quacker_boy |
quacker_boy Cuddle Bitch
400bandit |
400bandit World Chat Champion
Fadel |
Fadel Trackday Trickster
Posted: 02:36 - 20 Apr 2006 Post subject: |
I knew what he meant
I've burned my hand countless times putting my chain through my rear wheel and catching my zorst when I first got it.
Used to it now though so I don't catch it as much |
numark1 |
numark1 Scared of girls
Posted: 09:41 - 20 Apr 2006 Post subject: |
I can see myself now grabbing a hot exhaust and burning my hand. |
numark1 |
Kickstart |
Kickstart The Oracle
Gazdaman |
Gazdaman I did a trackday!!!
Barry_M2 |
Barry_M2 World Chat Champion
Kickstart |
numark1 |
Posted: 12:54 - 21 Apr 2006 Post subject: |
I am awaiting a switch gear and then i have EVERYTHING i need to get it started without bodging anything which should be good.
I think i will get it all going and almost complete before i try anything silly but there is so much i can for not that much which is really tempting. |
Barry_M2 |
bidman |
bidman Crazy Courier
Posted: 12:58 - 21 Apr 2006 Post subject: |
Hi, just to let you know incase you didn't already, looks to me your front wheel is on the wrong way, Dan ____________________ Don't ride it, RAG IT!! |
numark1 |
Posted: 13:31 - 21 Apr 2006 Post subject: |
Its the right one barry. Start button and kill switch is what i need.
The wheels are probably on the wrong way around but i only put them on temporary so i could move the bike about. Still need to put the brake discs on both wheels. |
numark1 |
Posted: 20:28 - 23 Apr 2006 Post subject: |
Done a bit more this weekend.
Rear wheel is on fully now, put the sprocket carrier on and rear brake disc and caliper. Footpegs are on and i started to spray the front mudguard one of the engine bars and the tank.
I don't think i left the primer long enough to dry as the glossy paint is coming up quite dull so i will leave that a couple of days then put a few more final coats on.
Also painted the clipons and put the ignition on.
Hopefully tonight i will win auctions for the R/H switch gear and clocks. Once i have the switch gear i have everything i need to get it started, before i go to thailand.
Once the engine's started i don't have much else to do.
I will need to sort out the loom for, fairings, put the clocks on and sort out the exhaust system.
I also bought some new paddock stands off Fuzz which have made a massive difference. Everybody should buy some now, it makes everything to do with wheels so much easier.
Anyway here are some pictures.
https://img192.imageshack.us/img192/8933/imgp43339nj.jpg
https://img107.imageshack.us/img107/5925/imgp43340vq.jpg |
McGee |
McGee O RLY?
craigs23 |
craigs23 Mr Muscle
numark1 |
Posted: 10:34 - 24 Apr 2006 Post subject: |
I will get some better pictures today in the daylight as the flash is making the bike look pretty crap.
I also won a r/h switch gear and the clocks for £20 posted last night so hopefully could try and start the beast up on the weekend if i sort out the wiring. |
quacker_boy |
numark1 |
Posted: 12:07 - 24 Apr 2006 Post subject: |
Sure am.
The bitch is finding parts atm though. I need a speedo thing that acts as a spacer on the front wheel which is really hard to find. Also i need a fuel tap and pump which seem to be pretty difficult to get hold of.
Once the engines running i will really get into gear and try and sort it out asap. Still on schedule to do a few track days this year on it. |
Gazdaman |
numark1 |
Posted: 13:39 - 24 Apr 2006 Post subject: |
I've heard a lot of tzr250 stuff fits, like the brake dics are the same.
I have spied a speedo drive for a 250 on ebay so will have a bid. Hopefully it will fit. |
Gazdaman |
Kickstart |
Posted: 20:58 - 24 Apr 2006 Post subject: |
Think the FZR uses 300mm disks while the TZR 1KT / 2MA models use a single 320mm disks. The 320 ones are easy (used by Ducati and a load of others as well) but the 300 is a bit more difficult (FZR600, possibly the TDM850, etc).
You can get rebuild kits fairly easily if they are warped.
Not sure on the speedo drive. They are something like £30~£40 new (got given the price of one of those when I was asking about the little bit of bent metal that drives it, I almost choked). Might be easier and cheaper to find someone local with a lathe to knock up a spacer to replace it.
numark1 |
Klause |
Klause World Chat Champion
Posted: 20:29 - 26 Apr 2006 Post subject: |
Sweet, I'll pop round soon on the monster to take a look see how your doing . ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
The last post was made 18 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
