| Author |
| vfr800 |
 vfr800 Spanner Monkey
| Back to top |
| stinkwheel |
 Posted: 00:55 - 05 Dec 2005 Post subject: |
If it is coming right from the bottom of the float bowl, it is an overflow pipe.
This is telling you that the float/needle valve assembly isn't functioning properly leading to too high a level of fuel in the float bowl (coming out of the overflow prevents it filling your crankcase with petrol)
Now. Simple things first. Just above the pipe you will see a brass screw, this is a drain screw so make sure it hasn't come loose.
Next give the side of the carb a few sharp raps with a rubber/nylon hammer. The floats sometimes stick and this can free them off (you will be able to tell because the fuel will stop pishing out)..
Failing that it is either a bit of muck in the needle valve, a damaged valve seat, a leaky float or the float height has somehow been mysteriously changed. You will need to take the carb off to check all of these. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| pipnet11 |
 pipnet11 Brolly Dolly
| Back to top |
| Cog Head |
 Cog Head Could Be A Chat Bot
 Posted: 23:13 - 05 Dec 2005 Post subject: |
right then...
i have bodged up my carb for the moment, with a little piece of the outer sheathing of some Cat 5 E cable, and its working...ok ish, just a sod when it kinks, the engine gets all bogged down and dies.
any way...
i fixed that, come home today from school and i see a big box with 50cc.nl on it, its my proformance exhaust it rocks...
i sorted (bodged) my carb for now any way, and decide to stick my new exhaust on, easy enough...got my old standard exhaust off and it seemed a little heavier than normal, so i tipped it up a bit and looked closely in the exhaust whole and a huge gush pf freekin petrol came gushing towards me, no wounder it wouldnt start...
i fitted me exhaust and went for a ride...as you do...and WOW it was crazy it flys i loved it, went for a blast arround my area and on the duel carrigeway, not a clue what speed i was doing, spedo said i was going about oil lamp Mph
i went to meet a m8 and went to go get another m8, and on the way back from his, my freekin throttle cable snapped, NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO ...not a happy bunny to say the least...had to push it back to my house which is about a mile or so, which wasn't too bad...so then now i need
*Breakpads Front and back
*Throttle cable
*tubing for my carb
no doubt that this list will continue to grow...
i have come to the conclusen that my bike is cursed
when will the torcheres money spending end ??? ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
| Back to top |
| Joey Bane |
 Joey Bane Borekit Bruiser
 Posted: 13:53 - 07 Dec 2005 Post subject: |
you can find diagrams and such suff at www.dellorto.com ____________________ Currently driving: Motorhispania RYZ(yes i'm another ped "boi") |
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
The last post was made 20 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
