owdamer |
owdamer World Chat Champion
veeeffarr |
veeeffarr Super Spammer
owdamer |
veeeffarr |
Posted: 19:43 - 08 Mar 2006 Post subject: |
Well if you count the fact I bumped it when I replied, a little bit
I imagine Daz|n00by knows something about this, drop him a PM I would |
daz|n00by |
daz|n00by The Internet
Posted: 21:17 - 08 Mar 2006 Post subject: |
Hi, did i see my name?
Yes i have done this for a living and may i say its a most satisfying job when done in the summer
From what you describe you have 2 options to go.
1. full removal of old render and pebble dash, chase out or mesh the brick work under neath, then apply 2 coats of render (1 scratch coat and 1 top coat) then apply a Tyrolean finish to what ever grade you want from very light and smooth to heavy almost roughcast finish (light finish looks the best and give the nicest finish imo), Tyrolean also comes in various colours from off white to sand stone and even in harsh colours now such as blue and red.
2. Remove all loose and blown render rake out joints and 2 coat to bring flush to surrounding render, then 1 coat the whole back wall after treating with a coat of Unibond and rub smooth, then apply Tyrolean to required finish as above.
the second option being the cheapest and fasted due to the work involved in-removal of all the old render.
Prices will vary a lot with different builders and how set up they are to do the job, ie a scaffold platform will be needed, either you provide or they provide same with a skip.
As a rough guide work on anything between £15/ 25 a square metre for 2 coat render and Tyrolean and a minimum of 3/4 days work depending on weather.
If its a 1 off i usually charge by the job myself and for a average back wall ie 3 windows and a door house i will charge approx£120/150 and then materials(about£80) in your case.
Also if full removal of render is done then you will need to take in to account the re beading of the wall, this entails round the window with angle bead,bell bead across the bottom of the house just above the damp course and stop beads if the house next door doesn't have render finish.
If your handy with a plastering float and hawk then option 2 could be done by your self with a bit of guidance untill you get to the Tyrolean part which is a very akward job for a diy person.
hope this helps you a bit. ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. |
Cillit-BANG |
Cillit-BANG World Chat Champion
daz|n00by |
Posted: 22:06 - 08 Mar 2006 Post subject: |
First day will be remove old render only, maybe beads at the most.
second day will be patch old render up to surface maybe 3/4 hours work, day 3 will be to finish render top coat maybe 5 hours work 6 at a push last day will be Tyrolean maybe 3 hours work including waiting for for first coat of Tyrolean to dry.
I make that approx 20/22 hours work for £120/150.
the area were i live is not in the habit of paying top wack for building work so i charge accordingly to suit were i work and who i,m working for.
When i,m on my sub contract work to the offices that i do maintenance for i charge £22 hour.
Besides that i enjoy my work and usually end up doing favors for people and just "have a drink". ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
veeeffarr |
Posted: 22:14 - 08 Mar 2006 Post subject: |
Daz,
We need more builders like you! |
daz|n00by |
veeeffarr |
BFG |
BFG Brolly Dolly
Posted: 22:33 - 08 Mar 2006 Post subject: |
Good builders are hard to find - You're definitely undercharging there Daz. But you sound like you know what you're doing too - Wish you'd done our house.
Back of our house sticks out 1.5" further than next door. That's cos the rerendering had to be done three times because they kept fucking it up. The first time they didn't bead the reveals.
This builder wanted to leave it grey too. Even though I had specifically stated I wanted a white finish to match the rest of the house. "That's decorating mate", was the answer. Twat.
Thankfully the guy putting the conservatory up, subbed to the builder otherwise it would have been a right arseache trying to sort out. He got them to do it again.
Then, when he came to put the frame up, he took his timbers out from under the lead and found that they hadn't nailed the lead to the wall (with the bead nails) and the lead and new render came away in his hands. He went absolutely fucking totally mental - Really went purple and was throwing his tools and all sorts. Wish I'd had a video camera. He sacked them and only paid them materials cos he'd lost 4 days on the job putting right their crap.
He than got another builder to fix it and put tyrolean on the whole wall, which sorted it. But then we had it painted over the top too and paid extra because IMO the tyrolean white ain't that white. Gave him a case of wine when he finished. Top bloke. |
daz|n00by |
BFG |
BFG Brolly Dolly
Posted: 23:01 - 08 Mar 2006 Post subject: |
Thanks for the info! It's OK though, all the old render came off and there was a good scored base done.
I think I'm exaggerating with the extra thickness TBH. You can see a step, but it's that the original new render wasn't that flat, so the tyrolean made up some thickness on the second run. I'm happy it was a sound job eventually on a sound base, but I'll keep an eye on it all the same. |
The last post was made 18 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
