| Milo |
 Milo World Chat Champion
 Posted: 14:53 - 24 Jun 2004 Post subject: Idea to further boost fuel economy |
I've never heard of this being done but I wonder if it will work?
You've heard of electric cars and bikes but what if they had a built in generator? This engine does not directly power the vehicle but instead runs at it's peak revs/power/efficiency to charge the batteries until full and only cuts in again when the levels run low.
I know because of the whole conversion to electricity and stuff it'd lower the efficiency but surely it'd still be pretty darn good?
Also a much smaller engine would be needed to power the vehicle as the acceleration is provided by the motors - a 250cc engine for a car version would surely be enough?
I've been thinking about this for ages and in a few years I'd like to build a concept - but I'd need the money, garage and knowhow first!
Any thoughts on this?
Ads ____________________ Shaft drives rule.  |
| Ninja |
 Ninja Caption Abuser
| Mr C |
 Mr C World Chat Champion
 Posted: 15:18 - 24 Jun 2004 Post subject: |
Basically how diesel electric trains work, and there are hybrid cars around which use a similar system.
However there are problems. You would certainly need more than a 250cc engine. The electric motors weigh a ton (although you can play with the eletrics and also use them as brakes which generate power as you slow down). The batteries weigh a ton.
Also, how do you fancy sitting at traffic lights with an engine screaming away under the bonnet?
| Mr C |
| Milo |
 Posted: 16:36 - 24 Jun 2004 Post subject: |
So not ideal for bikes then.
How about a few dynamo's on the tyres to power some electric motors and do away with the engine and battery's altogether? Just need a small run-start in the mornings and if you stop at the lights.  ____________________ Shaft drives rule.  |
| Mr C |
| Flip |
 Flip Super Spammer
 Posted: 01:11 - 25 Jun 2004 Post subject: |
A better idea for fuel ecomony would be to steal fuel  |
| clemsta |
 clemsta Scooby Slapper
| Frost |
 Frost World Chat Champion
 Posted: 05:22 - 25 Jun 2004 Post subject: |
such things have been done in cars in the past, where the engine cuts out when its being inefficient and an eletric motor kicks in running off batteries charged off the engine.
in theory what you say could/would work. where by the engine premenantly runs at peak efficiency charging a batterie which then powers the wheels. however if the engine was not powerful enough then when the driving is inefficient(traffic) then battery power is going to drain as the motor is using more power than the engine will produce. similarly when the motor is running efficiently, the engine will be producing more power than neccicary.
Such a system could possibly be built and used in a car however as it uses petrol still, the improvement in efficinetcy would not be as high as if it were a pure electric car or a fuel cell car.
Such a design could not be implemented on a bike as the weight of batteries, generators and eletric motors would make the bike so heavy as to cancel out any increase in efficiency.
nice idea though  |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 05:44 - 25 Jun 2004 Post subject: |
I personally prefer electrically driven supercharged smaller capacity engines. Get the same power as a 1.8 from a 1.0. No turbo lag, lower bsfc (brake specific fuel consumption), variable boost etc etc etc.. That or a compression ignition engine running on powdered charcoal. Though I'd rather use biomass for fuel when the petrol goes awol.
As far as using smaller engines for hybrid cars, you still have to produce the power, and still burn the same fuel. Though obviously anything which will let it burn at it's peak efficiency is better. Electric motors might be as efficient as 90%, but with 90% of 20-35% isn't an improvement.
Almost 5am isn't my best time for thinking about these things though.  |
| Milo |
There is a gap of 2 years, 35 days between these two posts... |
| Milo |
 Posted: 12:51 - 30 Jul 2006 Post subject: |
Well darn it...someone's gone and done it.
I was at the Motor Show yesterday and there was a new Mini with 4 hub-centre motors and a 240cc twin cylinder generator - this was all that was enough to keep it juiced up...and it was 250BHP+ according to the specs.
Can't remember the company and can't find it on Google - did anyone else see it there?
Told you it would work! / / /  ____________________ Shaft drives rule.  |
| 0ddball |
 0ddball World Chat Champion
 Posted: 13:23 - 30 Jul 2006 Post subject: |
Look on the bright side, if you could have done it you'd have needed about £1m just to build the concept. It has more circuit boards then a branch of Dixons.
Bit of info on it here, actually 640bhp.
https://carscoop.blogspot.com/2006/07/electric-powered-mini-qed-concept-with.html
Though something doesn't seem quite right about it. All that energy from a tiny 250cc ICE as the primary source. I think there may be a few skeletons in the cupboards that they aren't mentioning. |
| Zimbo |
 Zimbo World Chat Champion
 Posted: 15:40 - 30 Jul 2006 Post subject: |
There's a Dutch firm called Star Twin making a 1200cc TDi sportsbike, based on a modified VW Lupo TDi engine mated to an FJ1200 gearbox.
The bike weighs around 220kg, puts out around 120bhp and an eye watering 250 foot pounds of torque in performance trim(that's more than a Triumph Rocket 3, for comparison a Gixxer thou puts out about 80 foot pounds) and returns around 150mpg.
https://www.gizmag.co.uk/go/4273/1/
https://i71.photobucket.com/albums/i148/zimbo16/DSCF4200.jpg |
| instigator |
 instigator Super Spammer
| Milo |
| Raffles_Gentleman Thug |
 Raffles_Gentleman Thug Trackday Trickster
| Milo |
| Itchy |
 Itchy Super Spammer
| extreme3d |
 extreme3d World Chat Champion
| colin1 |
 colin1 Captain Safety
The last post was made 20 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
