Project GP100 !
satelliteone
PostPosted: 13:10 - 08 Oct 2008    Post subject: Project GP100 ! Reply with quote
OHHH NOOOO i bought another project! Im gona be busy this winter.. That and the DTR125..Smile
Too good to say no too.! 50 quid on ebay. and it was local to me. got the V5 and some spares. + manual..
The engine is in bits with a blown crank, Just bout another good crank from the dreaded ebay spares department. Smile
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1649.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1650.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1647.jpg
Honda XLR125R - Project
TZR125RR Belgarda 4DL - Sold
Chinki Project done n Dusted/sold** DTR125 2003 - Finished/sold
garth
PostPosted: 14:18 - 08 Oct 2008    Post subject: Reply with quote
Will be a really pretty bike. Get some drop bars!
stevo as b4
PostPosted: 21:06 - 08 Oct 2008    Post subject: Reply with quote
Yeah a nice GP100 Cafe racer FTW! PB did a GP100 project about 20years ago, and i think the aim was to build one into a 100mph bike?
satelliteone
PostPosted: 22:20 - 08 Oct 2008    Post subject: Reply with quote
Thanks chaps, maybe a cafe racer.. Gone have a nose round the scrapys see what i can find. Drop bars!..
would like a micron on the GP too.. Decent sports exhaust. In the book they say 15 horses.. i rekon with a decent carb say off a Vespa or DT125 then i would expect to see close on 20HP.. whooohooo...any one know of any GP125 tuning sites?
I measured the piston and its 57.85mm The bore is 57.99 i take that is not 100cc more like a big fat 125cc with a rebore of 2mm.
HOW cool!
The rings are new as well, never been fitted. Gona strip the carb to see what it is jetted with. Wonder if its been under jetted. Smile
Got one of the new crank bearings in today!.. Got the other side to do still.. need my compressor and impact driver to get the clutch shaft nut undone..Its on well!
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1651.jpg
satelliteone
PostPosted: 18:11 - 20 Oct 2008    Post subject: Reply with quote
Got the engine cases glued together today with the new crank installed. The bottom end has new main bearings and big ends/seals. It feeling very sweet indeed. slick!
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1661.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1663.jpg
Also the forks had a complete overhaul too..
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1664.jpg
Next are the wheels..
satelliteone
PostPosted: 18:48 - 04 Nov 2008    Post subject: Reply with quote
Today got the frame stripped ready for the renovation. Not looking too bad for a 1982 bike. Very solid indeed.
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1672.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1673.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1674.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1680.jpg
Lots of elbow grease and the wire wheel needed, will come up puka me thinks.
satelliteone
PostPosted: 13:58 - 05 Nov 2008    Post subject: Reply with quote
Frame painted..
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1684.jpg
Yoke and clock holder painted
Look, if i throw these bits at a wall, they stick, must cut down on the black stuff me thinks! har de har!
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1689.jpg
rotax81
PostPosted: 14:25 - 05 Nov 2008    Post subject: Reply with quote
HOW cool!
measure the bore AND the stroke and use this calculator to get your cc Thumbs Up
ie. 54mm bore, 54mm stroke = 123cc
https://www.scooterhelp.com/tuning/defs.ccs.html#cc_calc
i had a gp100 with a 125 motor...... lethal 2 up lol
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
satelliteone
PostPosted: 15:13 - 05 Nov 2008    Post subject: Reply with quote
Lethal you say, shite! im gona fall off!..lol
the stroke is 50 X 57.99 bore = 132.06cc
Blimey! may need to up jet slightly.. can you remember if jetting sizes if it was talked about?
rotax81
PostPosted: 15:38 - 05 Nov 2008    Post subject: Reply with quote
now you have got me Confused
i normally go by the carb size and multiply it by 5 then take off a bit.
ie... 24mm carb x 5 = 120 main jet but go for 110 and check the plug.
above was just an example, you need to do the maths Thumbs Up
satelliteone
PostPosted: 16:06 - 06 Nov 2008    Post subject: Reply with quote
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1698.jpg
wheels come up great. the spoke wont rust no more Smile
satelliteone
PostPosted: 14:57 - 10 Nov 2008    Post subject: Reply with quote
The yoke/forks are now installed
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1714.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1718.jpg
satelliteone
PostPosted: 15:23 - 10 Nov 2008    Post subject: Reply with quote
Setting the timming. It was waaaaayyyy out. It was set to fire at about 35Deg BTDC. The correct timming is 20Deg or 1.87mm BTDC. Would run like a dog like this and probally over heat. Wish it was a CDI system, makes it bloody easyier.lol
The markings on the flywheel was a bit vague at best, so i had to make my own TDC mark, and then the mark for 20Deg. Reset the stator plate by taking off the flywheel. Took a few attempts but got there in the end.
A multimeter on the points wire was used to let me know when they were about to open and go open circuit. This was the point of Ignition.
My homemade way of getting the TDC and 1.87mm BTDC
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1706.jpg
then mark the case
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/timming1.jpg
then slowly move the flywheel clockwise to get nearest dam it to 1.87mm as the piston falls down the cylinder.
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1707.jpg
I then reset the points gap to 15 thou. rechecked the timming and it was spot on. Yipppeee Smile
satelliteone
PostPosted: 15:48 - 12 Nov 2008    Post subject: Reply with quote
A mile stone today. Got the engine in. Had some issues with no spark, the wiring had to be sorted up front, and then i got a nice blue strong spark.
Wheels on, but still have to get some new parts, Rear sprocket and chain, a few bulbs and thats it.
New on my list is the tank to respray along with the side panels/front mudguard plus the carb need cleaning.. The seat needs recovering too.
Here are the pix from today.
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1738.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1743.jpg
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1748.jpg
more updates soon.
PostPosted: 18:40 - 12 Nov 2008    Post subject: Reply with quote
Very cool and excellent progress Cool
Gashead Harry
PostPosted: 21:13 - 12 Nov 2008    Post subject: Reply with quote
How did you got those wheels coming up like that? The ones on me CG are starting to go bad.
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
Gazdaman
I did a trackday!!!
PostPosted: 21:16 - 12 Nov 2008    Post subject: Reply with quote
Good work mate! Impressed.
Gaz
PostPosted: 21:47 - 12 Nov 2008    Post subject: Reply with quote
Looks like he just painted the spokes silver. Good idea really. I started grinding mine and was going to polish them but I got lazy and now they've gone rust again. I'm tempted to go and buy some silver paint now though.
satelliteone
PostPosted: 21:52 - 12 Nov 2008    Post subject: Reply with quote
Thanks chaps, not far off the MOT is it.
Gashead, good old wire brush for the hub, used a drill too.. sand paper for the spokes, and very good alloy looking brush paint. Patience and a steady hand... took me two hours for both wheels. Very Happy
All i need now is a couple of liters of 2K red paint.
stevo as b4
PostPosted: 22:41 - 12 Nov 2008    Post subject: Reply with quote
Clip on's, a Micron or Allspeed pipe, and a K&N cone filter FTW! Laughing
benjami
PostPosted: 17:58 - 13 Nov 2008    Post subject: Reply with quote
Looking good!
Where abouts are you located?
Gashead Harry
PostPosted: 19:19 - 13 Nov 2008    Post subject: Reply with quote
Top man! Something for me to do saturday if its dry. Thats an impressive job you've done im looking forward to seeing the finished article.
satelliteone
PostPosted: 19:27 - 16 Nov 2008    Post subject: Reply with quote
Thanks guys.. im in Plymouth Benjami! and steve.. would love a micron or allspeed..see what i can find on the net..
Got me new chain and sproket..fit that in the week..42 teeth Smile
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1754.jpg
MaybeGuy
PostPosted: 22:07 - 16 Nov 2008    Post subject: Reply with quote
plymouth??
you need to be the third wheel in the great 100cc race we've been planning...
RXS100
H100
(potentially) GP100
you know you want to...
both these bikes cost £70 each, so we're looking at who can make the best shitters haha
so far im winning by fucking loads because it cost me about £50 from start to finish to get it through an MOT on the RXS
the H100 however... total cost SO FAR is over £1000 Confused
satelliteone
PostPosted: 18:10 - 17 Nov 2008    Post subject: Reply with quote
Cool i love races..matt
a grand! on a the H100? what did he buy for it. gold plated..lol
SO far for me
already had the wheels bearings and new engine parts/fork seals with the bike. The rear tyre is like new, front should pass..
50 quid for the bike
20 quid for the crank
30 Chain n Sproket
03 New Clutch cable(ebay) bargain!
11 New Rev counter cable (local bike shop)
10 Rev counter(bike breakers)
05 for bulbs
so far thats
£129
Still to buy is the paint/2stoke oil/petrol and MOT. and i rekon its gona cost sub 200 quid-ish.
not bad for a bike that under gone a rebuild.
No idea on the market value on resale, guestimate any one?
The last post was made 17 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.22 - MySQL Queries: 16 - Page Size: 138.42 Kb
