Honda CB250K something - very very long term project...
pdg
PostPosted: 13:01 - 14 May 2024    Post subject: Honda CB250K something - very very long term project... Reply with quote
Part 1.
Will it run?
https://i.imgur.com/1GA2FHp.jpeg
Might need a bit of redex.
That beautiful hunk of scrap formerly identified as a 1970-'72 CB250 engine.
It was actually worse than that, I'd already 'cleaned' some of it before I thought to take a pic.
Unfortunately for it, I'm sometimes a twat and I left it out in the rain for approximately one decade, give or take 0.2 decades or so. In my defence (not that I deserve it) it really wasn't that much better beforehand.
I did however have the foresight to put the head, rocker box and other associated gubbins in a box in the shed, so they've got nothing more than patchy surface rust in a few places. Pretty sure I even have a camshaft somewhere too.
I got the block off after draining a few litres of water out of the cases and that's as far as I've got...
I also have the bottom end and gearbox of a slightly later one, it was sat outside next to this one. It's even less complete, but some internals may or may not be interchangeable.
So yeah, I have no idea when or even if any progress will be made, but I thought I'd bung it in here anyway - it might be fun to see what happens.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 13:48 - 14 May 2024    Post subject: Reply with quote
I suppose it'll mainly come down to if you have a viable crank and cam. I'd imagine most of the other bits are available out there because they are raced a lot in classic racing on account of them being flying machines.
PostPosted: 15:10 - 14 May 2024    Post subject: Reply with quote
Boat anchor
pdg
PostPosted: 15:44 - 14 May 2024    Post subject: Reply with quote
I think the two cranks I have are the same, so it should be possible to either pick the best one or make one out of the two.
Looking inside the gearbox through the drain I was actually really surprised with just how not bad it looked - most of the ball bearings are probably past their prime mind.
I seem to remember that the cam had a fair bit of wear, but it's entirely possible I'm thinking of something else... A stock cam is probably obtainable though if it comes to it. If I do need a replacement it'll depend on how the rest turns out - in fact, any new parts at all won't even be looked for until I know I have a reasonable percentage of it that's usable.
At some point I'll turn it into an exploded diagram and get the calipers out...
pdg
PostPosted: 15:45 - 14 May 2024    Post subject: Reply with quote
WD Forte wrote:
Boat anchor
No it's not, cheeky bugger.
It's too light and there's nowhere to attach the rope.........
pdg
PostPosted: 17:55 - 14 May 2024    Post subject: Reply with quote
Update the first. This post contains good news and less good news (it's not bad until I say it is).
I popped off the side covers and discovered very little in the way of rust. I proceeded to remove the clutch plates to separate diagnostics of the engine and gearbox.
Less good news, so we can end on a high:
The crank is stuck in the mains , the conrods are stuck on the big ends, the gudgeon pins are however free with little to no play. To be determined is how stuck and why.
Gooder news:
The starter motor turns and the starter clutch appears to operate. I didn't apply power so I don't know if the starter actually works, but it turns by hand.
The kick starter works (on these engines the kick operates on the gearbox side of the clutch).
All gears can be selected and the gearbox turns freely and smoothly in all of them - it was superficially stuck initially but it's likely that was dry greasy oil in the bearings and/or gunk around the clutch basket.
I think splitting the cases is next on the agenda - it'll be way easier and more mechanically sympathetic to assess and hopefully make good the crank that way.
Interim thoughts - I'm not unhappy.
blurredman
PostPosted: 13:23 - 16 May 2024    Post subject: Reply with quote
Looking forward to it. I like rags to riches stories on bikes!
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1979 MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
jeremyr62
PostPosted: 14:03 - 16 May 2024    Post subject: Reply with quote
By the time that ever runs again, petrol stations will be long distant memories.
But best of luck with it, and rather you than me.
pdg
PostPosted: 18:01 - 16 May 2024    Post subject: Reply with quote
Now I was going to say something like it may end up being a rags to rags deal.
But...
Them's fightin' words Laughing
Now, I'm 100% certain that I could force it to run without replacing anything at all, as long as I can find the camshaft...
From initial inspection it'd likely be a loose definition of running and longevity would be measured in "bits of string" timeframes, but still.
I would like to do at least slightly better than that though and there's exactly zero urgency to use it, so yeah, it won't exactly be finished this weekend - but I'll keep piddling with it and update as and when.
PostPosted: 12:50 - 17 May 2024    Post subject: Reply with quote
I'm an optimist and love a phoenix story but that is scrap..
..it has been screwed by water induced corrosion... any rescues will involve £100s (£1000s?) on new parts - pistons shells,balls, rebore crank grind etc.etc..
by all means try and rescue a forlorn motor but give yourself a fighting chance.
PS its not a Vincent after all.
PostPosted: 13:11 - 17 May 2024    Post subject: Reply with quote
On reflection, calling it a boat anchor was outrageous flattery
it is now a worthless peice of shite
jeremyr62
PostPosted: 13:44 - 17 May 2024    Post subject: Reply with quote
It wasn't my intention to goad you into action Smile
I agree with the naysayers. It will cost serious money to get that going again. There are much better better ways of spending your hard earned.
Sometimes, you just have to let go.
pdg
PostPosted: 15:23 - 17 May 2024    Post subject: Reply with quote
Ok, so let's discuss...
If someone brought that to me and asked me to fix it I'd offer them a fiver for weighbridge value. If they were insistent, I would quote based on replacing and/or machining all of the internals and consider it a bonus if I could reuse the clutch pushrod.
However, that's not the case.
There are levels of survival I am prepared to accept Wink
When I had my 2 stroke 50 the oil injection pump failed and the engine heat seized - I took off the head, made sure the piston was on the down stroke and dumped the clutch in 2nd while rolling downhill, then ran it on premix for the last 4 months of it's life (with me).
Would I build a daily use commuter out of it? No. I could, but that would not be financially viable.
Would I build a show bike out of it? Yes. Show bikes don't have to run...
How about something in between - say a bike that is built to maybe look reasonable to me and maybe do a couple of hundred miles a year pottering around for entertainment, where if it stops working (with variable levels of enthusiasm if/when said stop occurs) it's really not the end of the world because I'm not relying on it?
So yeah. It might be scrap. It might be an exercise in futility. It may not happen quickly but even if it never runs it won't be as expensive as an evening in the pub and it'll be more fun than watching tv.
jeremyr62
PostPosted: 16:32 - 17 May 2024    Post subject: Reply with quote
Yeah but realistically there is no way back for that engine. It doesn't make any sense in any universe to try to resurrect what is essentially a lump of iron and aluminium oxide. Far better to find something else to mess with that has a fighting chance. IMO.
pdg
PostPosted: 18:57 - 17 May 2024    Post subject: Reply with quote
Only singling out your reply because it's the newest, nothing personal Very Happy
I have to ask, like what?
I have a list of requirements:
Be older than me (so pre 1977)
Be between 200 and 500cc (light enough to be my type of fun, but a little more capable than a comparable 125, although I would go under 200cc if it's British)
Cost me (preferably less than) about £100 (slightly flexible if it's properly interesting to me)
A thing to bear in mind is that if this gets on the road it's probably not going to be a primary or secondary bike, it'll barely be a tertiary one - I have the CG (although that's probably going to my son for a bit when he's 17 at which point I may or may not grab his 50), the XL250 and another CB250K - even my 'primary' bike will be a toy, I need car for work and family hauling duties.
So there we go, with those requirements and considerations, like what?
pdg
PostPosted: 19:22 - 17 May 2024    Post subject: Reply with quote
Undeterred by his own stupidity and fuelled with belligerence, our hero bravely battles on and undoes some screws.
Firstly, the left side generator cover comes off to reveal:
https://i.imgur.com/iw5MfCa.jpeg
Then the clutch cover succumbed to his will, as did these 4 bolts
https://i.imgur.com/EVd6TA1.jpeg
This liberated the clutch pack from it's bonds and allowed further inspection confirming that they are indeed clutch plates and that they kept their living quarters remarkably tidy
https://i.imgur.com/mQ4EPyQ.jpeg
https://i.imgur.com/uK2IOop.jpeg
Oh, and then he sprayed some penetrating oil in some places.
jeremyr62
PostPosted: 21:02 - 17 May 2024    Post subject: Reply with quote
It's not the initial cost I would be considering, It's how much it will cost to get it running. To me, it looks like very little of it is useable. By the time you have it in a running condition it will resemble Triggers broom.
Anyway, it's your money.
PostPosted: 21:49 - 17 May 2024    Post subject: Reply with quote
The Motorcycle of Theseus Smile
PostPosted: 23:07 - 17 May 2024    Post subject: Reply with quote
I always wondered what sort of person would actually try and polish a turd.
A turd they created themselves too by the way
Contrast this to Ariel badgers revival of two 1940's era Ariels
Howling Terror
PostPosted: 01:21 - 18 May 2024    Post subject: Reply with quote
Allen Millyard can be heard sucking through his teeth.
I did hear him say that anything can be repaired...maybe that's a thought you can cling to.
I want you to succeed yet from the few photos it looks like a big ask..then again I've never spilt the cases on anything and certainly haven't the equipment to fit new liners or machine replacement parts.
Keep us posted. During my time here I've learned that there are still some key members that are willing to help, if required.
Just give them the right information.
UncleFester
PostPosted: 07:07 - 18 May 2024    Post subject: Reply with quote
That looks like way more effort than reasonable return.
Wife rebuilt an NC50 which was in way better nick than that and it ran into 4 figures, not including the time involved. She's also got a 94 CB400SF that's headed the same way). It's the stupid little stuff like replacement bolts / washers / gaskets / bearings or things like rechroming etc etc. Then there's what you break along the way or just can't find at all then you're too far down the rabbit hole and you end up spending daft money on some unobtnamium (looking at you CB400SF carbs and parts) part because you're already daft money in and can't leave it unfinished.
Scabs should be left well alone, not picked at Smile
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
PostPosted: 09:19 - 18 May 2024    Post subject: Reply with quote
Rebore and pistons alone will be double that. Then there a fuckton of other corroded engine parts to consider. £500 IF everything goes right..
still.. 'À chacun son goût '
pdg
PostPosted: 12:26 - 18 May 2024    Post subject: Reply with quote
Ok, maybe I've got the wrong end of the stick but the vibe I'm getting from the replies are:
Everyone is taking it far too seriously.
Everyone is utterly misunderstanding the intent.
It seems to have been assumed that I'll need to outsource work.
Clarifications:
This is not a restoration. It's not even really a rebuild as I consider them. I have another CB250 of the same model that is pretty much complete and a runner which is a far better candidate for that. If I buy parts for this one, then 'worst case ontario' is I have some more spares for the better one.
I actually enjoy this sort of thing - I would rather spend an evening in the shed fiddling with rusty junk instead of going to the pub and pissing seventy quid of beer against the wall then having nothing more than a headache to show for it.
Rebore? It's not like it's plated - if it really needs a rebore I can do that in the shed. Likewise pressing the crank apart and back together if it really needs new mains. It's an early 70s twin, it's hardly rocket surgery.
I only made the thread to shoot the shit - seems I may have misread the room.
to v or not to v
PostPosted: 12:36 - 18 May 2024    Post subject: Reply with quote
seventy quid, pfff you drink like a woman Razz
UncleFester
PostPosted: 13:17 - 18 May 2024    Post subject: Reply with quote
If it's just playtime tinkering then carry on as you were Mr. Green
It read like you had desires of making it a 'runner' Shocked
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 142.32 Kb
