Excel Macro Help
PostPosted: 15:52 - 20 Aug 2010    Post subject: Excel Macro Help Reply with quote
Right, I'm trying to create a Macro that will take a line of dates in the format dd/mm/yyyy and convert them to yyy/mm/dd, where yyyy - yyy is 2010 - 110, 1995 - 095 and 2150 - 250.
I do this using Text to columns twice, once / delimited for the date and once Fixed with to split the year into 2 parts.
I then find and replace on the first part of the year 19 - 0, 20 - 1 and 21 - 2.
I then concatenate into the format YYY/MM/DD, copy and paste the values and get rid of the data not require so I end up with the input dates then the output dates next to them.
This works when I record it the problem is when I run the Macro again it drops any leading 0's from the day and month cells which makes it useless
i.e.
03/02/2000 is turned into 10032 when it should be 1000302. I can;t work out what is going wrong when i do text to columns I am selecting text as the field format, any ideas?
here is the code.
10032
Sub dateconvertor()
' dateconvertor Macro
' Macro recorded 20/08/2010 by cibrown
Columns("A:A").Select
Selection.TextToColumns Destination:=Range("B1"), DataType:=xlDelimited, _
TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=False, _
Semicolon:=False, Comma:=False, Space:=False, Other:=True, OtherChar _
:="/", FieldInfo:=Array(Array(1, 2), Array(2, 2), Array(3, 2)), _
TrailingMinusNumbers:=True
Columns("DVery Happy").Select
Selection.TextToColumns Destination:=Range("D1"), DataType:=xlFixedWidth, _
OtherChar:="/", FieldInfo:=Array(Array(0, 2), Array(2, 2)), _
Selection.Replace What:="19", Replacement:="0", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Selection.Replace What:="20", Replacement:="1", LookAt:=xlPart, _
Selection.Replace What:="21", Replacement:="2", LookAt:=xlPart, _
Columns("F:F").Select
ActiveCell.FormulaR1C1 = "=CONCATENATE(RC[-2],RC[-1],RC[-3],RC[-4])"
Range("F1").Select
ActiveWindow.SmallScroll Down:=-6
Selection.AutoFill Destination:=Range("F1:F141")
Range("F1:F141").Select
Columns("B:E").Select
Selection.Copy
Columns("G:G").Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Columns("B:F").Select
Application.CutCopyMode = False
Selection.Delete Shift:=xlToLeft
Range("B2").Select
ActiveWindow.SmallScroll Down:=-18
End Sub
Frost
PostPosted: 16:07 - 20 Aug 2010    Post subject: Reply with quote
Leading zeros are not neccicary when doing mathematical operations. So if you tell a programming language, or calculator for that matter:
000000000001 + 000000000001 = 2, not 000000000002
You will either have to treat the whole thing as a 'string' that is what text is called in programming. Strings can be converted to numbers for maths, but obviously this will make them 2 instead of '02'. Most languages have a function called 'pad' which will let you put a number of 0's before to make the answer a certain length: e.g pad( text, '0', 2 ) will pad out text with 0's until it is of length 2. Thats not the correct name, but it will be very similar.
So basically convert the int's to strings.
PostPosted: 16:26 - 20 Aug 2010    Post subject: Reply with quote
It's all done with Text to columns, you set the field format to text and it should keep the leading 0.
There is no math involved it is purely moving data around, I could replace the numbers with letters it would still do it.
After the first text to columns step on the record it will look something like this.
01/01/2002 01 01 2002
Then the second
01/01/2002 01 01 20 02
But on the Run it will look like this
First
01/01/2002 1 1 2002
Then the second
01/01/2002 1 1 20 02
Note the 02 doesn't drop the 0.
The last post was made 16 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 40.51 Kb
