| Author |
| instigator |
 instigator Super Spammer
 Posted: 21:50 - 26 Jan 2009 Post subject: Bandit 1200 Assistancé |
More or less just bought a 1997 Bandit 1200. It's an import, bought from D&K. It has a km/h clock but a blue whatchamacallit it fitted between the speedo cable and the clocks making me think it converts it into MPH...
Great bike, having an absolute blast on it, feels like a much more practical machine than a sports bike around London for sure.
Anyhoo...a few points I've noticed on it.
- Once it's warm, it spits and gargles not only on the over-run but also at idle...not 24-7 but pretty frequently. This will be down to the viper race can on it most likely.
- Take off from the lights isn't very smooth - the fueling is obviously off and is only smooth after 2.5k. So I have to overcompensate with the throttle a bit.
- On idle and low rpm in 1st, it occasionally makes a "tsssst" noise like air escaping and the revs drop a slight amount...to a more normal level. The revs don't drop down from 2k-1.4k as quick as they should really. Since it's occasional and only generally at idle, I suspect it's not an air leak from the downpipes.
I understand that the original bandit exhaust strangles the machines power and that by slapping on an aftermarket can, like the previous owner has done, can release a few bhp. I want to sort the fueling out myself and wish to know the best approach to take. Strip the carbs apart and find out what size of jets it has, upgrade/downgrade them and then balance the carbs? For all I know, it could be jetted for a full system.... I may perhaps remove the viper can and slap on twin stubby cans, depending on how secure I feel my job is this month.
I imagine the fueling will be just as bad with them on but the theory behind the work will still be the same. Only thing I don't intend to do is to chase more bhp, I'm happy with it's power delivery as it is so don't want to faff about with a dealer, fitting dynojet kits if I don't have to.
Any suggestions? |
| Back to top |
| Keir |
 Keir World Chat Champion
 Posted: 22:17 - 26 Jan 2009 Post subject: |
my suggestion:
leave bike as it is and pay mr dyno man £250 to sort the fueling properly. not only will this save you the hassle of faffing with needles and jets, but he will have the equipment to measure air/fuel ratios properly. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Back to top |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:40 - 26 Jan 2009 Post subject: |
Race can and a dynojet kit on a 1200 Bandit should see 115~120hp with a pretty decent power delivery.
Pretty much agree with the above comment of spending a bit getting it set up on a dyno. Although well worth checking things over first (eg, check the pipe for the vacuum tap is not split, the carbs are seated properly, float heights are OK and the diaphragms are in decent condition).
| Back to top |
| instigator |
 Posted: 23:00 - 26 Jan 2009 Post subject: |
To be honest, if paying £250 for someone else to set it up is the only way to sort it out, I'd rather return it to standard by buying the OE can and putting that on. But then again, I don't know what the bike is set-up for...?
As you can tell, power gains, I couldn't care less about. I like the noise but it isn't worth £250 to me. I'd rather faff.
Suppose I could always look out for a 2nd hand set-up, carbs with dynojet kit fitted and with a can and sell of the parts that I have.  |
| Back to top |
| NiteMare |
 NiteMare Spanner Monkey
 Posted: 00:22 - 27 Jan 2009 Post subject: |
| instigator wrote: | To be honest, if paying £250 for someone else to set it up is the only way to sort it out, I'd rather return it to standard by buying the OE can and putting that on. But then again, I don't know what the bike is set-up for...?
which will probably cost you at least half of the 250quid with no guarantee that it'll run any better than now ...
dynojetted 36mm bandit carbs generally go for 100quid plus, if your local dyno operator is any good he will be able to set your carbs up for no more than 200quid (unless there's other problems)...
if you're in/around Birmingham i recommend you going to DynoTorque and having a word with Craig, he's set up 2 of my mates B12 engines, the last one gave a reading of 124.6bhp once he'd fettled it, no airbox/filters, 4-2-1 exhaust with a stumpy can
do it once, do it correctly ____________________ it ain't broke...
i ain't fixed it enough |
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 00:54 - 27 Jan 2009 Post subject: |
If it already has a dynojet kit the emulsion tubes might be worn oval. Common on the bandit 12 as I understand. ____________________ a.k.a 'Geri'
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| NiteMare |
| Back to top |
| Finglonga |
 Finglonga World Chat Champion
| Back to top |
| instigator |
| Back to top |
| NiteMare |
| Back to top |
| chris-red |
| Back to top |
| Finglonga |
| Back to top |
The last post was made 17 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
