Piston pisser! Suzuki GP100
cb1rocket
PostPosted: 12:19 - 08 Sep 2010    Post subject: Piston pisser! Suzuki GP100 Reply with quote
ok guys. After getting my GP100 on the road, not to mentioned the consent engine problems and getting it to run right. This is what happened when i suddenly just lost all power and clank clank clank clank!
Is a top end rebuild possible or am I gonna need to take the engine out of frame, strip and clean?
The piston has basically lost one of its lower flange and as i imagine its all broken up. The engine did run again after fitting a new plug but has bugger all power. It would rev to 5k rpm and sit there with a huge puff of smoke!
Rebore and new piston me thinks and to get the bloody timing sorted. Probably why it went in the first place, it was retarded but couldn't move the stator plate any further to advance the ignition! So might have to re drill and file the elongated holes further?!
What do you guys think I should do?
https://i212.photobucket.com/albums/cc108/CB1Rocket/DSCI0148.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/DSCI0147.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/DSCI0146.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/DSCI0145.jpg
https://i212.photobucket.com/albums/cc108/CB1Rocket/DSCI0144.jpg
stirlinggaz
PostPosted: 12:22 - 08 Sep 2010    Post subject: Reply with quote
where is the debris from the piston?
at the very least its needing a new piston & the bottom end flushed out.
more likely you've damaged the crank &/or bearings & will have to drop the engine & split it,
have fun!
cheers,
GAZ
edit : the crank doesnt look in the best condition either, suspect your going to need it replaced.
cb1rocket
PostPosted: 12:35 - 08 Sep 2010    Post subject: Reply with quote
debris? in the bottom me thinks or flushed out through the exhaust!?
Yet to see if there is any movment in the con rod.
Whats the best way of getting the crap out the bottom without splitting?
stonesie
PostPosted: 19:27 - 08 Sep 2010    Post subject: Reply with quote
If you want to re-use that crank case it MUST be split and every part cleaned thoroughly, it only takes a tiny fragment to get into a gearbox bearing to start it on the path to failure.
And "Sod's Law" clearly states that it will fail at the worst possible moment and in the worst possible way...
Locking the box and rear wheel solid during a top speed run perhaps?
cb1rocket
PostPosted: 21:34 - 08 Sep 2010    Post subject: Reply with quote
good point but i thought the gearbox is sealed away from the combustion/crank chamber, tis a 2 stroke
reggie
PostPosted: 00:19 - 09 Sep 2010    Post subject: Reply with quote
jet wash ftw if its just small bits of alumineum it wont do much harm
when the shit hits the fan make sure its facing the other way.
cb1rocket
PostPosted: 13:03 - 09 Sep 2010    Post subject: Reply with quote
well i just checked the con rod for vertical movement, and I can't really get any except sideways movement which is allowed for i hope!
So i think i'm all good without splitting the crank halves
The last post was made 15 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 62.28 Kb
