Zephyr 550 -> 600 conversion
proximity
PostPosted: 20:46 - 10 Aug 2006    Post subject: Zephyr 550 -> 600 conversion Reply with quote
As some of you may know my gearbox went on the zephyr. Instead of fixing it (will do that later) i got hold of an old GPX600R to fiddle with and me and edd of this forum have decided to have a little project and we are putting that in the zephyr. Power should go from 50hp to 84hp plus it has a set of micron downpipes so a little more.
Part 1: Stripping the bikes
Zephyr when i got it:
https://homepage.ntlworld.com/jason.lovell/project/zephyr%20new.jpg
GPX after i'd stripped it down:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20stripped.jpg
Zephyr stripped:
https://homepage.ntlworld.com/jason.lovell/project/zephyr%20stripped.jpg
Zephyr engine out:
https://homepage.ntlworld.com/jason.lovell/project/zephyr%20no%20engine.jpg
[/b]
2004 Aprilia Tuono
proximity
PostPosted: 20:50 - 10 Aug 2006    Post subject: Reply with quote
Part 2: The GPX top end rebuild
Here is the GPX top end:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20cams.jpg
It has 8 cam lobes and 16 valves, it uses rocker arms and screw and locknut type adjusters.
https://homepage.ntlworld.com/jason.lovell/project/gpx%20head.jpg
I took the head off first:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20head%20off.jpg
Here are the barrells:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20barrels.jpg
And then i spent absolutely ages lapping all the valves in and replacing the valve guide oil seals. I didnt take many pictures, here is the seat and valve during lapping:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20seat.jpg
https://homepage.ntlworld.com/jason.lovell/project/gpx%20valve.jpg
2004 Aprilia Tuono
Does it fit?
Interesting project.
proximity
PostPosted: 20:52 - 10 Aug 2006    Post subject: Reply with quote
Part 3: Mounting the GPX.
2 of the mounts lined up, the rear one i had to make a bracket.
Here is the engine mounted:
https://homepage.ntlworld.com/jason.lovell/project/gpx%20mounted.jpg
2004 Aprilia Tuono
PostPosted: 20:54 - 10 Aug 2006    Post subject: Reply with quote
Wouldn't have thought that. How are you mounting the radiator? Go on, do it Benelli style under the seat to really confuse people Wink .
proximity
PostPosted: 20:55 - 10 Aug 2006    Post subject: Reply with quote
Part 4: The exhaust.
I bought a set of micron downpipes off ebay. They were cheap but they come out on the left hand side of the bike (wierdly) and the link pipe wont fit there.
I took a piece of bed:
https://homepage.ntlworld.com/jason.lovell/project/bed%20exhaust.jpg
Cut it up like so:
https://homepage.ntlworld.com/jason.lovell/project/exhaust%20peice.jpg
Taped it together in place:
https://homepage.ntlworld.com/jason.lovell/project/exhaust%20taped.jpg
Welded it (im not very good but its strong):
https://homepage.ntlworld.com/jason.lovell/project/exhaust%20welded.jpg
And bobs your uncle:
https://homepage.ntlworld.com/jason.lovell/project/exhaust%20finished.jpg
It looks really cool with the can on, im just paintin it and then i will take a picture of it mounted. You will be impressed Very Happy
Edit heres the can on:
https://homepage.ntlworld.com/jason.lovell/project/exhaust%20done.jpg
2004 Aprilia Tuono
proximity
PostPosted: 20:57 - 10 Aug 2006    Post subject: Reply with quote
The radiator is getting mounted up front, i am in the process of making a bracket. I have mounted the top where the oil cooler went originally, but the bottom of the radiator im still trying the think of where it can mount.
The coolant tank fits snuggly under the seat.
2004 Aprilia Tuono
Whosthedaddy
PostPosted: 21:01 - 10 Aug 2006    Post subject: Reply with quote
Nice little project there Shocked
I take this is nt the 1st time that you've messed about with bikes. How difficult is it to have and build a hybrid bike?
proximity
PostPosted: 21:03 - 10 Aug 2006    Post subject: Reply with quote
Oh yeah if you look in the pictures above you can just see i put the GPX front end on aswell, with both 16" wheels and calipers.
When i got it, it had a GPZ front end which was crap and the original rear which meant it had an 18" rear and 16" front and crap single piston calipers.
2004 Aprilia Tuono
proximity
PostPosted: 21:04 - 10 Aug 2006    Post subject: Reply with quote
This isnt the first time ive messed about i always make little modifications but its the first time for all the big bits, for example ive never done a top end rebuild or swapped an engine before.
2004 Aprilia Tuono
proximity
PostPosted: 21:26 - 10 Aug 2006    Post subject: Reply with quote
I think what made it easy is using 2 kawasaki's from a relatively similar time.
For example the engine mounts are almost the same, infact the bottom end is very similar, some of the casings fit so i put my shiny ones on. The forks bolted straight on aswell.
Wiring is pretty much exactly the same aswell except the CDI wires took some working out.
I have had to make a few spacers and brackets here and there, having a welder deffinately helps, mine is only a cheap 100 quid no gas one and it does the job.
The GPX only cost me 100 quid and all that was missing was the bodywork and clocks etc. So all of the required stuff was there like the radiator, cdi, carbs etc.
2004 Aprilia Tuono
edd
PostPosted: 00:12 - 12 Aug 2006    Post subject: Reply with quote
You liar they're my shit welds Laughing
Bluespark Automotive - Diesel Tuning for Performance and Economy
proximity
PostPosted: 00:22 - 12 Aug 2006    Post subject: Reply with quote
Mine were too shit to warrant a picture.
2004 Aprilia Tuono
chalky143
PostPosted: 10:54 - 12 Aug 2006    Post subject: Reply with quote
looks good...nice bike u got there in the fist place Smile good luck
Current bike :: sv650 minitwin race bike
Previous bikes::cbr600 steelie race bike, 1989 Honda vfr750f, 2013 Honda fireblade, 2013 Ducati multistrata 1200s, 2012 Triumph street triple R, 1999 yamaha r6, vfr 800, ducati 600ss, vfr 400x2, ntv 650, bandit 600, cagiva mito 125, aprilia rs 50, honda c90x2, honda hornet 600x2, cbr 600, aprilia rx50, suzuki katana
My bike pics: https://www.bikepics.com/members/chalky143/
colin1
Captain Safety
PostPosted: 17:57 - 12 Aug 2006    Post subject: Reply with quote
part bike, part bed
cool Smile
proximity
PostPosted: 18:50 - 12 Aug 2006    Post subject: Reply with quote
Its now got a removeable baffle made from part of a VW polo silencer to go with the race can.
2004 Aprilia Tuono
edd
PostPosted: 01:04 - 13 Aug 2006    Post subject: Reply with quote
have you finished the baffle?
proximity
PostPosted: 01:10 - 13 Aug 2006    Post subject: Reply with quote
Almost, it just needs shortening and then the cover pipe welding on, 5 mins jobby. The radiator is mounted too.
I primered the rear wheel then ran out of paint. I need to get some from derrick wards.
All thats left is the can hanger then VROOM.
Heres an updated pic:
https://homepage.ntlworld.com/jason.lovell/project/zeph%20almost.jpg
2004 Aprilia Tuono
DaveH
PostPosted: 09:14 - 13 Aug 2006    Post subject: Reply with quote
Looking good Thumbs Up
The disembodied hand as a radiator hanger is a nice touch Wink
Whosthedaddy
PostPosted: 18:05 - 13 Aug 2006    Post subject: Reply with quote
A stumpy can is a must, its far too long Thumbs Down
Its looking good so far Wink
zephyrgirl
PostPosted: 14:02 - 15 Aug 2006    Post subject: Reply with quote
Hi there, I just realised that you are also on Zephyr Zone!
Saw your pics on there ages ago, but only just found this thread on here!
Great project, well done!
PS I'm Vikki Mc on ZZ.
Fly away on my Zephyr?
I bloody wish.
edd
PostPosted: 20:26 - 15 Aug 2006    Post subject: Reply with quote
Im on zephyr zone too, Im edd on there as well.
proximity
PostPosted: 20:29 - 15 Aug 2006    Post subject: Reply with quote
Hey edd its finished pretty much. Im just waiting for some gasket sealant to dry so i can start it.
The only thing im having trouble with is the coolant tank pipes and where they go.
I think the bottom tank pipe goes to where the radiator cap is (highest point to fill up), and then the top pipe can be an overflow, but there is a pipe left just at the top of the engine where the other coolant outlets are. It is lower than the radiator cap.
2004 Aprilia Tuono
edd
PostPosted: 20:39 - 15 Aug 2006    Post subject: Reply with quote
hmm... Ill come round tomorrow unless you are working and give you a hand.
proximity
PostPosted: 21:34 - 15 Aug 2006    Post subject: Reply with quote
Well its done.
All connected up now. Thing is, the coolant tank must drain into the system somewhere right, but it needs to be higher than the rest. Problem with this is, you cant open the radiator cap because water will pour out.
How do other bikes work?
2004 Aprilia Tuono
The last post was made 19 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.2 - MySQL Queries: 16 - Page Size: 133.47 Kb
