| binge |
 binge Emo Kiddy
| Bigeds |
 Bigeds Borekit Bruiser
| numark1 |
 numark1 Scared of girls
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
 Posted: 02:11 - 03 Sep 2006 Post subject: |
If you remove the CD-drives in device manager, reboot, do they re-add themselves automatically, or do they still show the '!'...?
It maybe your usual IDE driver has been overwritten and perhaps windows is using it's own naff one. If the above doesn't work, download the latest Motherboard IDE drivers for your machine, and then update them in 'Device Manager'.
Did you check the cables as suggested earlier?
 ____________________ aKa: Ducky |
| binge |
 binge Emo Kiddy
| T1z3R |
 T1z3R World Chat Champion
| binge |
 binge Emo Kiddy
| T1z3R |
| binge |
 binge Emo Kiddy
| DevilWAH |
 DevilWAH Nova Slayer
 Posted: 14:25 - 04 Sep 2006 Post subject: |
ok something that can cause this is.
do you have any third party cd writing softwear installed on your PC?
roxy cd creator, or any thing else??
these are know to interfea with the windows drivers. and you can find the information about it on the microsoft knowlage base.
the only way to get around it is to uninstall the softwear and reboot!
roxy cd creator is well known for causing this. and i have a number of PC each week i see with it. ____________________ When i think of someting good to put here. it will go here
Oh and no asking what the WAH stands for |
| binge |
 binge Emo Kiddy
| T1z3R |
| DevilWAH |
 Posted: 15:28 - 04 Sep 2006 Post subject: |
very unlickly this will help i think.
the windows IDE drivers are probable the most stable you will get. however they some times do not give the same proformance as mother baord manafactured drivers.
the fix below should also work
we use this whenn we get the same problem
just go in the the registry and dele the keys
1. Remove the Upperfilters and Lowerfilters values completely from the following registry key:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4D36E965-E325-11CE-BFC1-08002BE10318}
NOTE: If you are getting a code 39 message, it may be that additional third-party filter drivers were added to UpperFilters and LowerFilters values in addition to Adaptec filter drivers. In that case, you may try to remove the non-Adaptec filter drivers first, leaving the Easy Creator filters in place to see if the Code 39 goes away. If you still receive an error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters values completely in the preceding key.
2. Restart your computer.
Desktop software required configuring**Call closed by ____________________ When i think of someting good to put here. it will go here
| binge |
 binge Emo Kiddy
 Posted: 16:24 - 04 Sep 2006 Post subject: |
Ok, I didnt understand a word of that ^
ive tried uninstalling both drivers. Restarting. Comp re-installs them, restarts again. And still they dont work.
What if I was to save everything to a memstick duo, And then format the PC. Run the Compaq drivers. And reintall everything.
Would that help?
Would doing that make me loose my virus software which im paying Monthly for?
<|Ben|> |
| T1z3R |
 Posted: 16:29 - 04 Sep 2006 Post subject: |
| binge wrote: | Ok, I didnt understand a word of that ^
Would that help?
<|Ben|> |
thats a last resort IMO.
did you search for the drivers on the link i sent you?
devils suggestion may also work but youll need step by step instructions to follow him by the sounds of it. ____________________ duck my sick! |
| binge |
 binge Emo Kiddy
| T1z3R |
| map |
 map Mr Calendar
| DevilWAH |
 Posted: 16:47 - 04 Sep 2006 Post subject: |
ok here goes
click on the start button
then click where it says run,
in the box that comes up type regedit and press return.
a program will open up with a tree/menu on the left hand pane and a big pane on the right hand side
on the left hand pane find and expand hkey local machine (click on the little + to the left of it) . then carry on expanding system... currentcontrol set... etc etc
till you can see a big list of things simmler to the {4d36e965-e....... part
left click on this when you see it (actualy on the name not on the little + symble if there is one) and in the right hand screen will apper some values.
find where is says upper and lower values then clcik once on them to highlight them and hit hte delete key. (confim you want to delete them by chocing yes)
once you have done them both jsut restart the PC.
And belive me it does work! jsut make sure these 2 values are the only thing you delete.
The registory is not a good place to play in. you can cause nasty things to start happening!!
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4D36E965-E325-11CE-BFC1-08002BE10318} ____________________ When i think of someting good to put here. it will go here
| binge |
 binge Emo Kiddy
 Posted: 19:06 - 04 Sep 2006 Post subject: |
Holy crap. You ARE a legend! It worked"!
Everyone give Much Karma to this guy!!! ^^^^
Now, Next big ??? is...
How do I run 2 moniters?
not cos I need to, Because I WANT to!
seriously. |
| NSR Mick |
 NSR Mick World Chat Champion
 Posted: 20:41 - 04 Sep 2006 Post subject: |
Dual output card or 2 graphics cards.
I run 3 one off a dual head agp card the other off a pci card.  ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| binge |
 binge Emo Kiddy
| NSR Mick |
 Posted: 23:22 - 04 Sep 2006 Post subject: |
Yes you can have monitor 1 and 2.
Most motherboards disable the onboard graphics when you install another.
do you get 2 monitors showing in your display properties. Like so
https://www.matrox.com/mga/workstation/3dws/media/Display_properties.gif ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
The last post was made 20 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
