Marine Grade Chain Lube
veeeffarr
PostPosted: 00:40 - 18 Sep 2006    Post subject: Marine Grade Chain Lube Reply with quote
Any good for bikes?
Gradog
PostPosted: 01:32 - 18 Sep 2006    Post subject: Reply with quote
Never heard of it, but if it is what i am guessing it is then NO. It is designed to be sticky and keep out water, but at very slow speed. Chances are it will throw off.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
colin1
Captain Safety
PostPosted: 02:07 - 18 Sep 2006    Post subject: Reply with quote
i used to use spray on grease, but it would only cover the bits i had actually managed to point my nozzle at and spray
i took a leaf out of kickstarts book and started using old engine oil, and it worked its way all over the chain to protect better
i still use a bit of spray grease on the chain rollers, but regular oiling is good as you dont have the problem of missing a bit as the oil will get to the bits you missed
veeeffarr
PostPosted: 02:11 - 18 Sep 2006    Post subject: Reply with quote
So is marine grade chain lube any good for bikes?
Dazbo666
PostPosted: 02:13 - 18 Sep 2006    Post subject: Reply with quote
colin1 wrote:
....i took a leaf out of kickstarts book and started using old engine oil, and it worked its way all over the chain to protect better....
Jusy a thought, but would it be possible to use engine oil in a Scottoiler?? I've been considering getting one on a winter hack, but would consider using engine oil if that was cheaper but still as effective as the official Scottoiler refill
Word of the day : DILLIGAF
colin1
Captain Safety
PostPosted: 02:17 - 18 Sep 2006    Post subject: Reply with quote
i doubt it
i recommend old engine oil and a bit of spray on grease on rollers
but i have never tried marine grade chain lube
im guessing its more expensive than old engine oil or spray on grease so i guess you have the idea that because its marine it will protect from salt and water better
i think if a chain is lubed properly salt and water arent really gonna bother it, so marine grade stuff isnt worth the extra
but if it makes you happy...
as for using engine oil in a scottoiler, i think its not runny enough, also scottoiler stuff has a bit of detergent with it i think
veeeffarr
PostPosted: 02:23 - 18 Sep 2006    Post subject: Reply with quote
I've got a mate who can get hold of some.
It's for extremely fast moving chains.
THCi
PostPosted: 06:28 - 18 Sep 2006    Post subject: Reply with quote
Ive done over 5k miles on the bottle that comes with the oiler, and i still havnt run out. So, if you fit one, you'll have a while to wait to find out. But, S/O is very fine, a lot finer than engine oil, and a damned sight finer than used engine oil.
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
Zimbo
PostPosted: 07:43 - 18 Sep 2006    Post subject: Reply with quote
If you want to substitite scottoiler oil for something cheaper, chainsaw chain oil is what you need it's a quarter of the price and virtually the same product.
ram_doom
PostPosted: 08:57 - 18 Sep 2006    Post subject: Reply with quote
If you worked it into the links of the chain, it'd do a great job Thumbs Up just do it regularly and make sure its degreased before re application Wink
TL1000s, KDX200
kawakid
PostPosted: 11:10 - 18 Sep 2006    Post subject: Reply with quote
I've read so much crxp about chain lube especialy in Ride.
I buy a can from Morrisons for £1 and have had no problems.
People can go quite anal on things.
Mark_petty
PostPosted: 11:16 - 18 Sep 2006    Post subject: Reply with quote
I've just had a new chain and sprocket kit fitted and they sprayed on some dry chain lube, does anyone know if its any good?
Its not like oil its more of a sticky substance.
I'm just worried i'm going to kill my new chain if its not lubricated properly.
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
Cillit-BANG
PostPosted: 11:20 - 18 Sep 2006    Post subject: Reply with quote
It depends on what dry lube it was!! But generally, in summer months, dry lube will be fine.
Personally I rate the 'Wurth' Dry lube for summer use then something a bit thicker for winter like PJ1.
Mark_petty
PostPosted: 12:18 - 18 Sep 2006    Post subject: Reply with quote
Thanks mate, yes its that Wurth Dry lube, it doesn't say anything about summer though.
angryjonny
PostPosted: 12:35 - 18 Sep 2006    Post subject: Reply with quote
Wurth is what I've been using. I'm clueless so I just bought what the guy in the bike shop recommended. Interested by the engine-oil suggestion though. Might give it a go. Is it a pain to apply?
colin1
Captain Safety
PostPosted: 18:52 - 18 Sep 2006    Post subject: Reply with quote
i use a pop bottle with engine oil and pour a bit on the chain while rotating the back wheel by hand when bike is on a paddock stand
i think kickstart does it with the engine driving the back wheel while on a paddock stand but i dont fancy that
might be ok if you have one of those oil cans with a long stem tho
your chain wont look pretty like the ones that have clear wax (which is more suitable for dry weather)
kickstart reckons that waxs turn into a grinding paste as they accumalte grit etc, while oil just flings it off
it does mean you have to lube the chain more than you would if you just used spray on grease or wax, but the chain looks healthier to me for it particulalrly the links and side plates
colin1
Captain Safety
PostPosted: 19:00 - 18 Sep 2006    Post subject: Reply with quote
i suspect they done move as fast as bike chains
but i cant be sure of that
i know bike engines rev higher
McJamweasel
BCF Junkie
PostPosted: 19:46 - 18 Sep 2006    Post subject: Reply with quote
And what difference does that make to chain speed?
Ichy
PostPosted: 19:58 - 18 Sep 2006    Post subject: Reply with quote
I once used the stuff we had at work for the overhead conveyors. If the stuff you've been offered is anything like it then don't bother. The stuff was like really thick tar when it set. It was so sticky the chain ended up covered in gravel.
I now use stuff mean't for motocross bikes. I brought it by mistake once but found it did a good job as long as you give it time to set otherwise it sticks to the bike panels and tyre.
veeeffarr
PostPosted: 20:02 - 18 Sep 2006    Post subject: Reply with quote
So then obviously you know there's gear ratios and final drive ratios to be taken into account? Let alone primary and secondary reduction ratios Rolling Eyes
Dom_
Points Mean Prizes
PostPosted: 21:38 - 18 Sep 2006    Post subject: Reply with quote
Christ you tight bastard, a can of lube is only a fiver! Laughing
veeeffarr
PostPosted: 21:44 - 18 Sep 2006    Post subject: Reply with quote
Not being tight, just thought marine grade might be better stuff.
Jebus
PostPosted: 22:54 - 18 Sep 2006    Post subject: Reply with quote
I would say stick to the bike stuff, it is desgined for use on motorbike chains so be better than anything else.
2nd time around Smile CBT: 8/9/11
125 Varadero
colin1
Captain Safety
PostPosted: 23:36 - 18 Sep 2006    Post subject: Reply with quote
which is why i said i cant be sure, but i suspect a bike chain goes faster than a boat chain
and as bloke said, chances are the stuff designed for bikes is good for bikes, and the stuff for boats is good for boats, as thats what they designed it for
you can get spray on grease for £1 from pound shops sometimes
PostPosted: 23:46 - 18 Sep 2006    Post subject: Reply with quote
Yes it will work, but will be a bit messier if that bothers you.
I often use plain oil on chains. Yes it flings off, but that takes the cack with if so the chain stays relatively clean (wheels don't). Also sometime just use Scott oil straight from the bottle (and to clean a chain, a toothbrush and a small pot of Scott oil).
Tend not to have the engine running on the paddock stand, but will do so on a centre stand (just make sure fingers are well out of the way).
The last post was made 20 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 135.94 Kb
