Gear shift jammed, why it pays to be thorough...
krebsy
PostPosted: 15:10 - 06 Mar 2006    Post subject: Gear shift jammed, why it pays to be thorough... Reply with quote
Swapped my Divvy exhaust this weekend, was going to blog it but all it would be is swearing Smile.
Exhaust fitted (Motad 4-1) after 2 days of ripping the old Yamaha stock one off and cleaning up the remains of the bike. Thought I'd take it for a test run afterwards and managed to get 2 miles down the road before my gearshift jammed and I was stuck in 5th gear.
Not a fun time after the weekend's worth of work I had just put in.
Managed to limp the bike home and could not get the gearshift free. It had happened once or twice before where the bike wouldn't change gear but with a bit of "extra pressure" i.e. a solid stamp on the shifter then it would free up. I had the thought that something might be out of shape (a gear shift fork, push rod or something else in the gearbox) and was planning to get it checked at the next service.
This time, no amount of pressure would get things moving.
Luckilly I have just taken out breakdown cover and called for a guy who could do roadside repairs (rather than just pick it up and cart to the garage) who turned up and checked it over. The lever was pretty solid and he recommended taking it into the garage monday or tues, based on the fact that the bike had done 30k and probably needed the gears re-doing.
Found a local shop that was open (Silversone superbikes in Stony Stratford) who could take the bike in today and "resigned" myself to borrowing a friends 3 Litre peugeot 406 coupe for a day or so.. Smile
Phoned the breakdown service again (CMG) who came out to pick up the bike. The guy took a quick look and said, "Do you want me to take this to the shop? I could fix it right here and now."
"Go ahead", I added with a happy sense of relief (that I would have the bike back on the road in minutes).
The left hand foot rest is bolted on in a few places, one right under the gearshift. It seems that a bolt had worked it's way loose (nowhere near the exhaust system I might add so I definitely didn't muck up the exhaust swap Smile ) and had jammed under the lever. I guess that in the past the weight on the lever had popped it back into the bolt-hole just this time it had come out too far and jammed.
5 minutes later the bolt was secure back in the bike and the gears were merrily shifting up and down with no issues.
So, after fearing a gearbox re-build it was all sorted out by a thorough check and an allen key... Smile
K.
What's my New Year's resolution?
1280 x 1024.
ZRX61
Victor Meldrew
PostPosted: 18:02 - 06 Mar 2006    Post subject: Re: Gear shift jammed, why it pays to be thorough... Reply with quote
WTF???? 30K for a tranny rebuild?? the guy is a clueless twat.
Redd
PostPosted: 19:17 - 06 Mar 2006    Post subject: Re: Gear shift jammed, why it pays to be thorough... Reply with quote
Wow...the top bolt, left hand foot rest, on my XJ600n (naked Divvy) worked itself loose on me last week. It vibrated all the way out and I had to ride with almost no weight on the left foot peg because it was pulling away from the bike...and taking the exhaust with it Shocked
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
PostPosted: 19:23 - 06 Mar 2006    Post subject: Reply with quote
Roadside breakdown guy earned his pay then. Neutral
krebsy
PostPosted: 11:49 - 07 Mar 2006    Post subject: Reply with quote
The first guy had come up from London (90 mins) to have a look as well. I had specifically requested that someine who could do Roadside repairs come out as well. The bolt is pretty much hidden behind the gearshift and I didn't spot it as well. I'm glad then the exhaust is only on the right side now.. Smile . I'll stick some threadlock on the bolt at the weekend just to be sure.
Still, I'm happy that the bike is back on the road as I've a 200 mile round trip tommorrow to do.
BTW: I have 2 Divvy end cans now on my garage floor. Does anyone have a picture of a brand new one so I can compare the state mine are in? I don't know how to test them to see if they are any good and I'd sell them on if they are not too damaged. Where they connect to the downpipes will probably need a bit of touching up so I need to know how much pipe there should be at the ends...
K.
1280 x 1024.
Nb
PostPosted: 21:26 - 07 Mar 2006    Post subject: Reply with quote
Slightly off topic but have you used these people before? Was thinking of taking my bike there for its next service, since they are close to me.
krebsy
PostPosted: 10:27 - 09 Mar 2006    Post subject: Reply with quote
Not been there for anything major but they seem pretty decent and clued up...
1280 x 1024.
The last post was made 20 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.95 - MySQL Queries: 16 - Page Size: 57.51 Kb
