Chain lube..?
Cruiser
PostPosted: 21:32 - 09 Aug 2006    Post subject: Chain lube..? Reply with quote
hey people,
Ive gotta 2001 suzuki bandit with an O-ring chain on it..
at the moment to lube it, im puttin scottoil on it about every 80 miles or so as the scottoiler doesnt work, but ive heard a lot about how bad they are... can anyone recomend a really good lube or wax etc i can use instead, or is scottoil the best??
Thanks for any help,
James.
Finglonga
PostPosted: 21:36 - 09 Aug 2006    Post subject: Reply with quote
Scottoilers are very good if working properly, but just putting the oil on the chain every so often is no good as it is to thin. It is supposed to be contantly feeding the chain.
Any good chain lube/wax is ok, don't think there are many bad ones around nowadays.
You would be better fixing the Scottoiler though. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
Essex_Mike
PostPosted: 21:41 - 09 Aug 2006    Post subject: Reply with quote
i've only recently got my bike, is motul chain lube any good? as i went out and bought a can of it today. but no actually had to use it yet.
CBT - Passed - 14/07/2006 Theory - Passed - 19/08/2006 A2 test - Passed -19/07/2007
Previous Bike - Suzuki EN125
Current Bike - Suzuki GS500F
markandmindy
PostPosted: 22:06 - 09 Aug 2006    Post subject: Reply with quote
so why isn't your Scottoiler working? had one on my Bandit and it worked a treat, so much easier than lubing after every ride.
Cruiser
PostPosted: 23:02 - 09 Aug 2006    Post subject: Reply with quote
im not sure why its working, it just wont push the oil out through the tube properly. it was dodgy when i bort the bike tho, an loads of peoiple say they aint rly any good as they only lube one side. so there all good, none better than others ???thanks for the help guys
Marci
PostPosted: 11:31 - 10 Aug 2006    Post subject: Reply with quote
Someone should point out to them the affects of gravity on fluids Rolling Eyes
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Misc
PostPosted: 11:59 - 10 Aug 2006    Post subject: Reply with quote
I was just putting the lube on the rollers, but was told it's got to go on the actual rubber hoops & where they link? I was using Silikone, it turns white on the chain.
feef
Energiser Bunny
PostPosted: 12:08 - 10 Aug 2006    Post subject: Reply with quote
the lube goes on one side, but due to the thinness of the fluid, the fact that there is a way thru the rollers from one side to the other, and the forces involved (centrifugal and gravity) the oil gets to all parts of the link easily. If you're really bothered, get a dual feed.
https://www.riderstation.com/catalog/prodimages/IMAGE2_SDIweb.jpg
because the scottoiler is constantly lubing the chain, rather than periodically, it can extend chain life quite a bit.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Marci
PostPosted: 12:10 - 10 Aug 2006    Post subject: Reply with quote
That's due to the high amount of PTFE in it... I just use 3-in-1 ChainOil with PTFE... same stuff effectively, but cheaper.
squid36
PostPosted: 13:09 - 10 Aug 2006    Post subject: Reply with quote
i use proffi dry lube from hein gerrike , its a ptfe lube that doesnt attract grit and road shit because as the name suggests its a dry compuond it doesn`t protect against water so if i ride in the rain i always coat the chain in oil after !
they say life begins at 40 but i think it begins at 140 !!!!!!!
https://www.mayhem-paintball.co.uk/ essex premier paintball site
Finglonga
PostPosted: 17:22 - 10 Aug 2006    Post subject: Reply with quote
Check the vacuum pipe from the carb, it may have come off or cracked, stopping it from working.
As for your loads of "peoiple" saying it doesn't work properly I wouldn't take advice of them about ant other parts of your bike as it sounds like they know jack shit about it. Wink
Andy Sez....
F.Y.Y.F.F.
Cruiser
PostPosted: 19:53 - 10 Aug 2006    Post subject: Reply with quote
cheers for the help guys,
had it looked at today and been told the pipe is being crushed where it goes along under the swingarm, so all i need to do is that... it still is connected to the carb okay had that checked, so hopefully it`ll be workin again now!!!!
thanks Very Happy
The last post was made 20 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 16 - Page Size: 79.13 Kb
