help with my nsr back wheel
code guru
PostPosted: 21:50 - 14 Jun 2006    Post subject: help with my nsr back wheel Reply with quote
ok i whant 2 take my nsr back wheel off 2 fit a new sproket. now i taken the nut off one side and i tryed 2 undo it from the other side but the axel or spindel wot ever its call just keeps moveing around and it wont come out Confused
i dont know wot 2 do. because by back tyre needs a new valve as well because if i pump it up it losses air so atm is ok well it rides ok but it need pumping up.
thanks
shaun_04
PostPosted: 21:56 - 14 Jun 2006    Post subject: Reply with quote
the other side isn't a nut, it's part of the big bolt.
just hit the other side of the axel (the bit sticking out from when you removed the nut) with a mallet and it will come out. All should become obvious from then on. Remember to keep track of the order that spacers and bearings etc came off.
code guru
PostPosted: 22:17 - 14 Jun 2006    Post subject: Reply with quote
lol i tryed it before with a big hammer and fucked the end off the thing so the nut wouldnt go on but i had 2 grind the end off it off Embarassed
anyway all try again 2moro then with a mallet
thanks
Handsome
PostPosted: 22:19 - 14 Jun 2006    Post subject: Reply with quote
That's your Problem, if you'd have tried a Big Hammer it would have been sorted by now.....
code guru
PostPosted: 22:24 - 14 Jun 2006    Post subject: Reply with quote
i did try a big hammer but it wouldnt move Sad
Handsome
PostPosted: 22:27 - 14 Jun 2006    Post subject: Reply with quote
Doh! You missed it don't worry.....
Did you HIT it or TICKLE it, or try WD40 or the like to Free it a little.....
mr jamez
PostPosted: 22:34 - 14 Jun 2006    Post subject: Reply with quote
If you haven't got the bike on stands with the back wheel in the air, the weight pushing down on the spindle is going to make it difficult to get out. Next time you want to smack a threaded bolt with a hammer, wind a nut on and hit that instead Wink
code guru
PostPosted: 22:36 - 14 Jun 2006    Post subject: Reply with quote
yer i got a back paddock stand,
yer ill do that 1st then put the nut on like so it hits the nut and not the bolt
The last post was made 20 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 58.21 Kb
