| Author |
| 0ni |
 0ni World Chat Champion
| Back to top |
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 21:08 - 05 Jun 2006 Post subject: |
PM marjay the link to this thread
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| Back to top |
| MarJay |
 MarJay But it's British!
| Back to top |
| MarJay |
 Posted: 21:59 - 05 Jun 2006 Post subject: |
Ok.
Build quality is good, but not as good as a Honda. Probably a fair sight better than most suzuki's though! The finish is nice, but lacks attention to detail. There are wires hanging out all over the place in the dash for example.
Maintenance needs to be done often, even on the fuel in frame models. The Tube frame models were worse for this though. The official service intervals are every 5000 miles, but if you commute on one, or ride in winter (ambient temp of less than 15 degrees) then you are supposed to change the oil and filter every 1500 miles. Tranny oil is supposed to be done evey 10k miles but both are easyish jobs. The valves have hydraulically adjusting tappets and so I guess they never need attention.
The exhaust silencers are known to rust if you sneeze on them, but most people go for aftermarket silencers anyway.
The Belt drive is a godsend, but they do have a primary chain drive inside the transmission that gets the power from the gearbox to the belt. This swims in a bath of transmission oil and (afaik) only needs to be adjusted occasionally. The belts are supposed to last around 15k miles. The rear wheel is always in line because it can't be adjusted like a chain driven bike.
Mine has done just over 7500 miles, and doesn't miss a beat. Occasionally when you haven't ridden it for a while the time clock resets when you hit the ignition switch, but it has never failed to start for me.
Fuel wise I get about 90-100 miles to a 'tank' (frame full). This equates to around 36-38ish mpg.
The brakes are excellent, probably the best brakes on any bike I have ridden. Loads of feel and a great deal of power. The bike handles very well, and is surprisingly good in town because it has a wide bar conversion. With all of the rotating mass of the engine it is very easy to balance at low speed despite the engine being very lumpy at low revs. Headlights are good to fair, and the underseat space certainly isn't the smallest I've seen on a bike.
The main downsides that I can see to Buell ownership are:
The fact that some of the fasteners are imperial, and some are metric.
The tank range isn't great, but its acceptable
It makes me ride like a bit of a loony. Not high speed, but wheelying and stoppying lots. This may be a plus point too!
some of the maintenance tasks are very hard indeed, for example if something breaks in the gearbox, then its engine out and a full stripdown.
No other bikers nod at you any more. Cos they are all snobs.
The main advantages are:
It flatters my riding, I can ride round corners faster on this bike than I have on nearly any other bike
Everyone looks at you when riding it, especially with a loud exhaust.
The owners manual tells you what settings to give the suspension for your weight and riding style.
Some bits of maintenance are unneccesary. No coolant to change, no exposed chain to lube, and no need to adjust the valves.
Its hard to ride over 90mph. Doable, but hard. Will save my license on motorway journeys!
The bike isn't really a logical posession of mine. Its very much something that you just say "I've got to get me one of these!" and then you buy one. It isn't really practical, and they do have a reputation for going pop. But it is such a hoot!
HTH.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Back to top |
| MarJay |
| Back to top |
| 0ni |
 Posted: 22:03 - 05 Jun 2006 Post subject: |
Cheers MarJay Did you get a chance to test ride any of the 980cc buells before you got the 1200? Is there a noticeable difference? ____________________ Its a lovely day, just wait until some bastard spoils it. |
| Back to top |
| Hotdog |
 Hotdog Nearly there...
| Back to top |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
| Back to top |
| Hotdog |
| Back to top |
| MarJay |
 Posted: 23:33 - 05 Jun 2006 Post subject: |
| Hotdog wrote: | The Good bits:
If you don't replace the engine breather (valve type thing) with an aftermarket one - they spew oil everywhere if you rev them. | Never heard that. Mine has never done it and I'm always on the limiter. My oil is even slightly overfilled. It has not done this.
| Hotdog wrote: |
The engine and gearbox are antiquated junk and the rear wheel locks every time you downshift during 'spirited' riding. |
Actually the fuel injection is set up so that the bike revs up again during harsh engine braking. This is why you have to use the brakes when you let off of the throttle in first gear. Sure, you can change down three gears and dump the clutch, but then you'd be riding the thing wrong. The engine braking on downchanges was much much worse on my Triumph Daytona 955i and even on my old SV650. The engine is based upon an older harley design, but has extensive modifications. It doesn't share a great deal with the 1200 sportster engine despite being based upon it. If you like that sort of thing, then you buy that sort of thing. Simple aint it?
| Hotdog wrote: |
They overheat often and the huge car fan is on constantly throughout the summer months.
| Mine hasn't overheated, and I commute on it every day in heavy traffic. Sure, the fan comes on - but thats what it is designed for. I'd be a bit bloody worried if it didn't come on!
I'd be surprised if it comes on more often than the radiator fan on my old TT600, or my Daytona 955i.
Please base your opinions in a thread about living with a bike on (surprise surprise) living with a bike!!
One test ride may be enough to form an opinion, but living with the bike is what 0ni asked for, and living with the bike is what I have given him.
If you'd rather he bought a CCM R30 then fine, but don't out and out lie to the feller just because you have some sort of grudge.
If you have a CCM R30, then I'll happily go to a RWYB with you and prove that the Buell isn't a slow bike. You have already condeded that the Buell has an excellent chassis, and I believe on a trackday the rider may provide more of an advantage or disadvantage. I would however consider letting G or someone do a lap on the CCM then a lap on the Buell, but this seems like a bit of excessive effort to go to, to prove a point.
Additionally you might also note that the reliability issues are mainly with the Blast! US only models, whose engines are closer in design to the R30 engine than the XB or tube framed 1200 models.
I don't care about the reputation, I don't care that it has an engine based upon an old design. The CCM R30 has a Suzuki single that can be traced back to some very early four stroke suzuki trailies.
What I care about is that it starts on the button, goes quick enough to beat any car you are likely to mention, (and a hell of a lot of bikes) and makes me smile. Ultimately that is what bikes are all about.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Back to top |
| Hotdog |
| Back to top |
| MarJay |
| Back to top |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Back to top |
| Hotdog |
| Back to top |
| MarJay |
| Back to top |
| Hotdog |
| Back to top |
| Hotdog |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 Posted: 00:02 - 06 Jun 2006 Post subject: |
Marjay:
https://www.dirtysanchez.co.za/blogimages/nobs_110705.jpg ____________________ He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
Hotdog....(Defender of the weak, the poor and the innocent)
He's The Ace - He's Amazing...He's the Strongest... He's The Quickest.... He's The Best! |
| Back to top |
| alien.46.uk |
 alien.46.uk Could Be A Chat Bot
 Posted: 00:04 - 06 Jun 2006 Post subject: |
Didnt read it all so dunno if its been said but they have a very short wheelbase, good for city use, top cornering ...
I went to the harly HQ for the UK and they let me sit on one and i looked silly on it, its soo small
Then sat on a HD Fatboy and WOW the difference is hudge ...
But man there UK HQ is amazing inside every door is glass and slides with a little tap of your little finger and thats with 3m wide 3 tall double glazed glass ... all chrome and each individual office has a harly in each on the floor up on a wall at an angle ... WOW
But as to the Buells they are real short  ____________________ 2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD |
| Back to top |
| MarJay |
 Posted: 00:22 - 06 Jun 2006 Post subject: |
Anybody can post an amusing picture Hotdog, but your 'real world experience' still hasn't appeared anywhere. Your arguments seem to consist of trying to find small weaknesses in existing posts and battering people over the head with them until they submit.
https://i.cnn.net/cnn/2003/US/07/04/july.fourth/story.hotdog.pose.jpg
| Back to top |
| Hotdog |
| Back to top |
| byke95 |
 byke95 World Chat Champion
 Posted: 10:26 - 06 Jun 2006 Post subject: |
Hotdog: put your ego to one side and re-read this thread.
Oni asked 'what are they like to own'?. Marjay's tries to give a clear and balanced view as he doesn't shy away from what some may not like. Compared to Marjay's account of his experiences with his Buell, it is not even clear if you have owned one, or even ridden one (I can only presume you have).
Share your experiences by all means but arguing opinion is not going to help Oni make an informed choice.
Oni: Which Buell are you thinking about getting/test riding? I do like the look of the City X!  |
| Back to top |
| Keen |
 Keen World Chat Champion
 Posted: 11:28 - 06 Jun 2006 Post subject: |
I love the look of the Buell's, I would just find it hard to justify buying one, no good 2-up, expensive, no luggage space, cramped. If I could afford a fun bike for the weekend though, I'd be tempted by a funky buell.
They definately have something, but buying one is a heart over head decision (not necessarily a bad thing)  ____________________ "he who makes a beast of himself gets rid of the pain of being a man"- Dr. Johnson |
| Back to top |
| extreme3d |
 extreme3d World Chat Champion
| Back to top |
| MarJay |
| Back to top |
| Keen |
| Back to top |
The last post was made 20 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
