A 'Blueing' Exhaust
haGGard
PostPosted: 23:25 - 19 Feb 2005    Post subject: A 'Blueing' Exhaust Reply with quote
Hi,
I was just wondering what exactly does a blueing exhaist mean? My exhaust is chromed and i have noticed that near when it joins to the engine, (Gasket? Confused ) The chrome has turned a shiney bluey, purple colour.
Is this damaging or anything serious? Shocked
Cheers Thumbs Up
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
TheShaggyDA
Repost Police
PostPosted: 23:27 - 19 Feb 2005    Post subject: Reply with quote
If your pipes blue repeatedly or very quickly, it can be a sign that the air-fuel mixture or timing is out of whack. An over-rich mixture can cause a blue spot to appear far down the pipe or muffler where the unburned gas ignites on a baffle or hot spot. A very lean mixture or timing that is too advanced can cause pinging and the extra hot motorcycle exhaust gas can cause the pipe near the head to blue severely. Malfunctioning advance weights or a module that doesn’t advance will blue the pipes, but by that time your pistons will need replacing
Not good.
instigator
just the way stainless steel goes Thumbs Up Mines a dingy brown/yellowy colour
well, mine are okay for being brown/yellow apparently. dont know what lue means
haGGard
PostPosted: 23:45 - 19 Feb 2005    Post subject: Reply with quote
Shocked Shocked It could be running lean i guess, since it was not upjetted since fitting the exhaust, though i have never checked the plug, and that was 5 months ago Shocked
Are 'advance weights' referring to the rollers in the variator? My rollers a way to light at the moment which is causing the engine to rev higher at slower speeds (but acceleration is great Razz ).
PostPosted: 23:50 - 19 Feb 2005    Post subject: Reply with quote
It is usually just a sign that you have been riding the bike hard (as nature intended) I love a nicely blued header pipe Smile
If it has happened suddenly then you may have an issue that is causing the engine to run too hot. That said, I have seen the headers on my mates SOHC Z650 glowing red after a good hard blast on a dark night and there was nowt wrong with that other than excessive twisting of the right wrist Mr. Green
EDIT: Having just seen your post above.
1) CHECK YOUR PLUG!
2) Advance weights is referring to a centrefugal ignition auto-advance. In the unlikley event that your bike has these (they are on points ignitions), they very rarely malfunction. I have never heard of it. Your bike will have any ignition advance mapped into the CDI.
TheShaggyDA
Repost Police
PostPosted: 23:53 - 19 Feb 2005    Post subject: Reply with quote
Advance weights alter the timing of the spark dependant on engine RPM. Unlikely you've got them, as I'm guessing you don't have points ignition.
haGGard
PostPosted: 00:14 - 20 Feb 2005    Post subject: Reply with quote
Thats ok then Thumbs Up I have no idea what a points ignition is Laughing
I will try and check my plug tomorow...
bish777
PostPosted: 08:16 - 20 Feb 2005    Post subject: Reply with quote
This is perfectly normal for a single skinned exhaust pipe, and especially a single skinned zorst on a 2 stroke.
GSXR1100J
GOKU
PostPosted: 09:08 - 20 Feb 2005    Post subject: Reply with quote
the real reason water...the pipes turn that colour due to high heating and water....rifeing ur bike to this point and heat means that it will rust from the inside out.
always ride in moderation dont tan it every where you go..and give your bike plety of cooling down times when on ride outs
this isent a serious problem theres nothing you can do about it its just one of those things that happen..make SS look better IMO
mchaggis
PostPosted: 13:43 - 20 Feb 2005    Post subject: Reply with quote
Pish I say! Razz Wink
Your pipes are going to rust from the inside out no matter what you do, if they're not alloy, titanium or some brands of stainless. The water, heat and acidic combustion products all add up to a pretty corrosive mixture. As far as riding in moderation so that your exhaust pipes don't get blued up, personally I think blued up exhaust pipes looks nicer than gleaming virgin chrome. Shifty
I must not be a troll...
Mmmm, Guinness
Adam_P
PostPosted: 16:03 - 20 Feb 2005    Post subject: Reply with quote
I thought that the bluing was a form of tempering, which is just the metal heating up and cooling down again.
It's just what steel does when put into that kind of heat, isn't it?
Sounds like we need Kickstart to give the right answer...! Thinking Laughing Wink
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
mchaggis
PostPosted: 16:16 - 20 Feb 2005    Post subject: Reply with quote
It is, just like steel. It's caused by high temperatures -> oxidisation. Running lean will cause excessively high temperatures as well as advancing the spark too far.
Just rag a bike with a high enough compression ratio and a lean enough burn and the chrome will blue when it gets hot enough.
Silver will go blue as well as black if you let it oxidise in the same fashion.
Mmmm, Guinness
bish777
PostPosted: 22:02 - 20 Feb 2005    Post subject: Reply with quote
It will happen on a normal bike in normal conditions with a single skinned zorst! God it doesnt necessarily have anything to do with running lean. Jeesh what a bunch of doomsayers you lot are.
My MZ carburetted perfectly, as did my XBR500 (which i ran a little rich if anything) and the zorsts on those blued off, OE on the MZ (yes i hada aBRAND NEW MZ!) and micron on the XBR.
GSXR1100J
mchaggis
PostPosted: 23:41 - 20 Feb 2005    Post subject: Reply with quote
Note I said lean enough Wink If you run rich enough, it just won't happen.
Mmmm, Guinness
Will87
PostPosted: 00:18 - 21 Feb 2005    Post subject: Reply with quote
I can't remember if this works for either Stainless Steel or Chromed pipes, but a rag with a little bit of light oil on it rubbed over the blue areas when the pipes are hot is meant to get rid of the blueing.
mchaggis
PostPosted: 00:23 - 21 Feb 2005    Post subject: Reply with quote
I wouldn't be too sure about that one, for a start it involves rubbing oil on hot exhaust pipes, which doesn't sound like a good idea to me at least.
I should think you'd need a proper metal polish, not one which just gets rid of the grease and muck. (Eg Silvo, Brasso). They seem to work on most metals I've tried.
Mmmm, Guinness
Will87
PostPosted: 00:27 - 21 Feb 2005    Post subject: Reply with quote
mchaggis it's what i've heard recommended from my dad's friends (50 odd guys been bikers since they were 16/17). Just passing on the info, never tried it myself as i have not had the need. Besides oil on the exhaust pipe isn't bad, it just creates a bit of a hot oil mist. . . .
binge
Emo Kiddy
PostPosted: 00:40 - 21 Feb 2005    Post subject: Reply with quote
Dont worry about it mate. Its just the chrome. My techniwank hasnt done it because its a laquered finish (Rusts like a biatch) but my mate who has the same setup as me has a chrome pipe and the header pipe has gone blue.
It will eventually work its way further up the header pipe towards the expansion chamber where it will stop because theres not enough heat in the expansion chamber.
Nothing to worry about.
And if it does rust off, Get a new zorst Wink
They arent that expensive...
<|Ben|>
[edit] Oh shit, Forgot uve got a SF 100 Embarassed [/edit]
Mr C
PostPosted: 13:41 - 21 Feb 2005    Post subject: Reply with quote
pah
my pipe glows cherry red all the way from the headers to the can if I leave it running and not moving
Titanium see and only about a mil thick
it's gone a luvverly blue gold colour now Cool
187.3bhp = 201mph
TheShaggyDA
Repost Police
PostPosted: 13:50 - 21 Feb 2005    Post subject: Reply with quote
If you'd switched to a new exhaust and got blueing, you'd at least bother to check the plug, wouldn't you?
robboadd
PostPosted: 14:53 - 21 Feb 2005    Post subject: Reply with quote
Is this blueing or is rossi just being a tart? Smile
Mr C
PostPosted: 15:13 - 21 Feb 2005    Post subject: Reply with quote
looks the same as mine
= Titanium Wink
187.3bhp = 201mph
Adam_P
PostPosted: 16:41 - 21 Feb 2005    Post subject: Reply with quote
Steel ones look like this if you leave something running long enough. Wink
God is imaginary
Mr C
PostPosted: 17:01 - 21 Feb 2005    Post subject: Reply with quote
hehehehe
that's the way Cool Laughing Laughing Laughing
187.3bhp = 201mph
Adam_P
PostPosted: 22:27 - 21 Feb 2005    Post subject: Reply with quote
That's just the warm up to get the bloody water temperature up about an hour before a race. Apparantly they turn translucent when they thrash the shit out of it on the dyno when it's been rebuilt. Shocked
It's a bit blurry as it's fookin hot leaning over the back of the car when they're like that! Laughing
I'd like to get a snap of them after it comes in after a qualifying run, but I'd never get near the engine bay quickly enough to see them at that sort of heat.
Saw the turbo's on a Porsche 935 glowing almost white during the evening race at Bahrain though, kept us in hysterics every time it came past the pit wall in the dark! Laughing
God is imaginary
The last post was made 21 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.25 - MySQL Queries: 15 - Page Size: 132.46 Kb
