| headlamp |
 headlamp World Chat Champion
 Posted: 15:31 - 17 Jul 2006 Post subject: External Hard Drive Problem. |
Being a sensible sort of fellow, I decided to invest in an external hard drive for back up.
Yesterday went to back up some music and pictures - by switching it on and whilst my PC recognises a Hard Drive in 'G' is fails to recognise it as a Seagate EHD and I get a message saying would I like to format the drive now? As I have already transferred loads of data across I guess that isn't a good idea.
It does the same in other USB hubs and I've tried disconnecting other devices potentially using the same hub.
Any ideas anyone?  ____________________ Using a mobile phone while driving a car should be made a capital offence! |
| map |
 map Mr Calendar
 Posted: 15:35 - 17 Jul 2006 Post subject: |
Check if it exists under Device Manager. If it does then remove it. Make sure unplugged then reboot. When started plug it in again.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| headlamp |
| Mister James |
 Mister James I want to believe!
| headlamp |
| headlamp |
 Posted: 20:12 - 17 Jul 2006 Post subject: |
Right I tried that - it still doesn't work - it recognised it for a moment - then in 'My Computer' it came up Disc Drive G & still won't open!
Are there any repair kits for a Seagate EHD (250gb) - it's less than 4 weeks old!! ____________________ Using a mobile phone while driving a car should be made a capital offence! |
| T1z3R |
 T1z3R World Chat Champion
| headlamp |
| T1z3R |
| Mister James |
| G |
 G The Voice of Reason
| headlamp |
| T1z3R |
| headlamp |
 Posted: 23:40 - 17 Jul 2006 Post subject: |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
 Posted: 19:16 - 19 Jul 2006 Post subject: |
Is it one you can HOT SWAP? as in you can plug it in when the pc is on?
Some don't like that, my Maxtor external drive was plugged in to USB2 when I started using the Firewire lead instead I hot swapped it and it read that the disc was empty.
Turned everything off, re connected all the leads (making sure the hard drive was turned on) then started the pc. Everything was back as it was before I unpluged the USB lead.  ____________________ Andy Sez....
F.Y.Y.F.F. |
The last post was made 20 years, 70 days ago. Instead of replying here, would creating a new thread be more useful? |
