jim-cr 250 Nitrous Nuisance
Posted: 11:21 - 16 Sep 2006 Post subject: powervalve question (dtr) help |
hello,currently my 1994 dtr 125 has the powervalve set to fully open all the time and is starting to get a bit annoying because the bike takes a while before actually hitting powerband and when it isnt in powerband it is very slow,but when it is its quite quick.
so the question is how do i turn it down and is it easy and how far should i turn it down?,i dont know much about power bands so any would be very appreciated. thanks
Jebus Brolly Dolly
Posted: 18:48 - 16 Sep 2006 Post subject: |
Hiya, First off i got the same bike but my bike is the first model that came with the powervalve working, i.e it is fitted with the servo motor and mine is a 98 model, all previous models had the powervalve fitted but it was just sat there left open so it was of no use for what the thing was designed for.
It really amazes me that people do this yamaha spent a lot of time effort and money designing the powervalve and them people jam them open thinking thats better. The power valve restricts the flow at lower revs and this helps the bike produce a bit more power and smooths out the power at lower revs and after 7kish revs when it opens up it stops restricting the flow and then the bike can breath fully because after these revs the engine doesnt need the gas flow to be slowed down it all sorts its self out. Sorry i dont really know vast amounts about the little gizmo but a few guys on here will give up more information, most of what i got above should cover what you need to know about the valve
First it will depend on what year your dt is but you will need the servo motor and cables to connect the motor to the powervalve and other stuff as well i would imagine and then its setting it up as per haynes manual.
The "powerband" is a term that applies to the "band" of revs that produce the power on a engine, and most 2 strokes have a very narrow band in which this happens and it normally is quite a jump from the power produced outside of the band, this is what makes 2 stroke engines "peaky". ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
KatOwner Nova Slayer
