| Author |
| Velocifero |
 Velocifero Borekit Bruiser
| Back to top |
| finpos |
 finpos World Chat Champion
| Back to top |
| WavyGravy |
 WavyGravy Scooby Slapper
 Posted: 10:07 - 23 May 2006 Post subject: |
Hi There, what bike/year is it?
What caused the reg/rec to fail before?
Is the new one getting too hot to touch after a short ride?
Whats the acid level in the battery like?
If the headlamp is the only thing on that circuit then youve got a short in the wiring or are running too high a wattage bulb. if its not the only thing on the circuit then you could try this general test on the electrics
To get enough heat to melt things either means a short or something is drawing too much current, if the cause isnt obvious then with the bike at rest unplug as many connectors as you can reach and switch ignition on and see if the fusebox heats up, (put your hand on other components as well such as the ignition coils, these heat up quickly if theyre shorted) switch off and connect something else and test again, until you isolate the circuit thats causing the problem. If nothing is making the fusebox hot with these tests then the fault lies in the charging circuit.
These tests are just general ones, it might be an idea to disconnect the cdi (if fitted) while doing them If you can tell us the year and model then there might be someone who has experienced the same, and some bikes are easy to diagnose, like old hondas have great electrical components but dreadful wiring/connectors. ____________________ 1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off" |
| Back to top |
| Velocifero |
| Back to top |
| WavyGravy |
| Back to top |
| Velocifero |
| Back to top |
| edd |
 edd Nearly there...
| Back to top |
| Phil_G |
 Phil_G Traffic Copper
| Back to top |
The last post was made 19 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
