2005 R1 Pinking - Pre Ignition
Boomshanka
PostPosted: 00:43 - 10 Aug 2006    Post subject: 2005 R1 Pinking - Pre Ignition Reply with quote
My 2005 R1 has 1200 miles on it. When I open the throttle in 3rd gear and above, and at low revs, (not the best practice I know!) it pinks. I never noticed it until a few hundred miles ago and my previous R1 (an 02 Fuel Injected) never did it..........Any ideas?
PostPosted: 00:44 - 10 Aug 2006    Post subject: Reply with quote
Is it stock? Power Commander? Ignition advance unit?
Boomshanka
PostPosted: 00:47 - 10 Aug 2006    Post subject: Reply with quote
Its stock......no mods
PostPosted: 00:50 - 10 Aug 2006    Post subject: Reply with quote
Mmm, shouldn't do it then.
Running lean will encourage it, but shouldn't be close enough to pinking for that to be relevant.
Has it done it on more than one tank of fuel?
dXm
PostPosted: 06:15 - 10 Aug 2006    Post subject: Reply with quote
Are you using RON 95 gas and above?
I used to own a 2004 R1, and always used RON 97 or 98. Using too low an octane might cause pre-det.
loply
PostPosted: 18:12 - 10 Aug 2006    Post subject: Reply with quote
Are you certain it's pinking?
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 20:37 - 10 Aug 2006    Post subject: Reply with quote
Not sure on the requirements for the R1, but often Japanese bikes have fairly low octane requirements. EG, ZZR600 owners handbook specifies 91 RON fuel.
Boomshanka
PostPosted: 23:46 - 10 Aug 2006    Post subject: Reply with quote
I,m certain its pinking, but I am using ordinary unleaded. I will put super unleaded in when I fill her up and see if that makes a difference. Might be related, but I normally get about 140 miles before the fuel light comes on, so far its showing 157 miles and no fuel warning light yet!! Running leaner perhaps, but I cant see why, on a bike that has 1200 miles on it.
PostPosted: 23:53 - 10 Aug 2006    Post subject: Reply with quote
Presume it has a lambda probe and adjusts the fueling based on the feedback from it. Could have failed which would cause a fairly dramatic change. However also worth checking things like the airfilter (1200 miles isn't many so presume it has been parked up a bit, not unknown for a mouse to eat an airfilter).
edd
PostPosted: 12:42 - 11 Aug 2006    Post subject: Reply with quote
Definitely sounds like a failed sensor, as kickstart says most likely lambda probe, but possibly a faulty MAP sensor could also make your bike run excessively lean. possibly wise to have a dealer check it out on their diagnostic gear. At 1200 miles old is it not still within warranty?
Bluespark Automotive - Diesel Tuning for Performance and Economy
Kaben
PostPosted: 14:07 - 11 Aug 2006    Post subject: Reply with quote
out of interest, what is "pinking" ??
Kaben
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
The last post was made 20 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 72.39 Kb
