honda cg125 oil
custom-biker
PostPosted: 23:28 - 08 Dec 2007    Post subject: honda cg125 oil Reply with quote
is semi sythetic oil ok for this engine 10w 40?
is you can turn you aint goin fast enough.
Jamie S
PostPosted: 23:43 - 08 Dec 2007    Post subject: Reply with quote
That will be fine , it takes 0.9ltr's.
virus
PostPosted: 10:43 - 09 Dec 2007    Post subject: Reply with quote
wrong, 1 litre, 1.1 litres on rebuild.
John
own: 81 xs1100g...
learnerbiker
PostPosted: 23:10 - 09 Dec 2007    Post subject: Reply with quote
how do you change the oil on the cg? where is the filter? where do you put the new oil in? I'm guessing in where the dip stick is? Need to change mine too soon.
I ride a divvy 600 Smile
Jamie S
PostPosted: 13:46 - 10 Dec 2007    Post subject: Reply with quote
I'm not going to retype what I wrote in another thread so here is the link and a quote.
https://bikechatforums.com/viewtopic.php?t=132587
xr's only have one drain plug , its on the left hand side as you sit on the bike , under the gear leaver and to the left a bit , it's a 24mm cap with a re usable rubber seal , under the cap is a spring and a gause thimble. I hope you cleaned any bits of swarf off the Thimble ?
Then it's just a case of putting the cap back , be carfull not to cross thread it , they break REALLY easily and will set you back £5 each.
If you do ever fuck the oil drain cap up , remove one of your tappet caps and put the oil drain one on the tappet and tappet one on the oil drain, then get to a garage and sort it out properly. (that is a "get you to the garage only" type bodge btw.
Xr's use the same engine casings as a cg.
virus
PostPosted: 16:08 - 10 Dec 2007    Post subject: Reply with quote
sorry to shoot you down in flames again on the same thread but your wrong again, the oil drain bolt is directly at the bottom of the engine with a metal stub to the front of it to give some protection, if i recall its a 17mm head. you need to take out your dipstick, get a drain can under it then remove the bolt, then once its done put the bolt back in and refill.
John
own: 81 xs1100g...
learnerbiker
PostPosted: 20:01 - 11 Dec 2007    Post subject: Reply with quote
thanks guys, sounds very straight forward, i've changed the car's oil many times so this shouldnt be too different. Thumbs Up
mr.z
PostPosted: 16:15 - 12 Dec 2007    Post subject: Re: honda cg125 oil Reply with quote
custom-biker wrote:
is semi synthetic oil ok for this engine 10w 40?
No
Use non synthetic oil, asdas own is a good one.. for one there no point (because its simply not in long enough), for another it will very likely fuck your clutch and another its a total waste of money.
As to where, SOME cgs don't have a drain but others do the japanese models afaik, check the underside, brazilian models (more recent ones i couldn't say) have no drain so its the 24mm cap.. which is made of cheese so take care.
Scotch Bonnet
PostPosted: 17:07 - 12 Dec 2007    Post subject: Re: honda cg125 oil Reply with quote
the 2004 and on ones are just the 24mm cap, which yes, i can confirm is made of cheese. Hard cheese (Gruyere or thereabouts), but cheese nonetheless.
Hmmmm..... is it supposed to do that?
2001 CB500
8316
PostPosted: 17:59 - 12 Dec 2007    Post subject: Reply with quote
synthetic is a waste on a cg
mineral oil from halfords.tis fine
Now own a Fireblade!! Speed Limits? Bah!
Noxious89123
PostPosted: 21:42 - 12 Dec 2007    Post subject: Reply with quote
Who the heck mentioned Synthetic?
He said SEMI-Synthetic.
It's what most bike manufacturers tell you to use, no? It certainly tells me to use 10W-40 Semi-Synth in my Honda manual for my cbr.
mr.z
PostPosted: 01:20 - 13 Dec 2007    Post subject: Reply with quote
All oils have some degree of synthetic content, fully having the highest and semi having quite a bit.
Synthetic car oil particularly has additives known as friction inhibitors.. now how to wet clutches work? some you'll get away with it but why risk especially given the gain being, well, fuck all.
Bike oils, synthetics, are fucking expensive. The point of them is they prolong service intervals, if your changing the oil every 1000 miles that rather defeats the point.
Its like flying to Hungary to kill geese by choking them with Siberian tiger fur.. to feed your dog.. your dog will eat pig labia in gravy its entire life and be a perfectly happy dog all its days, in fact goose may well give it the shits.
The last post was made 18 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 80.23 Kb
