Modifying a regulator/rectifier
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3  Next
FretGrinder
PostPosted: 18:45 - 06 Apr 2011    Post subject: Modifying a regulator/rectifier Reply with quote
After my recent failure with my regulator/rectifier on my varadero 125, a new one is £177 and there are no pattern parts for mine which is an 07 model.
This turned some cogs in my head...
My reg/rec has 3 yellow wires coming from the alternator and 1 green 1 red wire that goes to the battery. Could you take a reg/rec from another bike, with the same wiring configuration, and fit them onto the connectors on your own bike?
I should imagine that, if the replacement reg reg has the same voltage and amp requirements, then this should be easy.
Has anyone done this? planning to do it? or just have any advice on what I could do?
Cheers. Mr. Green
Yamaha MT-09
ಠ_ಠ
pepperami
PostPosted: 19:12 - 06 Apr 2011    Post subject: Reply with quote
???? Sound like it could work???? possibly.
would one off a different bike have the same ?mapping? as your bike? ie would it send the pulse/charge/spark at the right time?.
Would you have to get one from a twin cylinder bike?
Just some thoughts Confused
FretGrinder
PostPosted: 19:24 - 06 Apr 2011    Post subject: Reply with quote
After a bit of trawling the interwebs I have come across a possible suitable reg/rec that is made to fot a CBR900 RR -
https://www.electrexworld.co.uk/rr690-regulator-rectifier-with-longer-lead-12963-0.html
This one looks very similar to mine. It has the same wiring configuration, 3x yellow from the alternator and 1 green + 1 red to the battery. I don't know if I'm right in thinking that 3 x yellow wires points to a 3 phase reg/reg (which is what i need) and 2 x yellow wires is a 2 phase reg rec.
The thing is I'd rather not get one, hook it up and fry my battery or other electric components.
If it did work then this one would also be better at dissipating the head, as the fins are larger.
I have seen people mod PC fans onto the front of their reg/recs, but I'd be worried in case rain got in and destroyed it as my reg/rec is mounted near my swingarm with no protection from the elements.
I'm sure Kickstart will be along with a post of ultimate win and chuck-norris-esque awesome
Yamaha MT-09
ಠ_ಠ
PostPosted: 19:27 - 06 Apr 2011    Post subject: Reply with quote
They are very generic units, and have nothing directly to do with the ignition system.
Electrex World do list one for the XL125V, and make no differentiation between different years of bike.
https://www.electrexworld.co.uk/rr58-regulator-rectifier-779-0.html
FretGrinder
PostPosted: 19:34 - 06 Apr 2011    Post subject: Reply with quote
Thanks for posting that keith. I have come across that one before but it's the wrong type for my bike as mine is hardwired and that one has a seperate connector.
Do you have any ideas on wether my above plan could work, e.g. buying the one in the link, taking the wires out of the connectors and slipping them into the connectors on my bike?
Cheers.
Yamaha MT-09
ಠ_ಠ
PostPosted: 19:43 - 06 Apr 2011    Post subject: Reply with quote
What do you mean by hard wired? That has a plug in connector. Or do you mean yours has a length of wire between the connector and the regulator / rectifier? If so if the loom has enough length on it then it will probably still fit.
Failing that almost certainly swapping the connector over will work.
FretGrinder
PostPosted: 19:58 - 06 Apr 2011    Post subject: Reply with quote
sorry for the confusion keith
I have attached a picture. The red box in the picture is where my wires are on my reg/reg. Thats what I meant by hardwired. The connectors on that reg rec are different to mine, I'm just wondering if it would work if I just swapped them over to the ones that I have on my bike.
Yamaha MT-09
ಠ_ಠ
cb1rocket
PostPosted: 20:15 - 06 Apr 2011    Post subject: Reply with quote
regualator/recitficier are fairly universal. This is a 3 phase type, the other is a single phase reg/rec which only has 4 wires, dont get that unless it is!
https://cgi.ebay.co.uk/250cc-Gokart-Voltage-Regulator-Rectifier-Go-Kart-/220716431741?pt=UK_CartsParts_Vehicles_ATVQuad_Trike_Parts_Accessories_SM&hash=item3363b9797d
PostPosted: 20:38 - 06 Apr 2011    Post subject: Reply with quote
Yes you can fit pretty much any reg/rec from a modern motorbike with a few exceptions.
Honda ones would be easiest because they use the same wire colours (although in a different connector block) so if you connect red to red, green to green and yellow to yellow, you'll be right.
Some appear to have more than one red or green, this is a red herring, they all connect back to the same point eventually so just bundle all the reds together and all the greens together. The three yellows need to remain seperate.
Some also have an extra black wire. These will work too but you need to connect that wire to a switched live somewhere on the loom (I use the feed to the back brake light switch). It may be simpler to just get one without a black at this stage.
For slightly complex electronic reasons, some of the more modern reg/rec units are considerably superior to the older type. A Yamaha R1 or R6 one is among these. You'd need to find out where to connect the wires to though, I and others on this forum can help with that if you decide to get one of those. It would be important that this was a genuine Yamaha one from a breakers/ebay, not a pattern one. For the afore-mentioned electronic reasons, they are highly unlikely to be faulty.
If the regrec goes on my VFR again, I will definately be replacing it with an R6 one.
FretGrinder
PostPosted: 21:02 - 06 Apr 2011    Post subject: Reply with quote
Awesome post dude, you seem to have hit the nail on the head thanks!
I've just been reading up on the Yamaha R1 reg/recs and how extremely unlikely they are to fail.
Thats my suspicions confirmed then, as long as you obtain the correct "phase" for your bike, 2 or 3 phase, then you can't really go wrong. If mine goes again I will almost certainly get one from an R1 and just connect the wiring up accordingly.
I will probably be upgrading to a transalp when I get my test done in the next couple of months, so this will probably be when I decide to change the reg/rec for the more robust Yamaha one. Expect a nice new thread with the whole project with lots of pictures.
Just an idea -
Maybe it would be a good idea to sticky this thread or the new one when I get the new bike as this the whole reg/rec problem throws up loads of hits on google, but the solutions seem to be few and far between.
Yamaha MT-09
ಠ_ಠ
prawny1
PostPosted: 23:18 - 06 Apr 2011    Post subject: Reply with quote
A lot of modern bikes use the mosfet type reg rec rather than the shunt type common on older/smaller machines.
The fh008 shindengen (oe manufacturer fh = mosfet type sh = shunt type) is 35A and can be found on late late cbr600 which should be plenty for the varadaro.
You will need to either buy a connector and wire it into your loom or just use spade connectors, all you do is wire in your generator inputs and wire the positive out to your battery via a 30A fuse then wire earth to frame or battery.
The r1/r6 reg rec is the 50A version from memory so is preobably overkill for your bike.
hellkat wrote:
Some people are only alive cos its against the law to kill them.
PostPosted: 23:22 - 06 Apr 2011    Post subject: Reply with quote
FretGrinder wrote:
Just an idea -
Google loves BCF. This thread will be up near the top within a few days.
FretGrinder
PostPosted: 23:55 - 06 Apr 2011    Post subject: Reply with quote
stinkwheel wrote:
FretGrinder wrote:
Just an idea -
Already there lol -
https://www.google.co.uk/#hl=en&xhr=t&q=modifying+a+regulator/rectifier&cp=31&pf=p&sclient=psy&aq=f&aqi=&aql=&oq=modifying+a+regulator/rectifier&pbx=1&fp=38584de721edb593
Yamaha MT-09
ಠ_ಠ
Gazdaman
I did a trackday!!!
PostPosted: 20:28 - 07 Apr 2011    Post subject: Reply with quote
I fitted a reg/rec from a CX500 to my old GS500. Worked a treat.
Gaz
Fortuna
PostPosted: 01:08 - 09 Apr 2011    Post subject: Reply with quote
I did this very mod on my R1, and there was a thread on here not too long a go where we helped a forum member do the same.
Just make sure the new one is fairly modern and preferably an SCR type.
The new reg/reg must be of the same or higher amperage.
3 yellows to 3 yellows (3 phase AC)
red to red (12v)
green to black (or green if your earth is green) (Neutral)
Here is the thread at Triumph Rat
T-RAT
EDIT:
Make sure it's after 2006!! Like I said, I have an R1 and it failed.
My replacement I got of ebay, it's from the ZX10-R and was a wopping £17!
CaNsA
PostPosted: 01:21 - 09 Apr 2011    Post subject: Reply with quote
https://cgi.ebay.co.uk/honda-xl125-xl-125-varadero-reg-rec-recifire-charging-/300489297272?pt=UK_Motorcycle_Parts&hash=item45f68ecd78
you are welcome
There is a gap of 1 year, 294 days between these two posts...
paulfmexico
PostPosted: 21:05 - 27 Jan 2013    Post subject: Reply with quote
Hi, after reading this post and being faced with the same situation, I was really not willing to pay the outrageous £187 demanded by Honda for this part (and wait 2 weeks for delivery), I decided to give this a try. I bought a Regulator for a R1 for £50 plus delivery from ebay, snipped the wires, connected them up like for like and its working fine....so far! I checked with a voltmeter and its putting back into the battery 13.7 volts ish, I drove about for a day with no problems at all, if anything goes wrong I will update this post but so far so good. I dont want anyone else being ripped off by Honda, the one I bought fits the backplate perfectly, I hope that this helps some else!!! Best regards, Paul.
uberkron
PostPosted: 22:01 - 27 Jan 2013    Post subject: Reply with quote
Reg rec contain the same parts 99% of the time, for sub litre bikes at least you can substitute almost anything. Just dont use one from a 50 cc!
i ride a zip 50 2smoke. It overtakes a hundred times a day.
There is a gap of 182 days between these two posts...
anand1
PostPosted: 13:09 - 29 Jul 2013    Post subject: Reply with quote
Hi,
Last week after reaching my work place on Varadero 125(2008), there was rotten eggs smell near my battery and could hear a alarm sound which went off after sometime. The same day evening while returning home the bike stopped on the road abruptly and has no power coming when i turn the ignition ON. RAC tried charging the battery, but in vain and had to tow to the garage.
The garage billed me £115 for new battery and bulbs and went fine for 2 days.On the 3rd day, same smell and alarm was heard again. After browsing the web found this link and one more which says battery was cooked up due to reg rec failure. As cant afford to pay another £191 for reg rec wanted to change the reg rec by using the above alternative suggestions.
Before proceeding, i just want to make sure this will be rectified if i change the reg rec or needs any more tests?
Do i also need to change the battery?
Also can you guys give me the link to alternative reg rec as said above R1/R6 or this ebay: https://www.ebay.co.uk[/url]/itm/NEW-GENUINE-YAMAHA-FZ1-01-05-R7-99-MODEL-REG-REC-P-N-5FL-81960-00-/161050953369?pt=UK_Motorcycle_Parts_13&hash=item257f628699
Thanks.
Timmeh
PostPosted: 13:36 - 29 Jul 2013    Post subject: Reply with quote
115 for a battery? Jesus, they saw you coming. You can get them for about 15-20 quid.
As stated several years ago, most reg/recs are universal providing that they're 3ph and rated appropriately.
uberkron
PostPosted: 05:27 - 30 Jul 2013    Post subject: Reply with quote
My main trade is auto electrician, whenever bikes come in with a fried reg i lust fit a 50 amp general purpose reg/rec. They are direct fitment for anything that makes its power from a permanent magnet alternator. They generally contain four zener diodes. You can make your own reg/rec african style out of a bosch alternator rectifier plate(s) as alot of them are fitted with zener diodes to prevent overvoltage in the event of a regulator failing and giving the alternator too much excitation.,
Anybody know which bikes use a proper alternator? I wouldnt have thought thered be many out there.
The only con of using a higher rated reg/rec is that there is more power lost in the diodes so in the case of most bikes its fine, but scooters tend to only have 2 or 3 amps available and this will be less if a 50 amp reg/rec is used.
Bezzer
PostPosted: 08:14 - 30 Jul 2013    Post subject: Reply with quote
Surprisingly a lot of the more common Suzukis, mainly oil cooled models, haven't got an inbuilt stator with separate reg/rec but use an external alternator with an inbuilt reg/reg, e.g. Bandits, Teapots etc.
They are pretty robust and not known as a weak point.
PostPosted: 08:15 - 30 Jul 2013    Post subject: Reply with quote
Moto Guzzi and BMW use them on many bikes, sometimes Ducati. Older eastern European 2-strokes too. I've noticed a few new sportsbikes with stand-alone alternators in a similar fashion to a car one but I couldn't name one.
There are probably more bikes that use an improper alternator though. A surprisingly large number of particularly small capacity and offroad bikes use a split single phase for both the charging (half rectified, unregulated) and the lighting (unrectified, unregulated). They may or may not have a seperate coil to generate the spark.
My Royal Enfield has a three phase, 12V magnetic alternator but only uses two of the phases for charging. The third is used for regulated AC headlights. I have a standard 3-phase reg/rec off a ZX6R on it with just two of the phases connected.
Fizzer Thou
PostPosted: 11:37 - 30 Jul 2013    Post subject: Reply with quote
My Exup-R has a seperate Generator that is easy to replace/repair.In 55,000 I have only had one small problem with it.
https://www.cmsnl.com/yamaha-fzr1000a-1990_model9589/partslist/C-08.html#results
I shuddered when I saw the price of a new item Shocked
Always have a 'Plan B'
anand1
PostPosted: 13:29 - 30 Jul 2013    Post subject: Reply with quote
Placed an order for the following reg/rec as it states 5 wired and 3 phased. Also the advert states suits for honda 150cc which should do with my Varadero XL 125 V8.
https://www.ebay.co.uk/itm/Honda-150cc-5-wire-3-phase-regulator-rectifier-v920-/300678008778?pt=UK_Motorcycle_Parts_13&hash=item4601ce4fca
The last post was made 12 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 141.68 Kb
