Honda CG125 Basic maintenance/servicing
Brick_Top
PostPosted: 18:02 - 26 Jun 2005    Post subject: Honda CG125 Basic maintenance/servicing Reply with quote
I've just bought a Honda CG125. I've checked the service book and it was last serviced at 6000 miles, it now has 10000 miles on it.
What should I replace and how? Does anyone have a PDF haynes manual?
I've never done anything to bikes before, and this is my first bike. I'm not totally new to mechanical things though, I've done a bit of work on cars before.
Conrad
bish777
PostPosted: 18:14 - 26 Jun 2005    Post subject: Reply with quote
change the oil and oil filter, air filter, spark plug and the clearances on the valves could do with checking and adjusting.
GSXR1100J
Brick_Top
PostPosted: 19:40 - 26 Jun 2005    Post subject: Reply with quote
What about brakes?
White Noise
Mr Dudwee
PostPosted: 22:33 - 26 Jun 2005    Post subject: Reply with quote
KidKoala wrote:
What about brakes?
do they feel soft/spongy?
if so maybe they need to be bled?
if they are firm and feel right compared to your training bike, then i would suggest leaving them alone. though if the bike has been used in the wet/winter i would suggest cleaning the brake pistons, if you feel inclined to as it could save problems happening later with binding brakes
take a look at korns handy guide
https://www.bikechatforums.com/viewtopic.php?t=22573
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
mchaggis
PostPosted: 22:37 - 26 Jun 2005    Post subject: Reply with quote
The oil filter is a small gauge mesh type, about the size and shape of a thimble, immediately beneath the sump plug. It just needs cleaning in white spirit or similar; it should not need replacement. I imagine you've been changing the oil every 1000-1500 miles anyway?
The valve clearances are set with a simple screw and locknut mechanism. They're set to 0.08mm IIRC, for which you will need feeler gauges. If you're careful, you should be able to reuse the rocker cover gasket, but if anyone has used instant gasket on it before, then you'll most probably require a new one.
Clean the air filter (a foam sock I think) in a big bucket of very hot water, dribble light oil through it and wring it out and massage it through to get a good light emulsion of oil through all the foam.
Brakes want adjustment if they're the drum type, and some light sanding of the brake shoes to remove any glaze which will cause squeaking. Don't breathe the dust!
For the hydraulic type, brake pads should be checked for wear limits, and then lightly sanded to remove any glaze and grease smeared on their backs also to reduce squeaking. Brake fluid will probably want replacing if it is darker than light honey, and otherwise will still probably want bleeding.
Sparkplug replacement is self-explanatory. Check the steering head, wheel and swingarm bearings for play or notchiness. Oiling the speedo, clutch and throttle cables might not be a bad idea either. Grease the swingarm and sidestand pivots, and clean any cut-out switches if they're still attached.
A bally good clean is always worthwhile, even if just to check for any loose fasteners.
I must not be a troll...
Mmmm, Guinness
cagiva gezzer
PostPosted: 12:47 - 27 Jun 2005    Post subject: Reply with quote
Don't wring air filters, press out any excess.
mchaggis
PostPosted: 12:51 - 27 Jun 2005    Post subject: Reply with quote
Yes, I should have made that a little more clear. Wringing it like a dish cloth is too vigorous, and twisting it like so is a no no. A gentle squeeze should be enough, or you can hang it out to dry a bit on the line.
Mmmm, Guinness
There is a gap of 2 years, 55 days between these two posts...
Spoon261
PostPosted: 13:46 - 21 Aug 2007    Post subject: Reply with quote
I have created a Honda CG125 website, it has lots of information like how to service the bike.
https://hondacg125.awardspace.com/
If anyone is wondering why I am responding to 2 year old posts, try a google search of Honda CG125 servicing, spark plug or oil. They all bring up this thread!
Honda CG125 Website https://hondacg125.awardspace.com/
Honda CBF125, CBR125 & Yamaha YBR125 Website https://125ccbikeclub.awardspace.co.uk/
I have left bikechat forums, I do not read pm (Private Message)
hmmmnz
PostPosted: 14:16 - 21 Aug 2007    Post subject: Reply with quote
Thumbs Up Thumbs Up to opening a page o help people,
but i have to say.. its fucken boring, their are no pictures on any of the maintance issues that you talk about, there is no pics full stop,
words are all good but you know what they say about pics Very Happy Thumbs Up
good luck with the site, and if you want a colour diagram, you know what to do. (im sure others would use it, even if you did not)
the humans are dead
I kick arse for the lord
Spoon261
PostPosted: 14:49 - 21 Aug 2007    Post subject: Reply with quote
Some one or ones have rated my last post as off topic.
This has resulted in my post being hidden from most people as a result.
If the people responsible do it again, I will report them to the moderator as abusing the system.
I challenge anyone to claim my post if off topic, the topic was everything about servicing the Honda CG125, my post was everything to do with servicing the Honda CG125.
My hidden post is repeated below
hmmmnz
PostPosted: 15:00 - 21 Aug 2007    Post subject: Reply with quote
i would call it spam rather than off topic, but i rarely go in for that stuff Very Happy threatening to go to a mod is more than likely going to earn you some more Thumbs Down Mr. Green no one likes a taddle tale hehe
the humans are dead
veeeffarr
PostPosted: 15:11 - 21 Aug 2007    Post subject: Reply with quote
Is this the website that advises people to screw a spark plug in 1/2 a turn with a plug spanner after putting it in finger tight? Shocked
Spoon261
PostPosted: 15:20 - 21 Aug 2007    Post subject: Reply with quote
Yes and thats what the Honda Owner's Manual tells you to do.
And yes thats for a new plug, not a used one as my website tells you to.
You can also check out the NGK websites and see what they tell you as well.
There is a gap of 3 years, 258 days between these two posts...
andrew191
PostPosted: 20:29 - 05 May 2011    Post subject: Indicator Reply with quote
When i flick on the indicator to the right, the switch sticks and i manually have to push it back to the middle, the left one flicks straight back, does it just need a clean? if so how would i go about doing that
Andrew, Honda CG 125 1998.
neil.
PostPosted: 20:39 - 05 May 2011    Post subject: Reply with quote
This thread started in 2005! Shocked
https://i32.tinypic.com/1yoec8.jpg
Brick_Top
PostPosted: 12:52 - 18 May 2011    Post subject: Reply with quote
Holy thread revival!
WayneCG125
PostPosted: 15:31 - 02 Jul 2011    Post subject: CG125 problems Reply with quote
I have a 1982 CG125
It runs great except;
The turn signals are like snails, when they work. I have to flip on and off manually when turning.
The break light is always on, I think it is a faulty switch, but not sure I I have a general electrical problem given the turn signal problem.
In they Haines manual they talk about a centrifugal oil filter. Is it real important to dismantle the engine to go though the procedure of cleaning that?
i may have more questions
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
WayneCG125
PostPosted: 16:38 - 03 Jul 2011    Post subject: Reply with quote
unitycrippledatmo wrote:
If its the last of the 6v battery ones then its normal
it's the 6V
I keep buying new batteries and charging them and it seems to make no difference.
I hate electrical problems
Is their a main ground somewhere? maybe that needs to be cleaned up. The horn worked once or twice a couple years ago, doesn't work now
I think there is a central problem, I am just not sure where to look.
kramdra
PostPosted: 18:18 - 03 Jul 2011    Post subject: Re: CG125 problems Reply with quote
if your in the south I can help with electrics.
Sounds like a new switch unit, and front brake switch would help - originals wont be much good..
Rear brake switch is adjustable
The filter is the main one. It would be a good idea - it can get full and then is useless. Wouldnt bother with the strainer, its too big to even stop sand - you wont find anything in it!
If you do this, the engine and surrounding frame need to be perfectly clean, so dirt cant fall in!
I think every 30,000 it should be done.
The last post was made 14 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 16 - Page Size: 126.37 Kb
