counter-steering (what??)
Keen
PostPosted: 19:29 - 09 May 2002    Post subject: counter-steering (what??) Reply with quote
what is this counter steering that I keep hearing about, can anyone explain it too me? I've heard it mentioned as a good way to increase turning ability- especially in an emergency.
PostPosted: 20:36 - 09 May 2002    Post subject: Re: counter-steering (what??) Reply with quote
Counter stering is pretty much the only way to turn a motorbike at reasonable speeds (you may not realise you're doing it but you probably are unconsiously). It works by turning the bars in the *opposite* direction to the way you want to go.
Try going in a straight line, at say 30, and turn your bars slightly while still going in a straight line. You'll find the bike leans to the opposite side and you have to shift your weight to carry on going in a straight line.
You can use this effect to turn into corners faster by making the bike lean rather than you leaning and hopeing the bike will follow. It's also a lot easier to change your angle of lean mid-turn using counter-steering.
Keen
PostPosted: 22:44 - 09 May 2002    Post subject: Reply with quote
yeah I see what you mean- you probably do that anyway when you lean don't you- thanks. Maybe you can do it better if you make a conscious effort though. I'll try it.
PostPosted: 22:54 - 09 May 2002    Post subject: Reply with quote
It definatley makes a significant difference... next time you go for a ride try just counter-steering (lean with the bike rather than the bike leaning with you)... you can lean a lot quicker
Keen
PostPosted: 23:01 - 09 May 2002    Post subject: Reply with quote
when I get my bike on the road I'll give it a go. There's a massive roundabout just up the road (it joins the A1) so when I get it back I'm gonna go there at night and get some practise in- try leaning as far as possible and counter-steering etc.
PostPosted: 23:33 - 09 May 2002    Post subject: Reply with quote
You can do it on a mountain bike as well... just not for long because you turn *far* too quickly and end up turning in again with the handlebars
The last post was made 24 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 47.9 Kb
