GS500 jack up kit? and....
PostPosted: 18:10 - 11 Oct 2008    Post subject: GS500 jack up kit? and.... Reply with quote
Few of questions.
Is their a jack up kit available for the rear end?
I've seen loads of lowering kits on ebay,but none to lift it?
Also,if i remove the seat and look under the tank,i can see into the air filter hole?Am i right in thinking something's missing like a top cover?
And lastly;Is their any gs500 specific forums that i dont have to pay for?
Theres www.gs500e.... but all the technical and how to side of the forums are closed unless you pay.(it's not just that i'm tight,i wont own the bike for long so i dont want to waste money joinging a forum i'll only use a couple of times)
Thanks for any advice Thumbs Up
Dave
Edit:Shit quality pic,just posting it to show you my cb500 exhaust can Laughing
https://i187.photobucket.com/albums/x13/fronterapics/DSC00365800x600.jpg
DRZ-400sm
Gazdaman
I did a trackday!!!
PostPosted: 18:21 - 11 Oct 2008    Post subject: Reply with quote
There are jack up kits on eBay, or certainly have been.
But a better way of jacking it up is to fit an RGV250 or SV650 rear shock. Better quality, and raises the rear.
And I joined gs500e.co.uk, it's only £3. It isn't a busy forum though.
And yes, you should be able to see into the air filter. Don't worry about that.
Gaz
Whosthedaddy
PostPosted: 18:23 - 11 Oct 2008    Post subject: Reply with quote
If the lowering kit involves (shorter) dog bones then a longer bone will jack up the rear. Its a 30 minute job to change tops.
If you are unable to find one:
Ask a friendly CNC machinist to knock out out for you.
Or
Measure the hole to hole distance of the standard ones and then see what other bikes have a longer dog bone as I believe that the standard hole sizes should be the same.
If its not dog bones then ignore all of the above as I have no idea.
PostPosted: 18:25 - 11 Oct 2008    Post subject: Reply with quote
Gaz
Cheers for the reply gaz Thumbs Up .
Just found a jack up kit on ebay germany for 20 odd quid..
On the gs forum,is their how to guides and things in the workshop section?
If there is i wont mind paying the £3 Thumbs Up
DRZ-400sm
Gazdaman
I did a trackday!!!
PostPosted: 18:27 - 11 Oct 2008    Post subject: Reply with quote
There are some guides. Not loads. Worth the £3 imo. And I hardly ever pay for stuff.
If you can't find the info you're after, someone on there will know, and will reply to you.
The CB500 exhaust looks decent, I'm planning on fitting an R6 race can.
Gaz
PostPosted: 18:28 - 11 Oct 2008    Post subject: Reply with quote
I could get one made no problem,but i'm not sure how much longer i should go on the dog bones (yes it does have 'em)
DRZ-400sm
Whosthedaddy
PostPosted: 18:31 - 11 Oct 2008    Post subject: Reply with quote
I'm sure that someone will provide the correct correlation between length and lift attained. You don't need a huge increase to jack the rear by a few inches.
Gazdaman
I did a trackday!!!
PostPosted: 18:51 - 11 Oct 2008    Post subject: Reply with quote
I'd start at about 20mm and go from there.
Be careful lifting it too much or it'll affect how far the bike leans on the sidestand and you'll have to mess about with that too.
Gaz
PostPosted: 18:53 - 11 Oct 2008    Post subject: Reply with quote
Should the dogbones not be shorter to raise the rear?
DRZ-400sm
Gazdaman
I did a trackday!!!
PostPosted: 18:58 - 11 Oct 2008    Post subject: Reply with quote
Interesting. My knee jerk reaction was 'no of course not'.
But you could be right, I can't actually find any evidence to the contrary. But I do think they have to be longer to raise the rear.
Also, on the bandit 400, they do jack up kits in 35mm and 50mm. So there's some ball park figures for you.
Gaz
PostPosted: 17:48 - 07 Nov 2008    Post subject: Reply with quote
Quick question....but first.
The standard dogbones are 180mm (from centre of hole to hole)
The holes are 12mm diamater.
6mm wide.
To jack the bike up you have to use shorter dogbones.
I've used 170mm dogbones which will raise the rear by 2".
Just thought i'd add that for future reference.
The question;
The new shorter dogbones i've had made up are only 4.5mm wide,where the standard ones are 6mm.Will they still be strong enough to use?
EDIT:
Mod=I just realised this should probably be in the workshop section. Embarassed Thumbs Up
DRZ-400sm
hmmmnz
PostPosted: 20:48 - 07 Nov 2008    Post subject: Reply with quote
don't use the dogbone method on the gs500,
the gs shock is fucken shit is you raise the bike on that shit shock and feels like a hover craft when you do corners.
use the sv650 shock (the yellow one!! not the newer white shock)
it needs a little fettling,
but is by far and away the best mod for the gs500
if you need any help, tech wise gimmee a yell,
what i dont know about the gs500 isnt orth knowing Very Happy
and im choice ..... just ask me Very Happy
the humans are dead
I kick arse for the lord
PostPosted: 21:56 - 07 Nov 2008    Post subject: Reply with quote
Hello stranger Very Happy all settled in now?
I was gonna use the 650 shock,but that means spending money(ebay says £50+).It's only a winter hack so that's not an option Smile
If the dogbones make things worse,i'll just stick the standard ones back on and live with it Thumbs Up
DRZ-400sm
hmmmnz
PostPosted: 19:27 - 08 Nov 2008    Post subject: Reply with quote
just keep your eyes open, i got mine for 15 quid,
yeah all settled back in nz.. i have 2 of the smallest bikes youve seen :Dgood on gas, but fucken slow Neutral
the humans are dead
hmmmnz
PostPosted: 19:46 - 08 Nov 2008    Post subject: Reply with quote
oh yeah the gsx600 shock is also a direct replacement,
plenty of those about
heres one on ebay
the humans are dead
Gazdaman
I did a trackday!!!
PostPosted: 20:37 - 08 Nov 2008    Post subject: Reply with quote
As do RGV250 ones. And they have a sexy remote reservoir too. Mmmm
Gaz
TGR
PostPosted: 20:45 - 08 Nov 2008    Post subject: Reply with quote
I slapped on the katana shock, it raised the bike about 3/4 inch and transformed the handling Thumbs Up
1991 Kawasaki ZXR400L - 1999 Suzuki GS500E - 1990 Kawasaki ZX750R H2 - 1991 Honda CBR 600 - 2015 Skyteam Monkey 125
Chriss
PostPosted: 21:06 - 08 Nov 2008    Post subject: Reply with quote
https://tbn0.google.com/images?q=tbn:7jcuj4zwukD3CM:https://www.totalmotorcycle.com/photos/2006models/2006-Suzuki-KatanaR50c.jpg?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
TGR
PostPosted: 21:18 - 08 Nov 2008    Post subject: Reply with quote
Yeah thats the one Wink
R32's Suzuki GSX-F 600 Katana
https://i491.photobucket.com/albums/rr271/nastypiranha/r32_katana.jpg
Chriss
PostPosted: 21:50 - 08 Nov 2008    Post subject: Reply with quote
Thought it was only known as that in the states.
More like teapot over here. Laughing
Endless Nameless
PostPosted: 01:31 - 09 Nov 2008    Post subject: Reply with quote
Arg! What is it with this place, no-one seems to know what a real Suzuki Katana is Neutral
A2 passed 22/07/08; restriction up 22/07/10 (just so I don't forget)
'79 Suzuki GS550E. Yes, that's a GS550, not a GS500.
Supersports "In a video editing competition I'd kick your sorry ass"
Chriss
PostPosted: 02:20 - 09 Nov 2008    Post subject: Reply with quote
You mean this old thing? Wink
https://static.howstuffworks.com/gif/1983-suzuki-katana-1100-01.jpg
Endless Nameless
PostPosted: 11:18 - 09 Nov 2008    Post subject: Reply with quote
Yes!
The last post was made 17 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.77 - MySQL Queries: 16 - Page Size: 128.04 Kb
