DT 125 de-restricting!
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3  Next
Rocky_mx
PostPosted: 23:44 - 02 Sep 2006    Post subject: DT 125 de-restricting! Reply with quote
What do i need to do to de-restrict a 05 modle dt 125 x?
I need more power....getting boysen power reeds and new exhaust soon! Only ones i can seem to find are dep?? Any more kicking about?
Also what else could i do to get more power Twisted Evil Re-jet with something bigger?
Thanks Smile
Jebus
PostPosted: 01:25 - 03 Sep 2006    Post subject: Reply with quote
try this site it got a load of info www.dtr125.net
2nd time around Smile CBT: 8/9/11
125 Varadero
coarl
PostPosted: 12:00 - 03 Sep 2006    Post subject: Reply with quote
take out catalyzer, drill YEIS on diameter 10mm
PostPosted: 15:07 - 03 Sep 2006    Post subject: Reply with quote
Drill out the thing in the zorst to unlock the heady 18bhp.
dgk13
PostPosted: 21:52 - 03 Sep 2006    Post subject: Reply with quote
My friends got a DT125Re on an 05' Plate. There wasn't any exhaust restriction, only restriction was that the powervavle wasn't earthed out. If its anything like his, there will be a red wire with a hoop at the end no connected to anything. Earth it out my putting it on a bolt on the chassis and then you'll have full power if its like the 05 model. Hope that helps.
Honda powwwwerrrr
Type_Mo
PostPosted: 22:47 - 03 Sep 2006    Post subject: Reply with quote
DO NOT CUT THE MANIFOLD OPEN LIEK IT SAYS ON THAT WEBSITE!!!!
made me lose top end speed Sad
element
PostPosted: 01:46 - 04 Sep 2006    Post subject: Reply with quote
messes with the fuel flow I belive..
Also tail can doesnt make a difference. Swapping the front pipe for a DEP makes a huge difference Ive read. You could get a stock secondhand pipe though, cut it open and remove the restriction which would then make it pretty much like the DEP.
Blocking the cat should in theory help too but one guy said he lost 5mph by blocking the pipe?!
Whats your top speed restricted? Ive managed 65 out of mine and it thats with it screaming. I heard these can do around 85!
Look for the wires going to the speedo. There will be 4 wires going to the block and only 3 wires on the other side going into the speedo. You need to earth that wire thats doing nothing.
Ive heard drilling holes in the snorkel helps too and you can easily tape em up if it ends up running to lean. I would be careful messing around with that though.
You can get Big One exhausts too and they are half the price of the DEP but you get what you pay for.
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Rocky_mx
PostPosted: 18:18 - 04 Sep 2006    Post subject: Reply with quote
Omg! Shocked
Just earthed the wire....and cheapest performance upgrade Razz
Now the powervale actually does something! Very Happy
element
PostPosted: 17:29 - 09 Sep 2006    Post subject: Reply with quote
Rocky_mx wrote:
Omg! Shocked
big difference huh? Very Happy
done mine a little while back. I noticed as soon as I pulled off and pinned it from 3rd. It now pulls all the way to 60 with no flat spots. Power used to die off while the revs carried on climbing. I think it might do more than 65 now but I didnt try. Rear disc was warped so bad the caliper was moving side to side and I started to think what would happen if the back locked..
Also noticed its easier to ride. No longer have to keep inside the narrow powerband so you dont need to keep changing gear.
Hoody90
PostPosted: 19:48 - 25 Sep 2006    Post subject: Reply with quote
will earthing that cable lower the mpg i will get? Obviously if i go faster it will decrease the mpg i get but if i am going at the same speed w/o the earth, will there be a difference in mpg?
element
PostPosted: 18:32 - 26 Sep 2006    Post subject: Reply with quote
well considering I used to change gear at 7k because the power was no longer there and now I can just let it go all the way to 10k yes it will drink more petrol. But at a steady speed say 50mph in 6th then you wouldnt notice a difference. Only time your gonna drink more petrol is going higher into the powerband which you couldnt do before!
if I ride sensibly ill get 110+ miles outta my tank (not inc reserve) were as if I keep it in the powerband all the time im refilling after about 80 miles.
There is a gap of 1 year, 83 days between these two posts...
prawny1
PostPosted: 10:50 - 19 Dec 2007    Post subject: Reply with quote
Where is the red wire located?
hellkat wrote:
Some people are only alive cos its against the law to kill them.
prawny1
prawny1
PostPosted: 10:51 - 19 Dec 2007    Post subject: Reply with quote
element
PostPosted: 15:53 - 19 Dec 2007    Post subject: Reply with quote
take the front light off then look for a connector block going into the speedo. there will be 1 wire in that block that doesnt connect to anything. You need to earth it. I thought it was green or was it brown?!? not red. Been a while now....
I got a big one full system on mine now and it will do 80 maybe a bit more if I really pushed it.. The front pipe was definately restricted as I noticed a bit of a difference when I fitted the big one. Thats an 04 plate though. Im pretty sure the 05/06 and 07 is restricted too..
Willenium
PostPosted: 23:21 - 02 Jan 2008    Post subject: Reply with quote
Presumably the earthing mod has now been carried out to concentrate on mechanical restriction. The airbox snorkel just pulls out and that will help a lot. Get an aftermarket exhaust on and then rejet your carb roughly two sizes up on the main jet.
Power gains using the above will be significant.
c_dug
PostPosted: 13:10 - 03 Jan 2008    Post subject: Reply with quote
a little off topic but if you were to insert a switch into the earth line on the powervalve so that at the flick off a switch you could restrict/derestrict the bike what could the police do if they pulled you over? even if you were riding it derestricted the second you saw the blue lights you could flick the switch and theyd have nothing on you, right?
c_dug
PostPosted: 13:54 - 03 Jan 2008    Post subject: Reply with quote
c_dug
Wrong.
It's probably worse to have the switch than to just have it de-restricted as you're trying to pervert the course of justice or something.
The same way flip up plates are worse than just having a small one.
If the contraption is found that is.
ghettostan
PostPosted: 14:32 - 03 Jan 2008    Post subject: Reply with quote
c_dug
the police never check the power of the bike anyway....
i got pulled over by a police on a motorbike and he dint ask if it was restricted or anything along them lines...
PostPosted: 15:33 - 03 Jan 2008    Post subject: Reply with quote
ghettostan wrote:
c_dug
Yeah they do sometimes, people have been done. Someone in the SE section was done quite recently. Although that was the 33bhp thing.
PostPosted: 18:45 - 04 Jan 2008    Post subject: Reply with quote
Big_Ham wrote:
c_dug
Wrong.
Yes and then you just say in bad weather I turn the powervalve off so that I have reduced power thus meaning my wheel doesn't spin. Very Happy
EDIT: It would be handy if you were doing your test on your own bike as you could ride there restricted and when you've passed, flick your switch and wheelie away Very Happy
All in my wonderful fantasy.
element
PostPosted: 15:44 - 06 Jan 2008    Post subject: Reply with quote
the back wheel wont spin unless ur riding like a twat in the rain (how do I know that? Mr. Green )...
just earth the wire and forget.. Mr. Green
DT125SM
PostPosted: 00:04 - 11 Jan 2008    Post subject: Reply with quote
Howdy guys Very Happy
I have read this post with great interest.
My friend has a 2006 Yamaha DT125X SM.
I had a go on it and it was no where near as quick as the 1990 DT125R I had back in the day.
So today we de-restricted it bu cutting the green/brown wire and by adding more wire we rigged it up to the negative terminal of the battery.
Also we took off the airbox snorkel completley.
The result ? sounded deeper when the bike started, pulling off it wants to bog down, defo sounds better but might put the snorkel back on at least until he can get a K&N air filter in there.
We took the bike to a LONG duel carridgeway to see what we could get top speed... and the most we could get outta it ...
78mph ... Rolling Eyes
Now my old DT125R went off the clock at 85mph so how come this one is only gettin 78mph ?
Is there anything else we can do to it guys to make it quicker and a better top end ? or are these the only two mods available for his 06 model.
Oh its got a DEP sport exhaust on it too.
Many thanks.
Matt Smile
ghettostan
PostPosted: 16:12 - 11 Jan 2008    Post subject: Reply with quote
element wrote:
are you sure?
i ride mine normal most of the time, chaging gears when it reaches around 6000rpm any higher than that on mine would hit the powerband ? but still i have to refill every 70/75 ?
and around 90/95 with reserve
i have a DT125 R 2001 by the way
Willenium
PostPosted: 15:13 - 12 Jan 2008    Post subject: Reply with quote
Hence why I stated that rejetting may be necessary. My bike ran well enough before I fitted the new jet but it definitely took less finesse to get it revving afterwards. Fitting a K&N will not help you in any way and you're better off sticking with the original airbox and just increasing the main jet size.
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 16 - Page Size: 140.42 Kb
