Brake line fittings
McJamweasel
BCF Junkie
PostPosted: 21:24 - 02 Jul 2003    Post subject: Brake line fittings Reply with quote
I think I'm gonna have trouble getting Goodridge to give me a new brake line but Busters have got 'em on sale @ £10 each.
Trouble is they come with Cadmium fittings.
Are they OK for road use? Neutral
Stew
If it's good enough for top race teams...
PostPosted: 21:27 - 02 Jul 2003    Post subject: Reply with quote
They should be fine. Usually problems with corrosion occur when mixing alloy and steel fittings. Although they are probably only £10 because most people tend to go for stainless fittings so they are getting rid of the least popular types of fittings. Do they come in a strange colour combination too? or is that not mentioned?
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
McJamweasel
BCF Junkie
PostPosted: 21:28 - 02 Jul 2003    Post subject: Reply with quote
Doesn't say, but in the picture they are plain metal.
Stew
PostPosted: 21:33 - 02 Jul 2003    Post subject: Reply with quote
I'm not certain on the qualities of cadmium fittings, but I have just had a quick look online (thanks google) and it seems that they are more prone to rust/corrosion than other types of fitting (although it also says the same for chrome fittings).
Just means you might have to keep em clean a bit more than stainless ones I guess Confused
TiN
Pocket Tin
PostPosted: 21:38 - 02 Jul 2003    Post subject: Reply with quote
Get some heatshrink over the fittings to protect them.
TiN
dotgems.net
Robby
Dirty Old Man
PostPosted: 22:41 - 02 Jul 2003    Post subject: Reply with quote
your bike will be long gone by the time the cadmium fittings corrode through.
McJamweasel
BCF Junkie
PostPosted: 22:44 - 02 Jul 2003    Post subject: Reply with quote
And what are you trying to say about my bike?
PostPosted: 23:32 - 02 Jul 2003    Post subject: Reply with quote
Cadmium is fine, it just corrodes a bit. Think that line you have on at the moment is probably using cadmium fittings.
Alloy ones are lethal. As they are assembled the steel braiding will take off the anodising on the alloy, resulting in corrosion (which you probably will not see), and a few months later a hose that will split from its connectors under preasure.
McJamweasel
BCF Junkie
PostPosted: 23:34 - 02 Jul 2003    Post subject: Reply with quote
Cool. I'll see what happens with Goodridge and if they don't come through I'll give Busters a call.
Stew
PostPosted: 23:38 - 02 Jul 2003    Post subject: Reply with quote
Buster can make you up some goodridge lines anyway. I had mine made up to the specifcation I wanted (colour types of fittings).
I think the cost was something like 19 pound per line plus £1.50 for shrikwrap plus about £9 for banjos. (I can't remember exact prices but give busters a ring and see)
McJamweasel
BCF Junkie
PostPosted: 23:44 - 02 Jul 2003    Post subject: Reply with quote
Yeah, but £10 in the sale is much better than £30 you paid...
Stew
PostPosted: 23:46 - 02 Jul 2003    Post subject: Reply with quote
So true. But my comment was in reference to this...
I thought you might have been waiting for a price from Goodridge. Embarassed
McJamweasel
BCF Junkie
PostPosted: 23:48 - 02 Jul 2003    Post subject: Reply with quote
Nah mate. I've already got a line off them and it burst! I'm waitin to see if they'll replace it under the warranty.
retrofly
PostPosted: 03:34 - 03 Jul 2003    Post subject: Reply with quote
hi
how much would it cost for a single braided hose? the one i've got is to short, when my forks are at maximum length the hose stretches Confused
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Stew
PostPosted: 09:42 - 03 Jul 2003    Post subject: Reply with quote
Like McJam said, busters are selling braided lines with cadmium fittings for £10 per line. So Luke your answer is £10. (You can use your existing banjos and fittings if they are in good condition).
retrofly
PostPosted: 13:15 - 03 Jul 2003    Post subject: Reply with quote
hi
banjos? whats that?
Luke
Stew
PostPosted: 13:19 - 03 Jul 2003    Post subject: Reply with quote
Banjo bolt. The 'banjo' shaped bolt that is attached to each end of the braided hose:
https://www.gmspeed.net/images/products/B168.jpg
retrofly
PostPosted: 13:21 - 03 Jul 2003    Post subject: Reply with quote
hi
how do they fit onto the hose? do u just push it in?
Luke
Stew
PostPosted: 13:24 - 03 Jul 2003    Post subject: Reply with quote
The picture doesn't really show it as that was just an example. On the end of the braided hoses is a threaded attachment. The banjo also has a thread on it. The two screw together to form a hose with a banjo at each end. One banjo then attaches to the master cylinder and the other attaches to your brake caliper.
retrofly
PostPosted: 13:42 - 03 Jul 2003    Post subject: Reply with quote
hi
cool sounds like an easy job, just got to deal with the break fluid now Razz
Luke
Stew
PostPosted: 13:57 - 03 Jul 2003    Post subject: Reply with quote
Putting the brake lines together and on the bike is the fun bit. Bleeding the fluid through can be a pain in the arse.
PostPosted: 14:41 - 03 Jul 2003    Post subject: Reply with quote
Most original brake lines use swaged (sp?) fittings which you cannot undo (the bolt together kind are illegal in many countries). I would be dubious about reusing them anyway, and those fittings are most of the cost. I wouldn't worry about reusing the bolts though (you should use new copper washers though)
Stew
PostPosted: 15:52 - 03 Jul 2003    Post subject: Reply with quote
So the banjo parts should have come fastened to the braided lines then? Mine didnt thats all, not sure if you can see in the pic but this is how mine arrived....
https://mysite.freeserve.com/crotchrockets3/brakes/brake1.JPG
PostPosted: 22:32 - 03 Jul 2003    Post subject: Reply with quote
Not seen them supplied that that Stew. Suppose no real reason why not though
The last post was made 23 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.35 - MySQL Queries: 16 - Page Size: 129.32 Kb
