lean, so I adjusted the carb to suit and never had an issue. I ordered a new carb and intake recently, and finally got round to fitting it, only to find it was completely the wrong intake. So I ordered another. And this one came with no vacuum port for the fuel tap. I fitted it anyway and butchered the tap to flow without vacuum. Went for a test ride, and the float bowl drained in about 4 miles of WOT on the dual carriageway. Gave it a minute or so and she fired right back up. I figured my butchering of the fuel tap was probably limiting flow, so got myself another non-vacuum tap (got a reserve now aswell), and fitted that this morning. I also set up the carb again with a colortune at various rev ranges and the bike runs absolutely fine, so I went for another test ride and got about 7 miles before the float bowl drained.
The carb is at a slightly different angle with the new intake, but is there something I could be missing as to why it's draining quicker than it's filling?
Cheers!
TheMadRatter
PostPosted: 14:43 - 17 Jan 2024    Post subject: Reply with quote
Forgot to mention its a proper PZ26 carb, not cheapo, and proper honda fuel tap, not cheapo.
Gonna set the float heights again as the new carb angle is effectively "downhill" so the float would be higher (its towards the front), and that could be closing off supply too early.
PostPosted: 15:52 - 17 Jan 2024    Post subject: Reply with quote
How much fuel was held in the bowl/pipe when the tap was turned off
for this test?
Without knowing how much fuel was used to get 7 miles
its all bollox
TheMadRatter
PostPosted: 16:02 - 17 Jan 2024    Post subject: Reply with quote
for this test?
its all bollox
It was float. I stuck some clear line on the drain, opened the drain screw up and it was extremely low. Set the float heights and just done 30miles pinned at 10.5krpm (down to 8k on the hills) with no issues.l, thankfully.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.18 - MySQL Queries: 15 - Page Size: 40.21 Kb
