Author |
frankiew1992 |
frankiew1992 L Plate Warrior
Back to top |
hmmmnz |
hmmmnz Super Spammer
Posted: 00:52 - 13 Jan 2009 Post subject: |
its just a exhaust restriction,
see the 2 tubes that come off the exhaust??
you have to cut those and weld over the hole,
also there may be a small restriction in the variator,
take the side cover off, you will see a band going between the enging and the rear wheel,
the pully at the engine end contains a washer(more like a spacer) that stops the band reaching full extension and stop it reaching full speed,
undo the pully and remove that spacer, then put it all back together,
you could also just buy a new exhaust instead of derestricting the old one,
your call, you may also need a slightly larger main jet if you get a new exhaust
have fun ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
Back to top |
frankiew1992 |
Back to top |
hmmmnz |
Back to top |
frankiew1992 |
Posted: 02:57 - 13 Jan 2009 Post subject: |
i have only had it since 8 ive just got to go to my local tyre shop and get a back tyre will tell u in the morning thanks for your help well appreciated
many thanks frankie |
Back to top |
hmmmnz |
Back to top |
The last post was made 15 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
