Best way to clean engine?
Arfdog
PostPosted: 13:22 - 14 Feb 2007    Post subject: Best way to clean engine? Reply with quote
Normally when I clean somewhere that's really dirty, like under the sprocket cover (inch-thick layer of tar-like, oily gunk) I remove what I can by scraping out with a sheet of bounty, then wipe the metal clean with bounty and WD40 (which seems to dissolve thick oil somewat).
Are there any easier, more effective methods? I've heard of steam-cleaning, but I don't even know what this entails..
I'm a lover, not a fighter.
Jamie S
PostPosted: 13:26 - 14 Feb 2007    Post subject: Reply with quote
Steam cleaning ( I know from experiance ) takes the paint off.
Just use Flash kitchen degreaser, It works wonders getting all that sort of crap of you bike and the engine.
It is safe to use every were on you bike.
hope this helps you.
jamie stokes
Jamie S
PostPosted: 13:41 - 14 Feb 2007    Post subject: Reply with quote
You say blast, meening ? jet wash steam cleaner, or just the hose pipe ?
cheers
jamie
PostPosted: 13:42 - 14 Feb 2007    Post subject: Reply with quote
Gunk the bugger.
https://im.edirectory.co.uk/products/225/i/gunkbrushon.jpg
Rub the gunk into all the crappy bits with an old paintbrush, leave it to sit for a few minutes then hose it down. This should remove the vast majority of the crap. Get a can, not an aerosol.
Paraffin works ok too. Same technique but use soapy water.
Remember, gunk lifts tarmac so don't do it on a tarred driveway.
Arfdog
PostPosted: 13:43 - 14 Feb 2007    Post subject: Reply with quote
Is blasting with a hose a good idea in a place like under a sprocket cover where there are oil seals and so on exposed?
Jamie S
PostPosted: 13:45 - 14 Feb 2007    Post subject: Reply with quote
Yer its ok, but it wouldant be if you were doing it every day
map
Mr Calendar
PostPosted: 13:59 - 14 Feb 2007    Post subject: Reply with quote
Agree with the use of Gunk to clean up an engine Thumbs Up
Best applied to a warm engine.
However, don't go overboad with the water washing it off (or cover electric bits in cling film first).
For finishing off and other bits (bodywork, seat, etc) then brake cleaner is the stuff to use Very Happy
HTH Thumbs Up
Jamie S
PostPosted: 14:00 - 14 Feb 2007    Post subject: Reply with quote
Can i just ask what is this Gunk stuff ?
PostPosted: 14:21 - 14 Feb 2007    Post subject: Reply with quote
I like to work on the assumption that if the seal can keep scalding hot oil in, it will keep water out. I've yet to be proved wrong in that assumption.
It is engine degreaser, you can buy it in big orange tins in almost any automotive suppliers.[/quote]
matt1981
PostPosted: 15:47 - 14 Feb 2007    Post subject: Reply with quote
Definately gunk it!! It comes in an orange can you can get a spray version or as a liquid, you can get it from halfords.
Pete.
PostPosted: 19:44 - 14 Feb 2007    Post subject: Reply with quote
I got some muc-off and I thought it was rubbish. Gunk is good as is paraffin, both will make your clothes stink even after washing. Petrol works very well but it's dangerously flammable, toxic, carcinogenic, bad for your skin, bad for the environment and bloody expensive.
a.k.a 'Geri'
owdamer
PostPosted: 19:57 - 14 Feb 2007    Post subject: Reply with quote
Be careful if you use gunk foam, it stains your tyres brown & makes screens look like they've steamed up.
cagiva gezzer
PostPosted: 20:08 - 14 Feb 2007    Post subject: Reply with quote
https://www.yourcarparts.co.uk/trolleyed/images/products/mac100accec001.jpg
https://www.whitedogbikes.com/ccp51/media/images/product_category/Autoglym_Bike_Degreaser_sm.jpg
Can dull the finish though. Only use it for really bad stuff, as the MC cleaner is for general use.
PostPosted: 21:56 - 14 Feb 2007    Post subject: Reply with quote
Although I suppose that's why it's called "engine degreaser" and not "screen and tyre cleaner". Wink
owdamer
PostPosted: 22:47 - 14 Feb 2007    Post subject: Reply with quote
You may well have a point there. Smile
goatrider
PostPosted: 03:16 - 15 Feb 2007    Post subject: Reply with quote
I have always used Gunk - does the job very well.
Definatley get the gunk in a can and not in the aerosol spray.
As said above - brush it on, working it into any stubborn areas (warm engine is best for sure) - go have a cup of tea - come back and hose it off with a normal garden hose with a "jet" style spray head on it.
I would not recommend using a pressure washer on any part of a bike Thumbs Down - the huge pressures involved can blast paint off and can seriously bugger your bearings if they get a direct blast (steering head, swingarm linkages, wheels etc etc).
And yep - gunk stinks so be prepared for the missus to give u loads of grief come laundry day Evil or Very Mad Laughing .
When you buy the can of gunk grab a tub of swarfega or similar to clean your hands or they will smell of gunk for days after (or wear some rubber gloves whilst using the gunk).
Pop into your local B+Q and grab a paint brush for painting the back of radiators (long handle - brush head at an angle) - excellent for getting under the engine and in some of those really hard to reach spots.
Have fun cleaning - a clean bike is a happy bike (unless its my GS5 and then its never bloody happy - Laughing Laughing ).
Cheers,
Goat. Thumbs Up
Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
"I dont give a shit who your dad is......quit walking on the water while I'm fishing......."
The last post was made 19 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 98.45 Kb
