Gpz 500 Gurus to the rescue
0ddball
PostPosted: 15:04 - 10 Jan 2006    Post subject: Gpz 500 Gurus to the rescue Reply with quote
(1997 UK D model)
Right, never had a single spot of bother with it until now and it was starting and running fine yesterday. Today i turned the key and there was nothing, everything was dead. I couldn't really see how the battery would go flat overnight but i charged it up anyway.
Then the neutral and oil pressure light lit but were intermittent. As i was trying the starter button the lights dimmed, the starter didn't show any signs of life but i could hear what sounds like a squeeking/arcing in the fuse box. I've checked all the 10A fuses in the box, they are fine (though there is a spare 10A and a spare 30A, what is the 30A for?)
Now when i turn the key there is nothing, no lights and no noises when i try the starter. I tried to run it off a fully charged car battery just to rule the bike battery out but it was still the same.
Short of stripping the bike and running though the loom bit by bit does anyone have any advice? Is there some simple fuse/relay i'm over looking or any common problems?
thanks.
extreme3d
PostPosted: 16:28 - 10 Jan 2006    Post subject: Reply with quote
The 30A is for the main fuse which is in it's own separate box down the left side of the fairing under the seat. Check that first as you may have blown it.
PostPosted: 16:29 - 10 Jan 2006    Post subject: Reply with quote
Can you get around to the inside of the fuse box and check nothing has broken / melted in there.
Not that much current goes through the fuse box compared to the requirements of the starter motor. Given the noise you are hearing I would be inclined to use a multimeter to go through the electrics looking for a short to earth.
extreme3d
PostPosted: 16:40 - 10 Jan 2006    Post subject: Reply with quote
Check under the headlamp area for the terminal where all the wires meet. Check all the plugs etc there are not corroded as water/road grime can hit that area. One of them is the live wire that feeds all electrics from one end of the bike to the other and if it's corroded/cut it will kill all circuits on the bike. My old GPZ (D7 2000) did this whilst i was driving. All of a sudden no engine, no lights, no electrics at all! I had no option but to coast to a stop and call the AA Shocked
PostPosted: 16:47 - 10 Jan 2006    Post subject: Reply with quote
Follow the fat red wire from the battery. This leads to the starter solenoid which is located under the left hand side panel. There is a red, plastic, snap connector block on the solenoid. Undo this.
This connector block contains the main fuse (30A) and all the power to the rest of the bike passes through it. One of the terminals that the fuse pushes into is prone to corrosion (on the fat, white wire), goes all green and furry and eats away the terminal on the fuse.
I have had to splice new terminals onto three of these in the past. The corrosion has a tendancy to track back along the wire so if this is the problem, you might have to cut a few inches off the wire and solder a new piece on.
Oh yeah. The fuse box CAN be totally dismantled. Surprised me, there is a bewildering array of printed circuits and microrelays in there.
I have also had an ignition switch go duff on me.
“Rule number one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.
PostPosted: 16:53 - 10 Jan 2006    Post subject: Reply with quote
Also try giving the fuse box a sharp thump with the heel of your hand. It has worked for me in the past.
extreme3d
PostPosted: 17:44 - 10 Jan 2006    Post subject: Reply with quote
Thumbs Up Laughing
0ddball
PostPosted: 11:57 - 11 Jan 2006    Post subject: Reply with quote
Success! Thanks for all the suggestions guys and give yourselves a pat on the back, it was the 30amp fuse that had blown. The starter solenoid terminals were a bit furry too so i gave those a clean and she started first press. Very Happy
There is a gap of 5 years, 17 days between these two posts...
nigel_robbins
PostPosted: 23:51 - 27 Jan 2011    Post subject: Reply with quote
Hi,
Riding back this evening all the electrics went on my 1987 Kawasaki GPZ 500.
The engine was still running but no lights.
When I turned it off there was nothing...
no lights, ignition, horn, and would not start
I've checked the four 10A fuses and the 30A main fuse and they all look fine plus the battery is good also.
Any ideas ?
Thanks,
Nigel
nigel_robbins
PostPosted: 00:08 - 28 Jan 2011    Post subject: Minor update Reply with quote
Sorry, the bike does start just no...
ignition lights, lights, indicators, horn, etc...
PostPosted: 01:45 - 28 Jan 2011    Post subject: Reply with quote
1) Way to resurrect a 4 year old thread.
2) As I said in my PM. That sounds distinctly odd.
Does the headlight flash when you press the "pass" button on the left switchgear?
Does the rev counter work when the engine is running?
nigel_robbins
PostPosted: 21:55 - 30 Jan 2011    Post subject: Kawasaki GPZ 500 - no electrics Reply with quote
Hi,
First of all, many thanks to kickstart and stinkwheel for your speedy and helpful input.
I found out that the brown wire (that leads to a brown wire) came off where it joined the ignition switch.
However, I'm not sure where to solder it back.
The lights come on if I touch the brown wire to the solder which leads on to the white wire (pic white wire). The lights also work when touched to the solder that leads to the yellow wire (pic yellow_wire).
When connected, the lights, horn, rev counter, etc. all work except the indicators despite the 10A fuses looking good.
Any thoughts on the above two issues will be much appreciated.
Many thanks,
Nigel
PostPosted: 22:29 - 30 Jan 2011    Post subject: Reply with quote
The brown wire is the switched live feed to the fuse box. It feeds the head lights, tail lights, ignition, horn and indirectly, the flashers.
It's normally connected to the white wire via the switch (so when the switch is off, it's not connected to the white). It ought to have its own seperate tag to attach to on the switch. Soldering it to the white wire will mean the bike is on all the time, no matter what you do with the switch.
There is a branch which comes off the brown wire to feed the indicator fuse. Probably brown with a red tracer. The join is somewhere wrapped up in the loom.
If the brown is connected up properly at the ignition switch, there should be 12v where the red on brown (or whatever colour the indicator fuse feed is) enters the fuesbox with the ignition on. If there isn't, you'll need to peel back the loom and follow that wire to find where the break is. it ought to join that brown wire somewhere.
A thought. It is unusual for a soldered join to part company like you describe. It suggests to me that it got pretty damned hot. Perhaps there has been a short somewhere and the solder blew before the fuse? Perhaps that short was on the flasher wire?
PostPosted: 22:44 - 30 Jan 2011    Post subject: Reply with quote
Hetzer wrote:
FFS, and you're a vet as well? How do you retain all this stuff, and where do you keep it?
I've had to wire up a few EX500 ignition switches, the go duff fairly regularly. I wired my last one up with a flick-switch in place of the ignition lock. So mostly experience.
Where do I keep it?
/home/scott/pictures/motorbike manuals/gpz_manual.PDF
I've spent so long over the years pouring over various wiring diagrams trying to locate a fault that they pretty much make sense to me now.
PostPosted: 13:15 - 31 Jan 2011    Post subject: Reply with quote
That looks like it has been bodged at some point in the past. I'd say someone has tried to hotwire the bike by knocking the back off the switch and pulling the wires off and it's been repaired. The soldering is pretty ropy looking, could be another dry joint in there. I would be tempted to re-solder the lot of them one at a time.
If you have a multimeter, you ought to be able to track down which terminal you want that wire to connect to though.
One of the terminals will read 0V when the ignition switch is off and 12V when the switch is on. That's the one you want.
I have a dim recollection of there being a wire soldered to the metal plate on the back of the switch. Unfortunately it doesn't show this level of detail in the manual. Picture attached.
All things being equal. It might be a better idea to replace the ignition switch altogether. You'll get a second hand one off ebay for Ł30.
nigel_robbins
PostPosted: 19:41 - 06 Feb 2011    Post subject: Re: Kawasaki GPZ 500 - no electrics‏ Reply with quote
Hi,
Just an update to say it’s all working now.
I soldered back the wire as detailed in stinkwheel’s 'soldered.jpg' photo.
In the near future I plan to buy a replacement ignition switch on ebay.
I've sorted out the issue with the indicators not working.
It was my fault, in checking all the connections I'd reconnected the socket to the indicator relay incorrectly. Useful GPZ500 'no indicators' link:
http://www.high-speed.ismysite.co.uk/phpBB3/viewtopic.php?f=25&t=7943&start=0
Many thanks to stinkwheel for all the help !
Nigel
The last post was made 5 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 2.89 Sec - Server Load: 0.89 - MySQL Queries: 16 - CDN Objects: 38 - Page Size: 98.34 Kb
