Van buying advice
Quote Me Happy
PostPosted: 18:33 - 29 Apr 2008    Post subject: Van buying advice Reply with quote
Hello chaps,
Been thinking about buying a van, something reasonably cheap and cheerful, for maybe under a £1000. Although I have sort of picked that figure out of thin air.
Would I be able to get a reasonable van for that? Thinking about something like a Transit but anything really as long as I can fit at least two MX bikes in there although three would be nice.
I saw this on Ebay today, didn't look particularly hard as am just thinking about it but that seems a reasonable price for a van with a long MOT.
Is there anything in particular I should be looking for? Also, I know it depends on the individual, but what is insurance like on this type of vehicle?
That's about it really.
Thanks.
michael j
PostPosted: 19:32 - 29 Apr 2008    Post subject: Reply with quote
That seemed like a good deal on the Transit and is exactly the sort of thing I'll be looking for when I sell my current Transit. Also consider VW Transporter, a better drive and bargains can be found.
You don't want to spend a little bit more and buy mine do you?
Ducati 996
WildGoose
White Van Man
PostPosted: 19:33 - 29 Apr 2008    Post subject: Reply with quote
I have become a bit of a Transit connoisseur over the past year, so bear with me.
You will fit 2 MX bikes and a bit of gear even in a low roof SWB, so anything bigger is a bonus.
For that money, don't consider anything but a Transit, you really can't beat them. Backbone of Britain and all that, and for a reason.
Aim for the smiley grill one, known to the geeks as the Mk5. Availible from 95 ish to 2001 ish. Obviously the later the better, as Transits main stumbling point is rust.
I am learning, that its all repairable, but helps if you are handy with a welder yourself to do it on the cheap. If you want no issues with rust, then go for the most rust free one from the off, and keep on top of rust protection/removal.
Bad areas for rust include:
-Bottom of the back doors.
-Inner/outer door sills and footsteps (Remove the trim if necessary to get a good luck)
-Floor
-Inner/Outer wheel arches (the outer will be obvious, the inner not so much.
-Shock absorber mounts.
-Front crossmember.
-Underneath generally, get on the ground on your back and go crawling looking for it, crossmembers etc.
With the floor and the arches, if its ply lined, make sure you get a look below/behind the ply as it hides a multitude of sins.
They come in either petrol or diesel, the diesel comes turbo or normally aspirated, normally aspirated is gutless (particularly on hills) but simpler and more reliable.
I'd recommended the diesel one way or the other, as the lump is solid and can return reasonable fuel consumption (non turbo). Biggest thing to check is the cam belt, if it hasnt been done, then either walk away, or do it yourself immediately you get it home. If it fails however, its often simple to repair, but slightly pricier than simple changing the belt. It's a simple enough job with a haynes manual (If I can do it, anyone can)
If the oil filter shows signs that its been on their for years, forget it, you want ideally someone who has been bothered to change the oil.
If it's a good starter from cold, this is a bonus, as quite a few can be a bit reluctant, just seems to be a feature.
Look for excessive play in the steering, if its too excessive, will probably need a new rack.
If the clutch feels dodgy/judders, then could be an indicating of either it being worn out, or the rear crankshaft oil seal leaking (which is common) again not major issues, all repairable for reasonable money, but good to not have the issue their straight away.
A good feel from the gearbox is a bonus, but replacement boxes are cheap as chips and plentiful, so not a major issue.
If you buy one, aim for one with more than one key, ideally to include the red master key. The 95+ models have coded keys linked to immobiliser system, you can't start it without the key, and getting a new set cut and coded is probably the most expensive thing I am looking at doing (£80-150 for a new set of keys from scratch).
The 3 point centre sealbelt on the bench seat, is not repairable or changeable. So if it doesnt work, you will be looking at a new seat.
Your example from ebay, looks fairly typical, check all of the above and go from there. He doesn't give much away with his description, but the mileage is very acceptable, mine has 220k.
I paid £780 for mine, and have slowly discovered all the niggling problems, but repaired it mostly for not much cost apart from my labour time. Total including purchase price is still under 1k.
Spares are cheap and plentiful, and there are lots of pattern parts about.
The transit forum is a great place for advice.
If you need any more advice, drop me a PM.
Hope this helps.
Quote Me Happy
PostPosted: 19:37 - 29 Apr 2008    Post subject: Reply with quote
Cheers chaps Thumbs Up
Wildgoose that is some great info, thanks Very Happy
Mike, yours is far too nice and will be out of my price range Sad
WildGoose
White Van Man
PostPosted: 19:38 - 29 Apr 2008    Post subject: Reply with quote
For the scrotes and everyone else....
OMG TRANSIT FTW. Thumbs Up Mr. Green
Garry, Tits, Punch, Coat, Door, Gone.
kthnx.
R6jonny
PostPosted: 21:11 - 29 Apr 2008    Post subject: Reply with quote
If you get one Joe can me and Wave2k borrow it to get to the 'Ring ??? pretty please
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
Phoenix
Twisted Firestarter
PostPosted: 03:11 - 30 Apr 2008    Post subject: Reply with quote
Just remember a transit will require van insurance (commercial) rather than car so will in general cost you a lot more, especially if you're young.
If you only need to put a couple of MX bikes in you could consider getting a cheap MPV like an espace. You'd get an alright one for less than a van, cheaper to insure and with the rear seats out you can get bikes in the back, I've seen a fully faired NC30 go in one comfortably, am sure 2 MX bikes might go in depending on height.
Ant
PostPosted: 08:02 - 30 Apr 2008    Post subject: Reply with quote
pho, i've had vans on a car policy (escort,combo,scudo &transit), that was with cis. i use evan insurance now for buisness use (you can still have social,domestic and pleasure tho)
04 ZX10R ~
Cigaro
PostPosted: 11:02 - 30 Apr 2008    Post subject: Reply with quote
I've had vans on a car policy too (Norwich Union), but some insurers (Directline) wouldn't touch me because of my age and the type of vehicle. Presumably because they think you're lying and you're going to use it for commercial use.
nrml76
PostPosted: 20:20 - 01 May 2008    Post subject: Reply with quote
If it is just to ferry MX bikes across the country, why not just buy a trailer? Surely it would work out cheaper in every way.
Everyone who lives dies, yet not everyone who dies has lived. We take these risks not to escape life, but to prevent life from escaping us.
Quote Me Happy
PostPosted: 20:24 - 01 May 2008    Post subject: Reply with quote
Not when you have to get a car to go with it.
nrml76
PostPosted: 21:48 - 02 May 2008    Post subject: Reply with quote
Ah I see. I assumed you had a car also.
Quote Me Happy
PostPosted: 09:03 - 03 May 2008    Post subject: Reply with quote
I do have access to a car and have considered a trailer but I think overall a van will be more useful.
WildGoose
White Van Man
PostPosted: 14:06 - 03 May 2008    Post subject: Reply with quote
Agreed, van's are far better and safer for towing as well, so you can have the best of both worlds if you wanted.
Sparks!
Sir Tart-a-lot
PostPosted: 14:24 - 03 May 2008    Post subject: Reply with quote
I'd reccomend a Fiat Scudo (or Peugeot expert/citroen dispatch.. all the same) you can get a 1.9D or maybe a TD for that money, but it'll be a bit scruffy... can get 3 mx bikes in the back at a very tight squeeze.. 2 and gear comfortably.. 2 sports bikes at a squeeze..
I've got a 01 1.9 JTD and it's been very reliable (so far!) its comfy and fast, spacious and suprisingly nice to drive (it's like a car) the older non-turbos in your price range are apparantly really slow though.... I wouldn't fancy a tooo old french/italian car either... but if you can stretch to about £2/£2.5k you'll get a nicer JTD or HDI model around 01/02 year.
Only thing with them is little things tend to go wrong every now and then.. I've had to fix the central locking twice so far, once the speedo went weird then fixed itself, and the door check strap is knackered, but that's just tiny easy to fix things.... plus point is GSF Car parts sell lots of cheap parts so fixing is usually cheap and easy.
IMO with vans it's better to wait and spend the extra to get something half-decent as in my experience a cheap van is more hassle than it's worth as I know from 1st hand experience how workers treat them.... some of our companies 06 fiat ducatos are in a terrible state already Sad
I waited AGES and managed to get a 1 owner from new van in good condition and it was defnietly worth the wait.
Oh you can also get into NCP car parks and parking is easy as its no longer, wider or bigger than a car.
WildGoose
White Van Man
PostPosted: 14:37 - 03 May 2008    Post subject: Reply with quote
Can't say I agree with your recommendations, but you make a good point about how workers treat vans, goes for any commercial vehicle that is used daily by people who don't hold responsibility for them. They get run into the ground and generally treated like crap, why close the door like a normal person when you can slam it with a steel toe cap boot?
Mine was an ex-builders van, so probably the worst choice you can make for a van to be well looked after, but i've still found it all fixable for a reasonable price. Comes down to cost, if you can afford it, buy the best you can, but in the lower price ranges under 1k, you simply can't be too fussy unless you want to go half way across the country.
Can get a SWB tranny in all the same spaces you can get a car, pretty much, apart from multi-storey car parks probably Wink
Sparks!
Sir Tart-a-lot
PostPosted: 14:47 - 03 May 2008    Post subject: Reply with quote
Yeah I had a SWB hi top transit for a while and a SWB normal transit, fine length wise, think the normal "just" fits in NCP car parks with no roof rack. Not that this is a big issue tho Laughing
Transits are alright, but I found them slow, loud and uncomfortable to drive long distance, even worse as a passenger. I went from portsmouth to Enfield for work, took it in turns to drive with someone and even with driving and as passenger i wanted to DIEE it was so uncomfortable Laughing but otherwise good vans, I would say reliable, but I blew one up and the other started randomly leaking, both had around 70k miles and I look after work vans (dad owns the company so its in my interest Wink)
Got a Fiat Cargo 1.9 at the minute, don't think you'd fit a bike in anyways but its fast and nippy, but very cheap and basic.
Also had a ducato 2 JTD. I think they are decent vans if you get a newer one. Fast enough and I was using the work one for taking my bike about for a while and had no issues, loads of space in the back too.
I really wouldn't reccomend a sub £1000 van unless you find a real bargain.. but for that money I guess the best you'll get is a transit.
At least parts are cheap Laughing
WildGoose
White Van Man
PostPosted: 16:07 - 03 May 2008    Post subject: Reply with quote
Agreed about the noise, and the slowness Laughing . Above 60mph you will want to die most probably, and mine still has the noise insulation in the engine bay!
The newer transits Mk6 (2000 on) and Mk7 are much better in this respect as they are more like a car, but I hate them because of this fact. They have no character or soul and If I wanted to drive my car, I would. Front wheel drive in a van is wang as well, although makes the clutch easier to change apparently.
As for slow, simply read this as economical Laughing The non turbo diesels like mine wouldn't pull the skin of a rice pudding, but don't take this to mean they won't /pull/. It'll get you there, up a 10% hill, towing 2 tons etc. As long as you are patient enough to let it. Probably utilising first gear at some point Laughing
Your vauxhalls, fiats, citroens, peugeot etc, all fine when new, but will fall apart in front of your eyes, and be ready for replacement after 3 years. Probably why contract hiring these kind of vans is more the done thing for most van owners these days.
Sparks!
Sir Tart-a-lot
PostPosted: 16:21 - 03 May 2008    Post subject: Reply with quote
Agreed on them falling apart.. My Fiat is fine, but I've had to fix quite a few little things Rolling Eyes it doesn't cost much or take much time, but it's kinda annoying when random bits fall off Laughing it's really nothing serious (not yet anyways Laughing) so hasn't put me off.
Goose does your transit have any loud rattles on idle? not from engine but from trim and stuff? One of our work ones, I can't drive the thing more than about 5 minutes because it makes sooooooo much rattling noises from the bulkhead, trim and seats that it gives you a headache...
I forgot something but you should pick up a Volkswagen Transporter T4 for about £1500 in okay condition.. I couldn't reccomend them enough to be honest.. I loved mine, had to sell it because I had money problems and needed to sort myself out. But it was amazingly reliable, I had a 2.5 TDI LWB which would fit loads of stuff in it and I'd happily drive that just about anywhere. You should get a 1.9TD SWB for £1500 in fair condition.. they last forever and the build quality was really good IMO. The 2.5TDI goes really well.
WildGoose
White Van Man
PostPosted: 16:48 - 03 May 2008    Post subject: Reply with quote
I've sorted the seats by removing most of the pointless plastic trim, and I only have a small wooden bulkhead that I built myself.
Most of the trim from the cab has been removed as it mostly just gets in the way, and most of the screws have long fallen out.
I try to keep it as minimalist as possible, and its also less to remove when you wanna fiddle with something Laughing
Fahim
PostPosted: 21:58 - 04 May 2008    Post subject: Reply with quote
How would you secure the bike in the back of the van though?, are there special types of ropes or something that you use to tie them down etc?
Might come in handy if i ever want to go and collect a new motorbike and if i ain't insured i can take it in the back of my dads LT35 MWB.
Current Bike: CBR125 ---> Written off Theory Test Passed: ---> 8/04/08 ---> A2 Test Booked:8/05/08 - Failed to turn up (had an accident and broke my leg in 3 places!)
WildGoose
White Van Man
PostPosted: 18:16 - 05 May 2008    Post subject: Reply with quote
Most vans have some tie down rings in the back that bolt through the floor or similar. Easy to make/buy if not. Then you can use ratchet straps or ropes to hold the bike in place, and bits of wood braced crossways to act as wheel chocks.
pits
PostPosted: 12:22 - 12 May 2008    Post subject: Reply with quote
O'rly? you should meet my mate paul, ex ford mechanic, and was the smiley face transit specialist. the N/A is noramlly gutless. but if you change the cambelt tighten everything up, set the tappets etc then you can get a 75ps na transit sideways on a roundabout, and spin the rear tyres, and on a private stretch of flat road get 105mph out of one
He did the cambelt, full tappet adjust, advance the timing a tiny bit, new fuel filter, wind the throttle out and fit it all back together in 2 hours. Went like stink then
Phoenix
Twisted Firestarter
PostPosted: 15:06 - 16 May 2008    Post subject: Reply with quote
While he was there he should've calbrated the speedo too. Could only get about 102 absolute max out of our 158bhp LT35s, the Sprinter would get about 108....indicated, sat nav would indicated about 97-98mph.
PostPosted: 19:32 - 16 May 2008    Post subject: Reply with quote
In the large majority, people selling vans are lieing, blagging, no-good scum. This makes it interesting finding the right one, with so many advertised as good, or even not-too-bad being vehicles you wouldn't want to sit in, never mind drive.
Maybe it's just me, but I've been to see a hell of a lot of vans that massively worse than described, even when on the phone I've gone through things that they've said are fine and are totally knackered when I get there.
At this sort of price, I'd probably just be looking for one in decent nick near to you for the price.
My SWL lot-top transit managed to get an SV650, GSXR750Y1 and 675 in at once, along with jerry cans, tools and the like. Was rather a squeeze. Consider the height for dirt bikes - though I think the CCM fitted in on the SM wheels, so most trail bikes should be ok as that's pretty tall even with the SM wheels.
Get one with a tow bar if you think you might need some /serious/ bike transportation.
Oh and I could do first and second gears doughnuts in the tranny too Very Happy.
The last post was made 18 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 136.37 Kb
