Bedding in brake pads?
Itchy
PostPosted: 13:49 - 11 Jan 2007    Post subject: Bedding in brake pads? Reply with quote
How long/miles does it take to bed in brake pads? , mine are looking a bit low but I don't want to change them like a day before the MOT test (last time I changed them 3 days before but managed 270 miles before taking it into MOT which it passed) .
Any suggestions?
Bike:
Single front disc , single rear disc , NTV,
Also
ZX6R 2001 model
Ta
Davo
Davo To The Rescue!
PostPosted: 14:29 - 11 Jan 2007    Post subject: Reply with quote
I usually try and take it easy for about 50-100 miles, although on the R6 I bedded the pads & disks in on the race track within about 5 laps of Snetterton.
Dan 4RR
PostPosted: 15:58 - 11 Jan 2007    Post subject: Re: Bedding in brake pads? Reply with quote
You've bought a ZX6R or wanting to know for when you get one?
Humans....the largest form of cancer the world has ever seen!
Speed Cameras - Putting goverment revenue before public safety!
Paddy Blake
PostPosted: 17:31 - 11 Jan 2007    Post subject: Reply with quote
I use sand paper and sand the disc from the middle out and in.
If the disc is worn sand the edge of the inside and outside of the pads.
paddy.
MattEMulsion
PostPosted: 22:18 - 11 Jan 2007    Post subject: Reply with quote
Just fit them and take it easy on the brakes for the first couple of hundred miles. You want them to bed them in gently and not get them too hot straightaway or they will end up glazing over. Even with new pads in and a half decent disc it should sail straight through the MOT with very little bedding in. Very Happy
Yamaha YZF-R6
Trip
PostPosted: 11:10 - 13 Jan 2007    Post subject: Reply with quote
Surely none at all?
If the testing center replaced them they wouldn't bed them in before they passed it would they?
Bike: Yamaha XJ600N Mileage: 28500 Miles Rider Mileage: Many Miles
CBT: PASSED Theory: PASSED Test: PASSED
Past-CG125 Present - Yamaha XJ600N Future - WHO KNOWS?
Itchy
PostPosted: 22:49 - 13 Jan 2007    Post subject: Reply with quote
Hmm righteo then , I'll change em a week before and my 300 odd mile weekly commutes should bed them in nicely!
Thanks
Nath
PostPosted: 22:57 - 13 Jan 2007    Post subject: Reply with quote
The MOT braking tests are not difficult to pass. Infact it's very rare to here of anyone failing for poor braking performance. Binding brakes yes. Leaking hoses yes. Cracked discs yes. Poor performance no.
Hard livin', hard luck.
PostPosted: 14:57 - 14 Jan 2007    Post subject: Reply with quote
Its a function of braking power versus the weight of the bike. The lighter the bike, the less good the brakes have to be. On a ZX6 you won't have an issue.
Didn't Keith's Bimota fail the MOT on braking performance?
Nath
PostPosted: 04:12 - 15 Jan 2007    Post subject: Reply with quote
The front brake on my cb550 is lethal, really attrociously bad. If you've only ever ridden modern style bikes you wouldn't really understand. It is not a lightweight bike either. Still passed its MOT well within the margin for brake performance.
Zimbo
PostPosted: 15:43 - 15 Jan 2007    Post subject: Reply with quote
Not necessarilly totally applicable, but this is the correc t bedding in procedure for race pads (off performance friction's site).
Bedding in procedure
Correct bedding in procedure can increase pad and disc life.
First, ensure the disc is clean and free from any other pad manufacturer's material before using our pads, other manufacturer's pads can leave an uneven transfer layer on the disc and cause bedding in problems.
The rider should build temperature in the disc and pad gradually over approximately 4 laps. Once our pads are fitted and the rider is ready, conduct an out lap at about 50% normal speed and apply brake pressure in the normal way (do not keep hold of the lever in an attempt to induce heat in the pads, this will thermally shock the pads and cause them to glaze).
Then conduct a further 2 laps progressively increasing the speed and lever pressure. The fourth lap should be at full speed and normal brake pressure.
The bike should then be brought into the pit, making sure to conduct at least two heavy brake applications with even brake pressure, this helps to create an even transfer layer of material on the disc. Then let the brakes cool for at least 5 minutes, this ensures the pads and discs have heat cycled in a controlled manner that helps prolong disc and pad life.
The brake pads are then ready to use at full race pace, remembering to generate heat into the pads on the out lap.
element
PostPosted: 16:41 - 15 Jan 2007    Post subject: Reply with quote
paddy.
i use wet and dry taped to a mirror and then rub the pad down a little so the pad surface is perfectly flat and the shiny coat is removed. I find this way my pads dont need wearing in at all and of all the ebc pads ive had, they have all been concave..
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 76.87 Kb
