nrg |
nrg Borekit Bruiser
steveh |
steveh World Chat Champion
nrg |
nrg Borekit Bruiser
Richard1987 |
Richard1987 Scooby Slapper
Posted: 14:42 - 14 Feb 2006 Post subject: |
sounds kinda dumb but check the bulbs
most peds only have 1 fuse usually placed at tjhe battery terminals somewhere around there?
Correct me if im wrong ____________________ add me to your msn messenger contacts : rip307@msn.com |
nrg |
nrg Borekit Bruiser
Richard1987 |
Posted: 18:57 - 14 Feb 2006 Post subject: |
a multimeter would be a good tool to have for these kind of problems. do you know how to use one? ____________________ add me to your msn messenger contacts : rip307@msn.com |
SFX |
SFX Derestricted Danger
nrg |
nrg Borekit Bruiser
Richard1987 |
Posted: 00:57 - 22 Feb 2006 Post subject: |
sure its not below the tank? around the engine where the starter motor is located? ____________________ add me to your msn messenger contacts : rip307@msn.com |
The Tot |
The Tot World Chat Champion
Posted: 03:05 - 22 Feb 2006 Post subject: |
Take it to a garage, 80 quid will sort the problem out. When i had my NRG, it would only run on one bulb, not use electric start and generally often used to cut out. The fuse is right next to the battery - i believe it's a 10 A fuse, but best check.
The problem is the connections on these bikes are shit so you may have to inspect the connections with a multimeter and resolder. It's pretty easy to do on the NRG cos all you have to do is pop off the front fairing.
A new battery might help. What model NRG is it? I had an 00 DT model.
In all honesty, just take it to a garge to sort and it'll be as good as new. ____________________ The Tot 2007 Yamaha R1 4C8 2002 Yamaha FZS1000 Fazer &
www.youtube.com/Titot182 for your bike gear reviews and pop punk covers
Earl Of Easycore Pop Punk Will Never Die! |
nrg |
nrg Borekit Bruiser
Misc |
Misc World Chat Champion
Fadel |
Fadel Trackday Trickster
Posted: 15:06 - 22 Feb 2006 Post subject: |
Get an Ohms meter, see if it's the wires or the actual terminal (lost the word I was after lol )
I need to do that as my speedo isn't working |
Misc |
The Tot |
Fadel |
Posted: 17:22 - 22 Feb 2006 Post subject: |
I have had seen several people saying tey had to get speedo cables for thier DNAs just not got round to it yet.
I'll check the spindle later on Cheers |
tommyboi |
tommyboi Borekit Bruiser
Posted: 19:25 - 22 Feb 2006 Post subject: |
brother had same problem,
take front plastic panel off above the front wheel then cheak the plastic clip holding wires in key hole it falls out alot ,
if it is this you will have it done in appox 3mins |
The last post was made 18 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
