Jack_Cheese |
Jack_Cheese World Chat Champion
Posted: 22:09 - 15 Mar 2006 Post subject: Randomly decided to paint a chunk of my bike today... |
Not sure if this should go in here, general chat or pictures, but here goes.
Had a random urge to paint my front mudguard matt black today. So i did. First thing i did was march down to halfrauds. 400, 800, and 1200 wet and dry went straight into my helmet (at this point being used as a shopping basket) along with plastikote primer and satin black. Both look identical, but figured i'd be proper about things.
Removing the mudguard. What an ordeal! The first picture of the mudguard shows it straight after removal. Those clips had to be hammered off the back of the bolts because the nuts were spinning in their housings on the other side of the clip. Finally got them off, though i had to resort to mole grips for the last of them.
Prepping - I took the good old 400 grit, a bucket of water and went beserk. You can never be overly-patient with the prepping, so i wet sanded, and left it to dry. Re-examined the paintwork, then sanded once more over the high spots, and any spots i'd missed. A couple of pieces of grit had got caught under the wet 'n' dry, too and left huge streaks. More sanding. More yet again with the 800 to get a smooth finish.
Painting - Meths + rag + elbow grease = paintable surface. I gave it a nice rub down with the meths then left it to dry. All of the garage was covered in newspaper, old carpet etc... I also made sure i draught-proofed the garade door round the bottom to stop the dust being lifted by the breeze. This also meant i was rather high. In these kind of temperatures, it's normally advisable to put the paint/primer into lukewarm water (if it's too hot for your hand, it's too hot for your paint can). This helps you to get a fine spray. Using a little spray gun adapter thingy i bought a while back, i started spraying the primer. I moved with the curve of the mudguard, from front to back keeping perpendicular and keeping the same distance.
Prepping Pt 2 - time for more sanding. This time i used wet 1200 grit and i rubbed very bloody lightly. Taking your time rubbing lightly is a hell of a lot better than taking paint off and wasting a hell of a lot of time building the layers back up.
Anyway, 1 more layer of primer, and 2 more layers of paint (sanding very very very lightly between each coat) and i'm done. And i'm pretty chuffed with 4 hours work!
I just wanted to put this in her so if anyone is considering spraying anything there's a wee little guide. I'm sure i could be corrected on how to do a few things, but i'm happy with the finish!
Expand the pictures to full size to get the best out of them, they turn even poorer quality when they're downsized by the browser.
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
instigator |
instigator Super Spammer
Posted: 22:44 - 15 Mar 2006 Post subject: |
Your picturs are f*cking useless. Or it's my computer
Am sure the quality is good though...the paintwork that is. |
NSR Mick |
NSR Mick World Chat Champion
Jack_Cheese |
Posted: 22:49 - 15 Mar 2006 Post subject: |
Had to load em as .gif files due to the size. Humm, i think i'll try and rectify that little situation...
Jack
:edit: Expand the pics to full size, they're not nearly as poo! ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
Groove |
Groove World Chat Champion
Jack_Cheese |
Posted: 23:11 - 15 Mar 2006 Post subject: |
Cagiva planet 125. The front mudguard is basically the same as a monster, but the retaining arms don't strech down as far.
I never thought a bike manufactured by an MV Augusta owned company could have such annoying retaining clips. It beggars belief!.
NSR Mick |
Method |
Method World Chat Champion
Posted: 18:11 - 16 Mar 2006 Post subject: |
Ewwwwwwwwwwww
Cant realy tell if the paint job was decent or not,
Ive never seen that happen with pics before ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
fast_tzr |
fast_tzr World Chat Champion
owdamer |
owdamer World Chat Champion
Jack_Cheese |
Posted: 19:24 - 17 Mar 2006 Post subject: |
Sony cyber shot 1.3Mp. Not a bad camera, tis a bit old, though. It's because they're .gif files that the quality is so crumby.
Anyway, i replaced the shovel of a numberplate hanger today, and got some small indicators. Had to do some chopping and shaping to get it to fit, but it worked well, and i'm happy with the results I'll post some pics up later.
EuropeanNC30R... |
EuropeanNC30R... Gay Hairdresser
Posted: 15:20 - 18 Mar 2006 Post subject: |
Looks like you've used paint to convert them to .gif's. Did the same thing to some of mine yesterday.
Sort some decent photos out, or if they're too big reduce the size. (easy to do in paint ) |
nrml76 |
nrml76 Brolly Dolly
Posted: 17:59 - 18 Mar 2006 Post subject: |
Nice thread . Just the inspiration I need to get started on my top fairing. It's broken in three places though, so it will be a challenge to get it back to new. Where did you source your paint, primer and the spray gun adapter thingy, and how much did they cost? |
Jack_Cheese |
Posted: 18:24 - 18 Mar 2006 Post subject: |
Paint and primer was from B&Q, just under £6 a can. The adaptor thingy i got from halfrauds cost about £1.99 or something - it really saves the ache on your fingers. What colour you doing your fairing?
nrml76 |
nrml76 Brolly Dolly
Jack_Cheese |
Posted: 19:39 - 18 Mar 2006 Post subject: |
Got the pics up on bikepics.com https://www.bikepics.com/members/jackcheese/ There's one of my tidier rear, and a photo of the front mudguard. the lighting is a bit poo, so i think i'll have to replace a couple of photos. The fuel tank is next for a matt-blacking!
McGee |
McGee O RLY?
Keen |
Keen World Chat Champion
Posted: 22:14 - 20 Mar 2006 Post subject: |
chain looks a touch slack on those pics, I used to have a planet and it seemed to eat through chains (seeing the evil fuel tap again brings back bad memories). Might want to tighten that badboy being a 17 yr old muppet when I had my planet, I neglected it pretty badly and the chain slipped off the rear sprocket on mine not nice ____________________ "he who makes a beast of himself gets rid of the pain of being a man"- Dr. Johnson |
Jack_Cheese |
Posted: 22:19 - 20 Mar 2006 Post subject: |
Thanks for the reminder I noticed it on the morning i took those photos, but i've since forgotten (obviously). Did you have a paddock stand for yours, and if so - did you use bobbins, because i can't see any mounting points for bobbins at all!
I'm going to get some daylight pictures tomorrow, and i should be respraying my tank sometime later this week provided i can get it off because, contrary to popular belief, this bike seriously does not want to come apart.
palmer |
palmer Fiddled Kiddy
Jack_Cheese |
Posted: 14:19 - 21 Mar 2006 Post subject: |
Got some daytime pics of my work on the arse end on bike pics. I had to cut the numberplate hanger down on the inner sliding part to allow it to fit between the holes on the end of the grabrails. I then had to file open the holes to allow the indicators to fit through. A few things fouled here and there, so had to be chopped and shaped, and the left indicator needs another washer going on the bolt to space it out. Looks 10x better than stock, though!
https://www.bikepics.com/pictures/545756/
airpig |
airpig Scooby Slapper
Posted: 11:34 - 25 Mar 2006 Post subject: |
Wanting to prep and paint my fairings but wondering if have to get rid of decals first or just get straight to it with the wet and dry?
Cheers ____________________ Bikes are an addiction for which there's no rehab!! |
NC30UK |
NC30UK Scooby Slapper
Posted: 14:28 - 25 Mar 2006 Post subject: |
yes you do, the decals on factory paint jobs are on top of the paint, and under the laquer. You should sand through the laquer, peel off the stickers, smooth it all down, primer, sand, coat, sand, coat, sand, coat, sand, laquer. |
jonnay |
jonnay World Chat Champion
Jack_Cheese |
The last post was made 18 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
