| Author |
| robocog |
 robocog Traffic Copper
| Back to top |
| The Artist |
 The Artist Super Spammer
| Back to top |
| baldy |
 baldy World Chat Champion
| Back to top |
| Raffles |
 Raffles World Chat Champion
| Back to top |
| temeluchus |
| Back to top |
| EnergyInducti... |
 EnergyInducti... Crazy Courier
| Back to top |
| robocog |
| Back to top |
| finpos |
 finpos World Chat Champion
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| baldy |
| Back to top |
| Alexio |
 Alexio World Chat Champion
| Back to top |
| Robby |
 Robby Dirty Old Man
 Posted: 16:54 - 12 Jan 2010 Post subject: |
From my GCSE and A level (shaky) understanding of capacitors, they take a while to charge and then discharge it all very quickly. I'm not sure if you can partially discharge one without clever electrics.
It seems that your reasoning for a capacitor is to protect the reg/rec and therefore protect the rest of your bike electrics, by having something in the circuit to soak up any spikes and give you some buffer. A resistor may do this.
However, have you ever ridden a bike with no battery on a dark night and braked for a corner? Your headlights go extremely dim. Your battery stops that happening.
Have a look for a very small, rechargeable 12v battery if you really want to save every last gram. I assume you have already fitted a light single seat and cut the frame back, removed the centre stand, ditched rear footpegs, ditched bodywork, drilled holes in things, fitted lightweight indicators, chopped down the front mudguard, ditched the mirrors and cut down the chain guard. |
| Back to top |
| robocog |
| Back to top |
| smegballs |
 smegballs World Chat Champion
| Back to top |
| finpos |
| Back to top |
| finpos |
| Back to top |
| smegballs |
| Back to top |
| Alexio |
| Back to top |
| finpos |
| Back to top |
| smegballs |
| Back to top |
| Raffles |
| Back to top |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:05 - 13 Jan 2010 Post subject: |
Not sure where it came from, I think it was one of the Royal Enfield sites I'd visited, but here's the contents of a text file I had squirrelled away :-
| Quote: | Battery Eliminator
Tired of replacing the battery or acid leaking on your pipes? Replace it with a 50,000-mfd, 16VDC computer grade capacitor.
What to do:
1. Remove battery.
2. Wrap capacitor in ¼” to ½” foam sponge rubber extending over each end of capacitor and tape it so it will not come off. The foam should be thick enough so the capacitor is a snug fit in the battery box.
3. Connect the black lead (-) to a clean tight ground. Remove paint and use serrated washer under ground lead bolt.
4. Connect the red lead (+) as the battery hot lead was connected.
Installation test:
1. Turn lights off.
2. Start bike and run for at least one minute.
3. Turn bike off.
4. Turn ignition on, neutral lamp should light for 5 to 15 seconds. (Capacitor should hold this charge for days)
System check with bike running:
1. Connect voltmeter across ground and capacitor hot lead.
2. At 1500 RPM or above, voltmeter should read 13-15 volts with a steady meter, that is, the reading should not change or bounce around.
3. With the lights on, voltage should be 12 volts or above if RPM is 1500 or above.
4. At 1500 RPM or below, voltage will drop if turn signals or brake light are used.
Note: If voltage readings at 1500 RPM are above 16 volts or below 12 volts, the voltage regulator is probably defective. This also causes short bulb life.
The battery eliminator solves a number of problems:
1. Battery acid leaking on pipes, wheels, etc.
2. Frequent battery replacement due to vibration.
3. Elimination of battery weight.
4. Voltage swings of defective battery resulting in weak spark, CDI failure, light failure, etc.
Disadvantages of battery eliminator are:
1. Lights won’t work if bike is not running.
____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Back to top |
| finpos |
| Back to top |
 . Renault 5 Driver
 Posted: 15:18 - 13 Jan 2010 Post subject: |
Robocog,
If you have 12volt electrics, then speak to someone like boyer bransden about their powerbox. They probably have something suitable for your needs.
I have one and don't require a battery. The only downside is my bike stays running after switching off the engine as mine is connected directly to the coil. Either an ignition cut out switch, or a decompressor (which is what I have on my engine) is advisory. |
| Back to top |
| robocog |
 Posted: 17:24 - 28 Jan 2010 Post subject: |
Managed to scrouge some sealed 12v batteries from a mate who I mentioned my idea to.... and they are bigger and heavier that the CG's original
so back to the original plan...
Just ordered a 33,000uF 40v DC cap and will report back when it arrives
I guess it may not be as effective as the 50,000-mfd mentioned in The Shaggy D.A.'s post, but has a safer voltage safety margin?
Not sunk too much money into it and cost less that a good firework, so if it does go bang hopefully it will at least get captured on video and will make a good "how NOT to do it" for youtube
Looked at the Boyer units, bit too pricey for this project as it costs roughly what the bike has cost me in total so far!
Regards
Rob |
| Back to top |
The last post was made 16 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
